on 14-06-2023 18:50
Making a new post in the hopes of getting someone from VM to contact me. The previous rep did not respond to me and it has been a few months.
I am still getting the same constant disconnects every day.
Acquired Downstream Channel(Hz) | 138000000 | Locked |
Ranged Upstream Channel(Hz) | 49600000 | Ranged |
Provisioning State | Online | Operational |
1 | 138000000 | -2.3 | 41 | QAM 256 | 1 |
2 | 146000000 | -2.6 | 42 | QAM 256 | 2 |
3 | 154000000 | -2.7 | 41 | QAM 256 | 3 |
4 | 162000000 | -3 | 42 | QAM 256 | 4 |
5 | 170000000 | -3.4 | 41 | QAM 256 | 5 |
6 | 178000000 | -3.5 | 41 | QAM 256 | 6 |
7 | 186000000 | -3.6 | 41 | QAM 256 | 7 |
8 | 194000000 | -3.7 | 41 | QAM 256 | 8 |
9 | 202000000 | -3.6 | 41 | QAM 256 | 9 |
10 | 210000000 | -3.7 | 41 | QAM 256 | 10 |
11 | 218000000 | -3.8 | 40 | QAM 256 | 11 |
12 | 226000000 | -4 | 31 | QAM 256 | 12 |
13 | 234000000 | -4.1 | 41 | QAM 256 | 13 |
14 | 242000000 | -4.3 | 41 | QAM 256 | 14 |
15 | 250000000 | -4.5 | 40 | QAM 256 | 15 |
16 | 258000000 | -4.6 | 40 | QAM 256 | 16 |
17 | 266000000 | -4.7 | 40 | QAM 256 | 17 |
18 | 274000000 | -4.8 | 40 | QAM 256 | 18 |
19 | 282000000 | -4.8 | 39 | QAM 256 | 19 |
20 | 290000000 | -4.8 | 39 | QAM 256 | 20 |
21 | 298000000 | -4.9 | 39 | QAM 256 | 21 |
22 | 306000000 | -5 | 39 | QAM 256 | 22 |
23 | 314000000 | -5.2 | 39 | QAM 256 | 23 |
24 | 322000000 | -5.6 | 39 | QAM 256 | 24 |
25 | 330000000 | -5.8 | 39 | QAM 256 | 25 |
26 | 338000000 | -6 | 39 | QAM 256 | 26 |
27 | 346000000 | -6 | 39 | QAM 256 | 27 |
28 | 354000000 | -6.2 | 39 | QAM 256 | 28 |
29 | 362000000 | -6 | 40 | QAM 256 | 29 |
30 | 370000000 | -6.2 | 39 | QAM 256 | 30 |
31 | 378000000 | -6.3 | 40 | QAM 256 | 31 |
1 | Locked | 41 | 4661652 | 1829505 |
2 | Locked | 42 | 3042311 | 509694 |
3 | Locked | 41 | 3118376 | 845370 |
4 | Locked | 42 | 2240589 | 246132 |
5 | Locked | 41 | 6082967 | 357009 |
6 | Locked | 41 | 7395652 | 492543 |
7 | Locked | 41 | 823675 | 25121 |
8 | Locked | 41 | 11928 | 1379 |
9 | Locked | 41 | 9558 | 579 |
10 | Locked | 41 | 11845 | 341 |
11 | Locked | 40 | 7687 | 500 |
12 | Locked | 31 | 257827715 | 1822 |
13 | Locked | 41 | 7315 | 1497 |
14 | Locked | 41 | 5229 | 1151 |
15 | Locked | 40 | 4297 | 427 |
16 | Locked | 40 | 3896 | 153 |
17 | Locked | 40 | 2610 | 167 |
18 | Locked | 40 | 2998 | 508 |
19 | Locked | 39 | 2847 | 1660 |
20 | Locked | 39 | 2525 | 1770 |
21 | Locked | 39 | 2082 | 1512 |
22 | Locked | 39 | 1607 | 1028 |
23 | Locked | 39 | 1562 | 203 |
24 | Locked | 39 | 1052 | 83 |
25 | Locked | 39 | 987 | 69 |
26 | Locked | 39 | 1529 | 96 |
27 | Locked | 39 | 2036 | 148 |
28 | Locked | 39 | 1699 | 189 |
29 | Locked | 40 | 1233 | 102 |
30 | Locked | 39 | 672 | 51 |
31 | Locked | 40 | 395 | 35 |
0 | 49600000 | 48.5 | 5120 | QAM 64 | 1 |
1 | 43100000 | 48 | 5120 | QAM 64 | 2 |
2 | 36600000 | 48 | 5120 | QAM 64 | 3 |
3 | 30100000 | 47.5 | 5120 | QAM 64 | 4 |
4 | 23600000 | 47.3 | 5120 | QAM 64 | 5 |
0 | ATDMA | 0 | 0 | 2 | 3 |
1 | ATDMA | 0 | 0 | 3 | 1 |
2 | ATDMA | 0 | 0 | 2 | 1 |
3 | ATDMA | 0 | 0 | 1 | 0 |
4 | ATDMA | 0 | 0 | 0 | 0 |
General Configuration
Allowed |
1 |
Enabled |
3.1 |
9873254k;fg87dsfd;kfoA,.i |
29902 |
1200000450 bps |
42600bytes |
0 bps |
Primary Upstream Service Flow
29899 |
110000274 bps |
42600bytes |
0 bps |
42600bytes |
Best Effort |
