on 11-04-2023 12:34
Hi All,
I am having issues with the speed recently I m supposed to have 1GB but as you can see I very rarely get this speed.
Acquired Downstream Channel(Hz) | 331000000 | Locked |
Ranged Upstream Channel(Hz) | 49600000 | Ranged |
Provisioning State | Online | Operational |
1 | 331000000 | 4.9 | 39 | QAM 256 | 25 |
2 | 139000000 | 5.2 | 37 | QAM 256 | 1 |
3 | 147000000 | 5.3 | 38 | QAM 256 | 2 |
4 | 155000000 | 5.4 | 38 | QAM 256 | 3 |
5 | 163000000 | 5.3 | 38 | QAM 256 | 4 |
6 | 171000000 | 5.3 | 38 | QAM 256 | 5 |
7 | 179000000 | 5.4 | 38 | QAM 256 | 6 |
8 | 187000000 | 5.5 | 38 | QAM 256 | 7 |
9 | 195000000 | 5.6 | 38 | QAM 256 | 8 |
10 | 203000000 | 5.5 | 38 | QAM 256 | 9 |
11 | 211000000 | 5.7 | 38 | QAM 256 | 10 |
12 | 219000000 | 5.8 | 39 | QAM 256 | 11 |
13 | 227000000 | 6 | 39 | QAM 256 | 12 |
14 | 235000000 | 6.2 | 39 | QAM 256 | 13 |
15 | 243000000 | 6.3 | 39 | QAM 256 | 14 |
16 | 251000000 | 6.4 | 39 | QAM 256 | 15 |
17 | 259000000 | 6.3 | 39 | QAM 256 | 16 |
18 | 267000000 | 6.2 | 39 | QAM 256 | 17 |
19 | 275000000 | 6 | 39 | QAM 256 | 18 |
20 | 283000000 | 5.8 | 39 | QAM 256 | 19 |
21 | 291000000 | 5.7 | 39 | QAM 256 | 20 |
22 | 299000000 | 5.4 | 39 | QAM 256 | 21 |
23 | 307000000 | 5.2 | 38 | QAM 256 | 22 |
24 | 315000000 | 5 | 39 | QAM 256 | 23 |
25 | 323000000 | 4.9 | 38 | QAM 256 | 24 |
26 | 339000000 | 5 | 39 | QAM 256 | 26 |
27 | 347000000 | 5 | 39 | QAM 256 | 27 |
28 | 355000000 | 4.9 | 39 | QAM 256 | 28 |
29 | 363000000 | 5.1 | 39 | QAM 256 | 29 |
30 | 371000000 | 5 | 39 | QAM 256 | 30 |
31 | 379000000 | 5.2 | 39 | QAM 256 | 31 |
1 | Locked | 39 | 115 | 1 |
2 | Locked | 37 | 130 | 0 |
3 | Locked | 38 | 109 | 0 |
4 | Locked | 38 | 103 | 0 |
5 | Locked | 38 | 126 | 0 |
6 | Locked | 38 | 113 | 0 |
7 | Locked | 38 | 110 | 0 |
8 | Locked | 38 | 109 | 0 |
9 | Locked | 38 | 96 | 0 |
10 | Locked | 38 | 98 | 0 |
11 | Locked | 38 | 103 | 0 |
12 | Locked | 39 | 84 | 0 |
13 | Locked | 39 | 101 | 0 |
14 | Locked | 39 | 92 | 0 |
15 | Locked | 39 | 70 | 0 |
16 | Locked | 39 | 92 | 0 |
17 | Locked | 39 | 105 | 0 |
18 | Locked | 39 | 106 | 0 |
19 | Locked | 39 | 90 | 0 |
20 | Locked | 39 | 88 | 0 |
21 | Locked | 39 | 95 | 0 |
22 | Locked | 39 | 104 | 0 |
23 | Locked | 38 | 98 | 0 |
24 | Locked | 39 | 102 | 0 |
25 | Locked | 38 | 106 | 0 |
26 | Locked | 39 | 103 | 0 |
27 | Locked | 39 | 90 | 0 |
28 | Locked | 39 | 99 | 0 |
29 | Locked | 39 | 97 | 0 |
30 | Locked | 39 | 83 | 0 |
31 | Locked | 39 | 91 | 0 |
0 | 49600000 | 45.3 | 5120 | QAM 64 | 1 |
1 | 43100000 | 45.3 | 5120 | QAM 64 | 2 |
2 | 36600000 | 45.3 | 5120 | QAM 64 | 3 |
3 | 30100000 | 45.3 | 5120 | QAM 64 | 4 |
4 | 23600000 | 45 | 5120 | QAM 64 | 5 |
0 | ATDMA | 0 | 0 | 0 | 0 |
1 | ATDMA | 0 | 0 | 0 | 0 |
2 | ATDMA | 0 | 0 | 0 | 0 |
3 | ATDMA | 0 | 0 | 0 | 0 |
4 | ATDMA | 0 | 0 | 8 | 0 |
the logs are full of similar messages to the below
11-04-2023 11:18:39 | notice | US profile assignment change. US Chan ID: 11; Previous Profile: 11 13; New Profile: 12 13.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
11-04-2023 10:14:50 | notice | US profile assignment change. US Chan ID: 11; Previous Profile: 12 13; New Profile: 11 13.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
11-04-2023 04:55:47 | notice | US profile assignment change. US Chan ID: 11; Previous Profile: 11 13; New Profile: 12 13.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
