on 11-10-2021 11:21
Hi all
So my Virgin Hub 4 WIFI has suddenly stopped and there is a solid red light. I googled the problem and it mentioned it could be over heated, which is odd since it's sat on the side board with nothing within 20cm each side. As per usual, can't get through to Virgin on the phone. Any ideas?
Answered! Go to Answer
on 27-01-2023 16:55
Hi there Chewbacca1,
Thanks for your post and welcome back to the community.
Are you able to post a picture of what the Hub looks like?
Just so we can ensure on our side that it's not still being affected by the same issues?
Regards,
on 06-08-2023 22:07
I also have a solid red light on my, I think, Hub 3 & so supposedly overgeating. It's not hot & has been like it for weeks. If a replacement is needed can you let me know please? I've tried re-setting a number of times. Thank you
on 06-08-2023 22:08
'overheating' 😄
on 07-08-2023 09:54
Hi SB-K,
Thanks for using the Community Forums to get this issue with your Hub 3 looked into, I am sorry if this has been causing some frustration 😥 I would be more than happy to look into this for you!
I understand you've tried rebooting the Hub, but we'll need to see what happens when you do a full Pin Hole reset. To do this just hold a pin (or similar) into the hole on the back of the Hub for 3 - 5 seconds. This will revert the Hub back to factory settings and will also let us know what we need to do next.
Do this for us today and let us know whether the red light reappears or not 🤗
Megan_L
on 13-08-2023 10:38
Yeah, did that sorry...still nothing.
on 13-08-2023 14:59
Thanks for giving it a go, SB-K.
I'm sorry to hear your Hub hasn't changed, even after a pin-hole reset. I'm going to send you a private message so we can book a Technician to come and replace this for you.
Please look out for it int he top-right, white envelope or the "Messages" tab when tapping your profile picture.
