on 04-03-2021 11:35
I have a TP-Link Deco mesh WiFi system at home so I have disabled the WiFi on my Hub3, however recently I noticed I kept getting performance issues on my mesh network.
I logged back into my hub3 to find the WiFi had been switched back on, which I assumed must have happened since the email that came out saying Virgin had improved WiFi. I disabled the WiFi again and went about my business, only to find sometime later I was getting issues. I logged back into the Hub3 and WiFi was back on.
As a test I disabled WiFi but left the page open in my browser and periodically refreshed the page, and it seems it takes about 10 minutes before it ends up enabled again.
Does anyone have any ideas or has seen this before? I can't say when it started but I'm pretty sure this has only started up since I got the email about the router update for improved WiFi
on 21-05-2021 10:04
Hi @ynotchat,
Thank you for your posts and welcome to our community forums. We're here to help.
I'm sorry to hear you had this problem. However, from what I understand in your latest post, you've now been able to address and resolve this. Is that correct?
If you need any further assistance, please do let us know.
on 29-06-2021 13:29
I also have this issue. I would like to retain the other Ethernet ports but every time I switch off the wireless signal it is re-enabled shortly afterwards.
I have toggled to Opt out of Virgin Media WiFi in my profile.
Does anyone know what can be done?
on 29-06-2021 14:03
Hi @cirspsi
Thank you for your post, sorry to hear that you are also experiencing an issue with WiFi connections being re-enabled.
Have you tried following the steps here to turn it off?
https://www.virginmedia.com/help/virgin-media-hub-turn-off-wireless
Please do let me know how you get on,
Best wishes,
Serena
on 29-06-2021 15:58
Yes, I have followed those instructions multiple times. Just repeated, confirmed it was switched off and sure enough it re-enabled after 15 minutes.
on 29-06-2021 16:11
Thanks for letting me know @cirspsi
Can you please try performing a Pin Hole reset on your Hub for me, this will restore the Hub to factory settings but it may prevent the Hub from re-enabling the WiFi.
To perform the Pin Hole reset, please follow these exact instructions:
Disconnect all unneeded ethernet cables from the rear of the Hub.
With the Hub Powered on use a paperclip or similar (I use a mobile phone SIM Slot tool) and do a pinhole reset.
DO NOT reboot the hub but allow it 5 to 10 minutes for it to boot itself up.
Please do let me know how you get on after this, thanks.
Serena
on 30-06-2021 11:34
Reset performed, WiFi disabled but unfortunately it is still re-enabling.
on 30-06-2021 11:44
@cirspsi wrote:Reset performed, WiFi disabled but unfortunately it is still re-enabling.
It's a bug - Use your own router and put the hub in modem mode!
You'll be much saner!
on 30-06-2021 15:51
Hi @cirspsi,
Sorry to hear this hasn't improved following the pin-hole reset.
I've tried running checks on your equipment from our end but currently there is an outage in your area that is affecting things. The details on this are:
Fault ref. F008150408
Estimated Fix Date: 06th JULY 2021 13:00
Whilst it's not guaranteed this is causing the issues you're having with the WiFi, it makes it difficult to diagnose other issues that might be at play currently.
Please let us know following this how you are getting on and we'd be happy to assist further.
Kind regards,
on 07-07-2021 15:42
Hi @Molly_G,
I tried this again today and after disabling my Wi-Fi signals the device re-enabled them shortly after.
on 07-07-2021 16:37
Hi cirspsi,
Thank you for coming back to me, have you tried putting our router in Modem mode rather than just turning WIFI off?
Paul.
