Download speed not as it should be
Dodsy77
My download speed has gone haywire today, ranging from 80mbps to 280mbps ish on a 350mbps connection using Ethernet
Screenshot 2023-04-16 at 15-18-24 Broadband Quality Monitor thinkbroadband.png
4 REPLIES 4
Dodsy77
Router stats
Screenshot 2023-04-16 at 16-00-17 Hub 3.0.pngScreenshot 2023-04-16 at 16-00-07 Hub 3.0.pngScreenshot 2023-04-16 at 15-59-58 Hub 3.0.png
Your downstream power is too low, the range should be -6 to +10. so you have fallen off the bottom, so to speak.
You will need a VM technician to resolve this issue.  Even so, I have to admit the Samknows is showing full speed to your Hub .....
Unless you have an attenuator on the back of your hub (looks like a small cylinder)
If you do, you can remove that yourself and you will get more power level!
Adri_G
Hey Dodsy77, thanks for reaching out on our help forums and the community.
Sorry to see there are some issues with your hub's performance and speeds currently, we'd love to best assist with this.
Can you advise what fixes you've tried so far such as rebooting or resetting the hub so we can advise from there?
On our end the seem to be no issues with our hub or network at the minute, are you using any 3rd party equipment currently?
Can you please advise if you get below 180MB over wired connection on any of the speed tests performed as you've mentioned there's a range from 80MB to 280MB above?
Please, share more and we're happy to help.
Adri
