on 10-12-2022 16:38
Upgraded to GIG1 earlier this year, been getting multiple daily disconnections lately. Hub 5 is running in modem mode. Not an issue with my router, seems to be related to the hub or the connection itself.
Status
Item Status Comments
Acquired Downstream Channel(Hz) | 138000000 | Locked |
Ranged Upstream Channel(Hz) | 49600000 | Ranged |
Provisioning State | Online | Operational |
Downstream
1 | 138000000 | 0.3 | 41 | QAM 256 | 1 |
2 | 146000000 | 0.6 | 41 | QAM 256 | 2 |
3 | 154000000 | 0.8 | 41 | QAM 256 | 3 |
4 | 162000000 | -1.1 | 41 | QAM 256 | 4 |
5 | 170000000 | -1.3 | 41 | QAM 256 | 5 |
6 | 178000000 | -1.5 | 41 | QAM 256 | 6 |
7 | 186000000 | -1.5 | 41 | QAM 256 | 7 |
8 | 194000000 | -1.5 | 41 | QAM 256 | 8 |
9 | 202000000 | -1.4 | 41 | QAM 256 | 9 |
10 | 210000000 | -1.5 | 41 | QAM 256 | 10 |
11 | 218000000 | -1.6 | 41 | QAM 256 | 11 |
12 | 226000000 | -1.8 | 40 | QAM 256 | 12 |
13 | 234000000 | -1.9 | 41 | QAM 256 | 13 |
14 | 242000000 | -2 | 41 | QAM 256 | 14 |
15 | 250000000 | -2.2 | 40 | QAM 256 | 15 |
16 | 258000000 | -2.3 | 40 | QAM 256 | 16 |
17 | 266000000 | -2.3 | 40 | QAM 256 | 17 |
18 | 274000000 | -2.4 | 40 | QAM 256 | 18 |
19 | 282000000 | -2.4 | 40 | QAM 256 | 19 |
20 | 290000000 | -2.4 | 39 | QAM 256 | 20 |
21 | 298000000 | -2.6 | 39 | QAM 256 | 21 |
22 | 306000000 | -2.7 | 39 | QAM 256 | 22 |
23 | 314000000 | -2.9 | 39 | QAM 256 | 23 |
24 | 322000000 | -3.2 | 39 | QAM 256 | 24 |
25 | 330000000 | -3.5 | 39 | QAM 256 | 25 |
26 | 338000000 | -3.6 | 40 | QAM 256 | 26 |
27 | 346000000 | -3.6 | 40 | QAM 256 | 27 |
28 | 354000000 | -3.8 | 40 | QAM 256 | 28 |
29 | 362000000 | -3.6 | 40 | QAM 256 | 29 |
30 | 370000000 | -3.7 | 40 | QAM 256 | 30 |
31 | 378000000 | -3.8 | 40 | QAM 256 | 31 |
1 | Locked | 41 | 3612389 | 609026 |
2 | Locked | 41 | 3999705 | 363670 |
3 | Locked | 41 | 2846763 | 146990 |
4 | Locked | 41 | 2338510 | 108613 |
5 | Locked | 41 | 8831692 | 892840 |
6 | Locked | 41 | 9823858 | 754161 |
7 | Locked | 41 | 1342031 | 257442 |
8 | Locked | 41 | 56602 | 6171 |
9 | Locked | 41 | 36488 | 4626 |
10 | Locked | 41 | 40451 | 4340 |
11 | Locked | 41 | 44186 | 4535 |
12 | Locked | 40 | 55136 | 5190 |
13 | Locked | 41 | 57649 | 4754 |
14 | Locked | 41 | 39950 | 2888 |
15 | Locked | 40 | 28745 | 1917 |
16 | Locked | 40 | 20060 | 1425 |
17 | Locked | 40 | 15513 | 1380 |
18 | Locked | 40 | 26602 | 2484 |
19 | Locked | 40 | 61516 | 2118 |
20 | Locked | 39 | 77895 | 3123 |
21 | Locked | 39 | 58771 | 1981 |
22 | Locked | 39 | 19503 | 1097 |
23 | Locked | 39 | 7172 | 623 |
24 | Locked | 39 | 6228 | 543 |
25 | Locked | 39 | 7516 | 742 |
26 | Locked | 40 | 8344 | 1098 |
27 | Locked | 40 | 8950 | 1020 |
28 | Locked | 40 | 7655 | 802 |
29 | Locked | 40 | 5322 | 501 |
30 | Locked | 40 | 3980 | 290 |
31 | Locked | 40 | 3921 | 211 |
Upstream
0 | 49600000 | 47.8 | 5120 | QAM 64 | 1 |
1 | 43100000 | 47.8 | 5120 | QAM 64 | 2 |
2 | 36600000 | 47.8 | 5120 | QAM 64 | 3 |
3 | 30100000 | 47.3 | 5120 | QAM 64 | 4 |
4 | 23600000 | 46.8 | 5120 | QAM 64 | 5 |
0 | ATDMA | 0 | 0 | 0 | 0 |
1 | ATDMA | 0 | 0 | 0 | 2 |
2 | ATDMA | 0 | 0 | 0 | 1 |
3 | ATDMA | 0 | 0 | 0 | 0 |
4 | ATDMA | 0 | 0 | 0 | 0 |
10-12-2022 16:37:07 | warning | DBC-REQ Mismatch Between Calculated Value for P1.6hi Compared to CCAP Provided Value;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
10-12-2022 16:18:58 | critical | Received Response to Broadcast Maintenance Request, But no Unicast Maintenance opportunities received - T4 time out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
10-12-2022 04:00:54 | warning | DBC-REQ Mismatch Between Calculated Value for P1.6hi Compared to CCAP Provided Value;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
10-12-2022 03:54:48 | critical | Received Response to Broadcast Maintenance Request, But no Unicast Maintenance opportunities received - T4 time out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
10-12-2022 03:50:51 | warning | DBC-REQ Mismatch Between Calculated Value for P1.6hi Compared to CCAP Provided Value;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
10-12-2022 03:50:51 | notice | US profile assignment change. US Chan ID: 6; Previous Profile: 13; New Profile: 11 13.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
10-12-2022 03:50:47 | notice | REGISTRATION COMPLETE - Waiting for Operational status |
10-12-2022 03:50:42 | warning | Dynamic Range Window violation |
10-12-2022 03:50:42 | warning | RNG-RSP CCAP Commanded Power Exceeds Value Corresponding to the Top of the DRW;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
10-12-2022 03:50:41 | warning | REG-RSP-MP Mismatch Between Calculated Value for P1.6hi Compared to CCAP Provided Value;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