11-04-2023 03:51:59 | notice | US profile assignment change. US Chan ID: 11; Previous Profile: 12 13; New Profile: 11 13.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
11-04-2023 02:48:10 | notice | US profile assignment change. US Chan ID: 11; Previous Profile: 11 13; New Profile: 12 13.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
11-04-2023 01:44:21 | notice | US profile assignment change. US Chan ID: 11; Previous Profile: 12 13; New Profile: 11 13.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
11-04-2023 00:40:33 | notice | US profile assignment change. US Chan ID: 11; Previous Profile: 11 13; New Profile: 12 13.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
11-04-2023 00:20:16 | notice | US profile assignment change. US Chan ID: 11; Previous Profile: 12 13; New Profile: 11 13.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
11-04-2023 00:15:13 | notice | US profile assignment change. US Chan ID: 11; Previous Profile: 11 13; New Profile: 12 13.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
I have rebooted multiple times, but nothing is changing. Any ideas on the issue?
11-04-2023 14:24 - edited 11-04-2023 14:25
Try checking with Area faults on 0800 561 0061 or if you have a VM landline 150 as small local faults are not listed on the VM status page.
Setup a BQM to monitor your circuit www.thinkbroadband.com/ping
Once done we can comment.
Also what speed is showing with a direct wired connection using www.samknows.com/realspeed ?
Note VM only guarantee 20Mb speed over WIFI,
on 11-04-2023 14:28
Speed shows as 66.27 in router mode.
Nothing on local faults, this has been getting worse for weeks now.
on 11-04-2023 14:30
What does the Samknows client show as being delivered to the Hub? Can you post a screenshot of the result please? Is that also using a direct wired connection to the Hub with a gigabit capable device, e.g. laptop etc.
on 11-04-2023 14:51
That was the speed shown on samknows I have set it back to modem mode and really don't want to reset it again.
It was tested wired though with a 1 GB port
on 11-04-2023 14:55
Okay, that's not good. Your stats look good, apart from the T3 timeouts and the US channel profile hopping about. You will need a VM technician to resolve this one for sure. Note however, VM will request you put the Hub in Router mode, so they can monitor your circuit.
Setup a BQM if you have not already to record and monitor your incoming circuit www.thinkbroadband.com/ping
on 14-04-2023 08:08
Hi dsmars 👋
I've had a look at things from our side and can see you've been able to get in touch regarding this and arrange a technician.
If you do still need help with anything please let us know.
Alex_Rm
on 14-04-2023 08:18
Yes engineer came yesterday but speed is still low, currently 56mbps he said he would contact me on Monday to check if the hub replacement worked.
14-04-2023 08:32 - edited 14-04-2023 08:33
If a change of Hub was the answer it would work perfectly instantly, the engineer ought to know that.
Are folks close to you are also seeing these performance issues ?
Given the issues have persisted, is an internet defect being reported on the 0800 561 0061 fault service.
on 16-04-2023 10:40
Thank you for keeping us updated with this dsmars.
How has the service been since your post?
^Martin
