on 09-03-2024 12:31
I hope this will be picked up by someone at VM, as there have been many poor-quality issues.
1. The first team came to connect fibre to my house said it couldn't be done (distance too far for the cable). I was told an engineer would need to do a site visit, but my order was then 'lost' and nothing happened.
2. The second team arrived three months later. The could fit the cable with no problem. The first team came on a Friday afternoon; I guess they wanted to clock off early!?!
3. Had to wait a long time for the engineer's visit (as expected). He installed the kit with no problem, but as I have thick walls, it needed the WiFi booster (as confirmed with the VM Connect app). However, the engineer doesn't have any of those, so although the main WiFi was installed, I could not get WiFi everywhere. Trying to get the booster order was a nightmare. Many hours on support chat and support calls. Eventually got one ordered.
I was still having to run the BT service at the same time as VM... which turned out to be a good thing.
4. As a day or two after the new Hub 5X was installed, the power supply failed! No VM internet.
5. Again, many hours trying to contact support. Unfortunately, a replacement power supply could not be sent out due to the open delivery order of the WiFi booster! This is rediculous VM. Internet is down due to faulty equipment and you can't send out the replacement????
6. Eventually, the WiFi booster turned up. But guess what? No power supply in that box!!! This booster for the Hub 5X requires a separate power supply and does not plug directly into the power socket. So... back on to support.
7. However, even though the booster has been delivered, the 'order' is still open on the system.
So I now have two useless pieces of VM kit that need new power supplies, and VM can't order the replacements!!
It's a good job I didn't cancel BT. I was not expecting to have to pay for two internet providers though!
09-03-2024 12:43 - edited 09-03-2024 12:44
Welcome to Virginmedia's famous customer service!
It's often recommended on here that an existing service should be maintained until after VM is installed and working, to allow for delays.
Unfortunately most users only come here after it's too late. You're wise to have thought of it beforehand.
on 09-03-2024 15:08
Make sure you get your compensation for a total loss of service
on 11-03-2024 19:42
Hi GavShrews,
We're sorry to hear you're having an issue with your connection. Taking a look at things here, it looks like you have a hub and connection that we're unable to support in the Community. You'll need to contact our specialist team so they can help further. Please call the team on 150 / 0345 454 1111. As long as you're calling from the number we have as a contact number for you, this will pop you directly through to the team you need.
Let us know how you get on.
on 15-03-2024 17:14
8.5 days without internet.... which VM are charging for.
I had internet for 1.5 days, then it died. The most correspondence I've had back from VM is them telling me they will charge me for two months of service!!!
But the VM quality continues: Eventually, the delivery arrives. I am eager to get the two power supplies plugged in for this expensive internet I am sent.
But no!
Virgin Media has sent me a useless coaxial cable!!
So I guess, another week at least without internet.... if I can ever get through to VM Support that is!!!
Shockingly bad service from Virgin Media. 😠
on 15-03-2024 17:26
Compensation
https://www.virginmedia.com/help/automatic-compensation
on 16-03-2024 08:38
Thanks!
Just spent another 3 hours with support. They know I'm without service, however, when I queried it, she hung up the phone!
First support person after 2 hours said they can't help with ordering a power supply, and ended the session.
Second person said they can only order 1 supply.
So, it also isn't meeting the Virgin Media WiFi guarantee. I got no WiFi anywhere, and with the pod not working either, when I do get the fixed power supply, I will have no wifi in parts of the house.
on 16-03-2024 08:43
Oh, support just called back.
Apparently, they cannot order any power supply. It's on me to chase up again in another 2 days time!!!!!
on 16-03-2024 09:16
@GavShrews wrote:Oh, support just called back.
Raise a formal complaint at this link:
on 19-03-2024 07:56
13 days and counting with total loss of service.
According to their compensation page, I am due £102.63 (and counting). The complaints department offered me £20, with no resolution to the lack of service.
This might have to go to OfCom at this rate.