10-12-2022 03:50:35 | notice | DS profile assignment change. DS Chan ID: 32; Previous Profile: ; New Profile: 1 2 3.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
10-12-2022 03:50:34 | notice | TLV-11 - unrecognized OID;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
10-12-2022 03:50:22 | warning | DHCP WARNING - Non-critical field invalid in response ;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
10-12-2022 03:50:19 | notice | Honoring MDD; IP provisioning mode = IPv4 |
10-12-2022 03:50:04 | critical | Started Unicast Maintenance Ranging - No Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
10-12-2022 03:50:04 | critical | No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
10-12-2022 03:49:43 | critical | Received Response to Broadcast Maintenance Request, But no Unicast Maintenance opportunities received - T4 time out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
09-12-2022 16:28:09 | warning | RNG-RSP CCAP Commanded Power Exceeds Value Corresponding to the Top of the DRW;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
09-12-2022 16:28:09 | warning | Dynamic Range Window violation |
09-12-2022 13:37:25 | critical | 16 consecutive T3 timeouts while trying to range on upstream channel 3;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
09-12-2022 13:37:25 | critical | Started Unicast Maintenance Ranging - No Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
09-12-2022 13:37:25 | critical | Unicast Maintenance Ranging attempted - No response - Retries exhausted;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
09-12-2022 13:35:45 | critical | 16 consecutive T3 timeouts while trying to range on upstream channel 4;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
09-12-2022 13:35:45 | critical | Unicast Maintenance Ranging attempted - No response - Retries exhausted;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
09-12-2022 13:28:07 | critical | Started Unicast Maintenance Ranging - No Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
09-12-2022 13:25:46 | warning | RNG-RSP CCAP Commanded Power Exceeds Value Corresponding to the Top of the DRW;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
09-12-2022 13:25:46 | warning | Dynamic Range Window violation |
09-12-2022 13:14:07 | warning | Dynamic Range Window violation |
09-12-2022 13:14:07 | warning | RNG-RSP CCAP Commanded Power Exceeds Value Corresponding to the Top of the DRW;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
09-12-2022 11:47:16 | critical | Received Response to Broadcast Maintenance Request, But no Unicast Maintenance opportunities received - T4 time out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
on 08-03-2023 15:40
Hey Cyborgmatt, thanks for posting with your updates and sorry to see your issue has only gotten worse.
Since we can see you're already in touch via PM with Natalie, she will be able to follow up on those and discuss the issue further in private so to help.
Please, rest assured we will be able to assist either by replacing the hub or providing the most appropriate resolution depending on our diagnostics and findings.
You can keep us here posted too once you've received further support as we'll be glad to know it's been taken care of.
Let us know here of any questions or concerns you may have in regard to the above and we're eager to advise further.
on 10-05-2023 17:53
Hello Adri, unfortunately, I still haven't heard back from any of my PMs.
Is it possible to follow up with someone else as I'm still having connection issues?
on 16-06-2023 01:52
Hi I have hub 5 I upgraded on 5th may since then my wifi is slow cuts of so does my tv services my land line csnt make or receive calls this has been going on since 5th may I have complained over 2pl0 times nothing getting done I've rebooted hub ect I want compensation and my services fixed I am going to go further to onbudsman and trading standards no one gets back to me they email tell me yo call then how can I with landline kit working
16-06-2023 07:25 - edited 16-06-2023 07:27
@Liamdoc081 wrote:Hi I have hub 5 I upgraded on 5th may since then my wifi is slow cuts of so does my tv services my land line csnt make or receive calls this has been going on since 5th may I have complained over 2pl0 times nothing getting done I've rebooted hub ect I want compensation and my services fixed I am going to go further to onbudsman and trading standards no one gets back to me they email tell me yo call then how can I with landline kit working
Multi-post query in addition to a unique topic on the 'Quick Start' forum
on 18-06-2023 15:25
Hi Liamdoc081, thanks for the message and welcome back to the forums.
I am sorry to hear that there is an issue with the connection and we would ask that you set up a BQM here and let us know the results.
Can you also run a speed test with Sam Knows please?
Kind regards, Chris.
