on 13-08-2023 10:59
Hello,
I'm hoping I can get some help on this matter. I have a solid red light on my superhub which has persisted over several weeks. This is joined by incredibly poor performance over 2.4Ghz & 5Ghz WiFi, and I believe a new superhub is needed.
The unit is not overheating.
I called support, went through all of the respective actions, and had to 'wait and see'. Unfortunately the issue has persisted over the last few weeks.
As a last ditch effort, I turned the hub off for 10 hours last night to see if that would change anything this morning. Unfortunately it did not.
Does anyone know how I can resolve this issue without having to buy another router?
Many thanks
13-08-2023 11:39 - edited 13-08-2023 11:42
@PJ789 wrote:Hello,
Many thanks
Firstly, your VM equipment is rented. If it is not working correctly (which it isn’t) VM will replace it free of charge as per your contract. You have rebooted & done a “cold start”, which has not resolved it. The false overheat warning could mask a real issue that could be a fire risk, plus there has been a drop in performance, so you require a tech visit to replace it.
I have escalated this thread as a potential safety issue, so you should get a response here from the forum team soon. They will utilise the private messaging system to confirm your details & get this under way.
on 13-08-2023 13:19
Hey @PJ789,
Sorry to hear you are having this issue with your Hub, what I would like to do is go about sending out a replacement Hub for you, I will need to confirm some details with you in a quick private message, if you have not used this feature before you can access it via the envelope at the top or your screen.
Joe
on 13-08-2023 13:38
Thank you very much for the escalation nodrogd! Much appreciated.
on 13-08-2023 13:38
Thank you very much Joe, I've just replied to you now.
on 13-08-2023 15:06
Hey @PJ789,
Glad we were able to have that chat and sort out a technician to replace your Hub, do let us know how the appointment goes and if you require anything further let us know.
Joe
