on 25-06-2023 22:36
Just arrived in Fuertaventura and I can't get a mobile signal on my Virgin mobile.
Tried rebooting, checked Roaming is enabled. Fortunately my standby EE SIM works perfectly.
What do I need to do.?
on 26-06-2023 08:51
Hi @Buttshill.
Apologies you are having issues in Fuerteventura with your mobile signal. In order to assist you further we would have to bring you into a private message so that we can gain access to your account. Please look out for the envelope on the top right of your screen or if you are on a mobile device it will be located under your profile icon.
Please ensure that you have your devices connected to local WiFi for use.
Sabrina
on 26-06-2023 12:17
Hello, what happened to the communications
on 26-06-2023 12:58
Hi there.
Apologies, I have been in meetings and such. Did you get my previous message requesting Julie to confirm Data Protection details?
Sabrina
on 26-06-2023 13:30
Hi, yes. How do we set up a live chat
on 26-06-2023 13:47
Hi John.
You can go on the Virgin Media website and a chat box will appear with a bot asking questions to get you through to the right live agent who can assist you. I can assist via a webchat on this end also.
The choice is entirely up to you.
Sabrina
on 26-06-2023 14:31
Just contacted customer support and they say my roaming was switched off. Now switched on and waiting 24 hrs.
Sabrina many thanks.
on 26-06-2023 14:32
Hey John.
Fantastic news. Thanks for the update. I will keep this conversation open for another 24hours.
Sarbina
