on 09-07-2020 12:15
I'm currently away from the UK and need to access my voicemail. But it's asking for a pin that I don't remember setting. I tried all the important numbers I may have used but now it's locked and the customer service line tells me to come here. Does anyone know how to fix this?
Thank you!
Answered! Go to Answer
on 21-10-2022 14:13
Yes, it is turned on in my device settings too
on 21-10-2022 14:28
Hi @Laurah89,
Thank you for checking and confirming. So that we can take a closer look at what's going on for you, I'm going to send you a private message in a few moments.
Please respond to this when you can and we'll proceed from there.
on 21-10-2022 14:52
Hi I'm also having problems accessing VM as I didn't set up a PIN prior to leaving the UK for Spain.
Any help would be greatly appreciated.
Paul
on 21-10-2022 15:33
Hi @PaulMuirhead,
I'm so sorry to hear you're having some problems with your services outside of the UK. Are you getting no mobile service at all now that you're outside of the UK, or is it just a problem with the voicemail and PIN?
on 21-10-2022 15:46
Hi Zach and thanks for the quick reply.
It only seems to be VM that’s the problem, I can access mobile data, hotspot my phone and make and receive calls no problem!
on 21-10-2022 15:52
Hi @PaulMuirhead,
Thank you for expanding and confirming. I'm going to send you a private message in a few moments so we can take a closer look over things. Please respond to this when you can and we'll go from there.
on 24-10-2022 13:46
Hi @PaulMuirhead,
Thank you for getting back to me via private message so that we could look into this for you. I'm glad that we've been able to address and resolve this matter.
Please do let us know if there's anything more that we can assist you with.
on 09-11-2022 14:36
i am currently abroad for few weeks and cannot access to my voicemail. I haven’t set up a pin before going away. Can someone help me ?
thank you very much
on 09-11-2022 14:39
Hello Nilili.
Thanks for your first post and welcome to our Community.
Hope the weather is better than it is here.
Sorry to hear you are having an issue with your voicemail pin.
We can get the new pin set up for you.
If you can check the purple envelope top right of your screen that would be great.
Gareth_L
on 09-11-2022 14:47
Hi Gareth,
thanks for your quick reply. I checked the purple envelope and cannot see your message