14-06-2023 20:46:05 | critical | No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
14-06-2023 20:45:06 | critical | Received Response to Broadcast Maintenance Request, But no Unicast Maintenance opportunities received - T4 time out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
14-06-2023 20:32:57 | warning | DBC-REQ Mismatch Between Calculated Value for P1.6hi Compared to CCAP Provided Value;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
14-06-2023 20:29:48 | critical | Received Response to Broadcast Maintenance Request, But no Unicast Maintenance opportunities received - T4 time out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
14-06-2023 20:29:48 | critical | Started Unicast Maintenance Ranging - No Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
14-06-2023 11:38:39 | warning | DBC-REQ Mismatch Between Calculated Value for P1.6hi Compared to CCAP Provided Value;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
14-06-2023 11:38:39 | notice | US profile assignment change. US Chan ID: 6; Previous Profile: 12 13; New Profile: 11 13.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
14-06-2023 10:48:15 | warning | DBC-REQ Mismatch Between Calculated Value for P1.6hi Compared to CCAP Provided Value;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
14-06-2023 10:48:14 | notice | US profile assignment change. US Chan ID: 6; Previous Profile: 11 13; New Profile: 12 13.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
14-06-2023 10:38:05 | notice | US profile assignment change. US Chan ID: 6; Previous Profile: 12 13; New Profile: 11 13.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
14-06-2023 10:38:05 | warning | DBC-REQ Mismatch Between Calculated Value for P1.6hi Compared to CCAP Provided Value;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
14-06-2023 07:29:06 | warning | DBC-REQ Mismatch Between Calculated Value for P1.6hi Compared to CCAP Provided Value;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
14-06-2023 07:29:05 | notice | US profile assignment change. US Chan ID: 6; Previous Profile: 11 13; New Profile: 12 13.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
14-06-2023 07:26:40 | notice | US profile assignment change. US Chan ID: 6; Previous Profile: 12 13; New Profile: 11 13.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
14-06-2023 07:26:40 | warning | DBC-REQ Mismatch Between Calculated Value for P1.6hi Compared to CCAP Provided Value;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
14-06-2023 06:20:09 | warning | Dynamic Range Window violation |
14-06-2023 06:20:09 | warning | RNG-RSP CCAP Commanded Power Exceeds Value Corresponding to the Top of the DRW;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
14-06-2023 06:18:48 | warning | DBC-REQ Mismatch Between Calculated Value for P1.6hi Compared to CCAP Provided Value;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
14-06-2023 06:18:47 | notice | US profile assignment change. US Chan ID: 6; Previous Profile: 11 13; New Profile: 12 13.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
14-06-2023 06:05:44 | notice | US profile assignment change. US Chan ID: 6; Previous Profile: 12 13; New Profile: 11 13.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
