insomniac22's avatar
insomniac22
Constant disconnects, resets required
For the last few weeks I have had constant issues requiring me to reset my router 3-4 times a day. I have the max virgin package and broad speed check show I only getting just over 100mb and often the upload speed is higher than the download.
error log:
12-05-2024 10:09:58 notice CM-STATUS message sent. Event Type Code: 24; Chan ID: 159; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: 1.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
12-05-2024 10:07:31 notice CM-STATUS message sent. Event Type Code: 16; Chan ID: 159; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: 1 2 3.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
12-05-2024 02:05:27 warning DBC-REQ Mismatch Between Calculated Value for P1.6hi Compared to CCAP Provided Value;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
12-05-2024 02:05:27 notice US profile assignment change. US Chan ID: 6; Previous Profile: 12 13; New Profile: 11 13.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
12-05-2024 00:57:19 notice US profile assignment change. US Chan ID: 6; Previous Profile: 11 13; New Profile: 12 13.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
12-05-2024 00:57:19 warning DBC-REQ Mismatch Between Calculated Value for P1.6hi Compared to CCAP Provided Value;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
12-05-2024 00:54:51 notice US profile assignment change. US Chan ID: 6; Previous Profile: 12 13; New Profile: 11 13.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Downstream info:
1 331000000 -1.4 39 QAM 256 25
2 139000000 6.8 41 QAM 256 1
3 147000000 6.3 41 QAM 256 2
4 155000000 5.8 41 QAM 256 3
5 163000000 5.2 41 QAM 256 4
6 171000000 4.8 41 QAM 256 5
7 179000000 4.3 41 QAM 256 6
8 187000000 3.9 41 QAM 256 7
9 195000000 3.6 40 QAM 256 8
10 203000000 3.1 41 QAM 256 9
11 211000000 2.6 40 QAM 256 10
12 219000000 2 40 QAM 256 11
13 243000000 0.4 40 QAM 256 14
14 251000000 0.3 40 QAM 256 15
15 275000000 0.1 40 QAM 256 18
16 283000000 0.1 40 QAM 256 19
17 307000000 0.6 39 QAM 256 22
18 339000000 -1.5 39 QAM 256 26
19 347000000 -1.8 39 QAM 256 27
20 371000000 -2.9 38 QAM 256 30
21 379000000 -2.9 38 QAM 256 31
22 403000000 -3.5 38 QAM 256 34
23 411000000 -3.8 38 QAM 256 35
24 435000000 -4.5 37 QAM 256 38
25 443000000 -4.7 37 QAM 256 39
26 467000000 -4.9 37 QAM 256 42
27 475000000 -5 37 QAM 256 43
28 483000000 -5.2 37 QAM 256 44
29 491000000 -5.4 37 QAM 256 45
30 499000000 -5.5 37 QAM 256 46
31 507000000 -5.8 37 QAM 256 47
32 515000000 -5.9 37 QAM 256 48
3.0 Downstream channels
1 Locked 39 32 1
2 Locked 41 33 0
3 Locked 41 14 0
4 Locked 41 15 0
5 Locked 41 16 0
6 Locked 41 8 0
7 Locked 41 15 0
8 Locked 41 20 0
9 Locked 40 12 0
10 Locked 41 13 0
11 Locked 40 19 0
12 Locked 40 10 0
13 Locked 40 9 0
14 Locked 40 13 0
15 Locked 40 16 0
16 Locked 40 23 0
17 Locked 39 23 0
18 Locked 39 21 0
19 Locked 39 27 0
20 Locked 38 28 0
21 Locked 38 40 0
22 Locked 38 28 0
23 Locked 38 21 0
24 Locked 37 39 0
25 Locked 37 49 2
26 Locked 37 61 0
27 Locked 37 55 0
28 Locked 37 66 0
29 Locked 37 61 0
30 Locked 37 59 0
31 Locked 37 71 0
32 Locked 37 62 0
3.1 Downstream channels
159 190 4K 3736 QAM 4096 148
159 Locked 32 -13.6 1724735205 1342154498
I have done all the restarts, disconnected the power for 10mins, disconnected all devices. Thanks for help in advance.
1 Reply
  • Ilyas_Y's avatar
    Ilyas_Y
    Hey insomniac22 Thanks for reaching out to us and a warm welcome to the Virgin Media Community forums. ๐Ÿ‘‹๐Ÿผ
    I'm sorry to see the issues with the connection you have been facing recently. ๐Ÿ˜ข
    Are you able to perform a hard reset on the Virgin Media hub?
    Pop a pin in the reset pin hole for 40 seconds and reset the hub.
    Please also set up a BQM graph which will help us monitor any drops on the line - this can be done here.
    Once we have a few days of data we can then assess this and look in to the matter.
    Kind regards,
    Ilyas.
