on 06-12-2022 20:05
I’ve just installed my new Hub 5, Wi-Fi is fine but none of the Ethernet ports seem to work, no on demand TV and games console only via Wi-Fi.
Everything was fine on Hub 4 ??
Answered! Go to Answer
on 27-08-2023 13:55
Hi @JonBx,
Thanks for your post.
We're sorry to hear this.
Can you confirm if you've tested this using an alternative cable and/or device to see if the issue persists?
on 27-08-2023 16:21
Virgin sent me a new hub and my problem has gone away. Obviously the hub was faulty. I think there is something else going on with hub 5 that will become apparent over time but so far so good. I think it’s important to remember that at speeds of 1 gig, Ethernet is pretty much redundant unless connecting old Ethernet only devices (hive and a network server in my case) and leave everything else to WiFi ..
on 08-09-2023 15:37
Ok…. problems continued with new hub and system required pin hole reset every other day. Engineer attended yesterday only to find that a splitter had been installed back to front by the engineer who installed the hub 5 and tv box. I have had 3 weeks of problematic and constantly crashing WiFi due to this error. Does VM offer compensation for such instances?
on 10-09-2023 15:43
Hi @JonBx,
Thank you for the update on the situation, and I'm sorry to hear that this has happened. Was the engineer who visited recently able to resolve this by moving the splitter?
In regards to a credit, you can find our policy here.