14-06-2023 06:05:44 | warning | DBC-REQ Mismatch Between Calculated Value for P1.6hi Compared to CCAP Provided Value;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
14-06-2023 05:02:09 | warning | DBC-REQ Mismatch Between Calculated Value for P1.6hi Compared to CCAP Provided Value;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
14-06-2023 05:02:09 | notice | US profile assignment change. US Chan ID: 6; Previous Profile: 11 13; New Profile: 12 13.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
14-06-2023 04:58:37 | warning | Dynamic Range Window violation |
14-06-2023 04:58:37 | warning | RNG-RSP CCAP Commanded Power Exceeds Value Corresponding to the Top of the DRW;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
14-06-2023 04:24:56 | notice | US profile assignment change. US Chan ID: 6; Previous Profile: 12 13; New Profile: 11 13.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
14-06-2023 04:24:56 | warning | DBC-REQ Mismatch Between Calculated Value for P1.6hi Compared to CCAP Provided Value;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
14-06-2023 03:36:24 | warning | RNG-RSP CCAP Commanded Power in Excess of 6 dB Below the Value Corresponding to the Top of the DRW;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
14-06-2023 03:16:46 | warning | Dynamic Range Window violation |
14-06-2023 03:16:46 | warning | RNG-RSP CCAP Commanded Power Exceeds Value Corresponding to the Top of the DRW;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
15-06-2023 08:04 - edited 15-06-2023 08:22
You have loads of post RS errors and DS channel 12 is struggling re noise. There are also quite a few timeouts.
Call it in as a fault. Also the VM forum team can arrange for a Hub 3 for you.
on 15-06-2023 13:55
@Cardiffman282 wrote:You have loads of post RS errors and DS channel 12 is struggling re noise. There are also quite a few timeouts.
VM wouldn't arrange for a hub 3 - as per the OP's opening post in their original thread, they have a Gig1 connection.
(Upgraded to GIG1 earlier this year, been getting multiple daily disconnections lately. Hub 5 is running in modem mode. Not an issue with my router, seems to be related to the hub or the connection itself.)
They would only supply a hub 3 if the OP downgraded their speed.
Although the OP says it's not an issue with their router, it would be best to perform a timed one minute full reset of the hub 5, with all other equipment and ethernet leads removed and then post the logs again which should have been reset to zero. Then leaving it in router mode re-post the logs after a few hours to show how the errors are increasing.
on 15-06-2023 14:47
Fair cop. Must have mixed up two threads in my dotage.
on 17-06-2023 15:24
Hi @Cyborgmatt 👋
A warm welcome to our Community Forums and thanks for your post.
I am sorry to hear you've been having some issues with your service.
I haven't been able to locate your details using your Forum credentials so at the time of writing aren't able to run any tests.
I'll pop you a PM 📩 now to confirm these details and we can take it from there.
Speak soon 😊
18-06-2023 16:34 - edited 18-06-2023 16:35
Had a great engineer come on Saturday thanks to the chat support team. He found some stability issues with the line and replaced some old equipment. It has been just over 30 hours so far but the connection appears to be much more stable now.
