- jbrennandVery Insightful Person
What Hub model is it?
- Ashleigh_CForum Team (Retired)
Hi there techweb
Thank you so much for your post and welcome back to the forums, it's great to have you.
I am so sorry that you have faced this issue with your service and thank you so much again for posting. Can I ask if you have been able to try a pin hole reset? To do this push a pen etc into the reset hole at the back of the Hub and hold in for 30 seconds.
- AdduxiVery Insightful Person
If the red LED persists after a pinhole reset, the Hub should be swapped out. This red LED is the overheat warning and should be working correctly. A VM Mod should pick this up and discuss directly with you.
- techwebOn our wavelength
Thank you. Tried power cycle and pin hole reset. Issue persists.
Looks to be a fault and I am quite happy to replace myself.
Related Content
- 2 years ago
- 4 months ago
- 4 months ago
- 4 years ago
- 3 months ago
