on 06-12-2022 20:05
I’ve just installed my new Hub 5, Wi-Fi is fine but none of the Ethernet ports seem to work, no on demand TV and games console only via Wi-Fi.
Everything was fine on Hub 4 ??
Answered! Go to Answer
on 06-12-2022 20:06
@TShock wrote:I’ve just installed my new Hub 5, Wi-Fi is fine but none of the Ethernet ports seem to work, no on demand TV and games console only via Wi-Fi.
Sounds faulty.
It has been reported a few times on here.
on 06-12-2022 20:06
Sounds faulty.
on 06-12-2022 20:10
Yeah seen the comments , not good as I’ve returned hub 4☹️
on 06-12-2022 20:11
Everything was fine on Hub 4 ??Sounds faulty.
Probably it is, but the first thing they will ask you to do is to completely factory reset the hub (ie, stick a bent paperclip in the reset hole on the back and hold it in (you will feel a click as the micro switch is depressed) for a good 60 seconds and just let the hub reboot itself). It is not impossible that you have been sent a second hand / reconditioned hub and it might be somewhat ‘messed up’ A factory reset will sort that out, although I’m not overly hopeful, it is a necessary step to go through.
on 06-12-2022 20:25
Thanks just tried and still the same, love a upgrade😂
on 09-12-2022 12:37
Hi there TShock, thanks for your posts and replies on our help forum recently.
We're sorry to hear of the issue with the ports not working on the new hub 5 we fitted, could you please let us know if the issue is present on one or more ethernet ports and whether you've tested this using an alternative cable and/or device to see if the issue persists?
Please, let us know if you've had any updates or managed to restore this issue since your last post here back on Tuesday?
Happy to help you.
on 24-08-2023 09:51
I have this problem too! No Ethernet ports working.. Engineer was aware of this when he installed hub yesterday and tried to blame one of my cables! Pin hole reset works until Ethernet port is plugged in. Even the virgin tv box can’t use Ethernet!
24-08-2023 10:47 - edited 24-08-2023 10:50
@JonBx wrote:I have this problem too! No Ethernet ports working.. Engineer was aware of this when he installed hub yesterday and tried to blame one of my cables! Pin hole reset works until Ethernet port is plugged in. Even the virgin tv box can’t use Ethernet!
If VM are going to start blaming Ethernet maybe they should sell them like they do with Coax if we are getting to this stage.
likely a 2nd hand hub that has problems and not tested by VM
on 24-08-2023 10:54
Same for me… installed yesterday and engineer left me with it crashing every time I attempted to connect Ethernet.. worked fine with hub 3. Pin hole reset fails again as soon as an Ethernet connection made.
on 24-08-2023 12:08
On the off chance you have crossover cables and the hub not liking them could it be that?