1 | 138000000 | 3.6 | 42 | QAM 256 | 1 |
2 | 146000000 | 3.3 | 42 | QAM 256 | 2 |
3 | 154000000 | 3 | 42 | QAM 256 | 3 |
4 | 162000000 | 2.8 | 42 | QAM 256 | 4 |
5 | 170000000 | 2.4 | 42 | QAM 256 | 5 |
6 | 178000000 | 2.3 | 42 | QAM 256 | 6 |
7 | 186000000 | 2.2 | 42 | QAM 256 | 7 |
8 | 194000000 | 2.2 | 41 | QAM 256 | 8 |
9 | 202000000 | 2.2 | 41 | QAM 256 | 9 |
10 | 210000000 | 2.3 | 41 | QAM 256 | 10 |
11 | 218000000 | 2.1 | 41 | QAM 256 | 11 |
12 | 226000000 | 2 | 41 | QAM 256 | 12 |
13 | 234000000 | 1.9 | 41 | QAM 256 | 13 |
14 | 242000000 | 1.6 | 41 | QAM 256 | 14 |
15 | 250000000 | 1.4 | 41 | QAM 256 | 15 |
16 | 258000000 | 1.3 | 40 | QAM 256 | 16 |
17 | 266000000 | 1.3 | 40 | QAM 256 | 17 |
18 | 274000000 | 1.2 | 40 | QAM 256 | 18 |
19 | 282000000 | 1.2 | 40 | QAM 256 | 19 |
20 | 290000000 | 1.1 | 40 | QAM 256 | 20 |
21 | 298000000 | 0.9 | 40 | QAM 256 | 21 |
22 | 306000000 | 0.8 | 40 | QAM 256 | 22 |
23 | 314000000 | 0.6 | 40 | QAM 256 | 23 |
24 | 322000000 | 0.3 | 40 | QAM 256 | 24 |
25 | 330000000 | 0 | 40 | QAM 256 | 25 |
26 | 338000000 | 0.1 | 40 | QAM 256 | 26 |
27 | 346000000 | 0.2 | 40 | QAM 256 | 27 |
28 | 354000000 | 0.3 | 40 | QAM 256 | 28 |
29 | 362000000 | 0.2 | 40 | QAM 256 | 29 |
30 | 370000000 | 0.2 | 40 | QAM 256 | 30 |
31 | 378000000 | 0.4 | 40 | QAM 256 | 31 |
1 | Locked | 42 | 529 | 12 |
2 | Locked | 42 | 378 | 10 |
3 | Locked | 42 | 273 | 5 |
4 | Locked | 42 | 241 | 4 |
5 | Locked | 42 | 168 | 0 |
6 | Locked | 42 | 116 | 0 |
7 | Locked | 42 | 85 | 0 |
8 | Locked | 41 | 61 | 0 |
9 | Locked | 41 | 48 | 0 |
10 | Locked | 41 | 32 | 0 |
11 | Locked | 41 | 37 | 0 |
12 | Locked | 41 | 26 | 0 |
13 | Locked | 41 | 22 | 0 |
14 | Locked | 41 | 13 | 0 |
15 | Locked | 41 | 10 | 0 |
16 | Locked | 40 | 11 | 0 |
17 | Locked | 40 | 6 | 0 |
18 | Locked | 40 | 4 | 0 |
19 | Locked | 40 | 4 | 0 |
20 | Locked | 40 | 3 | 0 |
21 | Locked | 40 | 2 | 0 |
22 | Locked | 40 | 3 | 0 |
23 | Locked | 40 | 2 | 0 |
24 | Locked | 40 | 0 | 0 |
25 | Locked | 40 | 0 | 0 |
26 | Locked | 40 | 5 | 0 |
27 | Locked | 40 | 3 | 0 |
28 | Locked | 40 | 4 | 0 |
29 | Locked | 40 | 3 | 0 |
30 | Locked | 40 | 4 | 0 |
31 | Locked | 40 | 3 | 0 |
0 | 49600000 | 43.3 | 5120 | QAM 64 | 1 |
1 | 43100000 | 43 | 5120 | QAM 64 | 2 |
2 | 36600000 | 42.8 | 5120 | QAM 64 | 3 |
3 | 30100000 | 42.5 | 5120 | QAM 64 | 4 |
4 | 23600000 | 42.3 | 5120 | QAM 64 | 5 |
0 | ATDMA | 0 | 0 | 0 | 0 |
1 | ATDMA | 0 | 0 | 0 | 0 |
2 | ATDMA | 0 | 0 | 0 | 0 |
3 | ATDMA | 0 | 0 | 0 | 0 |
on 20-06-2023 18:29
Glad to hear service has improved Cyborgmatt,
Thanks for letting us know.
Alex_Rm
