on 11-10-2023 09:19
I recently switched to VM landline and broadband/TV.
Broadband is fine but no dial tone on the landline phone, no dial tone, it's never worked.
My VM hub / router has an orange light lit at the bottom all the time, but on this forum people seem to think that it should be white?
The orange bar LED at the bottom is the only LED lit on the hub.
Answered! Go to Answer
on 19-10-2023 17:13
Virgin should have sent you one and you could request one by calling in.
Quicker and easier to get one here though:
on 11-10-2023 09:26
Orange LED is just a deteriorating LED and nothing to worry about.
As for the phone, where have you it connected to? Is it in a standard phone socket, or is it plugged into the Hub?
11-10-2023 10:31 - edited 11-10-2023 10:36
An ordinary phone connects to the TEL1 socket via the VM adapter as per
If you log into the VM hub you should see Telephony is Ready or Enabled at the bottom of the Welcome page when you log in.
If it shows Telephony (Disabled) as per this image below then the landline has not been set up on the hub
on 13-10-2023 12:06
Hi @Priffin
Sorry to hear the phone is not working.
Have you followed the brilliant advice from our Forum community and got this sorted?
Keep us posted if you need further help.
Best wishes.
on 19-10-2023 12:04
I'm not sure if I have an adaptor fitted.
Where do I get them from?
Regards,
on 19-10-2023 17:13
on 19-10-2023 17:17
Thanks Paul! 🙂
on 22-10-2023 14:41
Hi Priffin, thanks for the message and welcome back to the forums. I am sorry to hear that the landline is now working and will send you a PM so that this can be looked into further. - Chris.
