09-01-2024 21:38 - edited 09-01-2024 21:43
hi keep getting cut off my downstream power levels look a little high some said 0 be best
hub 5 in modem mode 1gb with 3x tv boxes
3.0 Downstream channels
1 | 331000000 | 9.1 | 39 | QAM 256 | 25 |
2 | 139000000 | 9 | 39 | QAM 256 | 1 |
3 | 147000000 | 8.8 | 39 | QAM 256 | 2 |
4 | 155000000 | 8.7 | 39 | QAM 256 | 3 |
5 | 163000000 | 8.7 | 39 | QAM 256 | 4 |
6 | 171000000 | 8.5 | 39 | QAM 256 | 5 |
7 | 179000000 | 8.2 | 39 | QAM 256 | 6 |
8 | 187000000 | 8.1 | 39 | QAM 256 | 7 |
9 | 195000000 | 8.2 | 39 | QAM 256 | 8 |
10 | 203000000 | 8.3 | 39 | QAM 256 | 9 |
11 | 211000000 | 8.4 | 39 | QAM 256 | 10 |
12 | 219000000 | 8.3 | 39 | QAM 256 | 11 |
13 | 227000000 | 8.3 | 39 | QAM 256 | 12 |
14 | 235000000 | 8 | 39 | QAM 256 | 13 |
15 | 243000000 | 8 | 39 | QAM 256 | 14 |
16 | 251000000 | 7.8 | 39 | QAM 256 | 15 |
17 | 259000000 | 7.6 | 39 | QAM 256 | 16 |
18 | 267000000 | 7.5 | 39 | QAM 256 | 17 |
19 | 275000000 | 7.3 | 39 | QAM 256 | 18 |
20 | 283000000 | 7.4 | 39 | QAM 256 | 19 |
21 | 291000000 | 7.2 | 39 | QAM 256 | 20 |
22 | 299000000 | 7.3 | 39 | QAM 256 | 21 |
23 | 307000000 | 7.9 | 39 | QAM 256 | 22 |
24 | 315000000 | 8.3 | 39 | QAM 256 | 23 |
25 | 323000000 | 8.9 | 39 | QAM 256 | 24 |
26 | 339000000 | 9.5 | 39 | QAM 256 | 26 |
27 | 347000000 | 9.7 | 39 | QAM 256 | 27 |
28 | 355000000 | 9.7 | 39 | QAM 256 | 28 |
29 | 363000000 | 10 | 39 | QAM 256 | 29 |
30 | 371000000 | 10.1 | 39 | QAM 256 | 30 |
31 | 379000000 | 10.2 | 40 | QAM 256 | 31 |
1 | Locked | 39 | 185756 | 7534 |
2 | Locked | 39 | 406097 | 8942 |
3 | Locked | 39 | 689450 | 13127 |
4 | Locked | 39 | 572993 | 12961 |
5 | Locked | 39 | 670247 | 15338 |
6 | Locked | 39 | 462995 | 12219 |
7 | Locked | 39 | 81650 | 11337 |
8 | Locked | 39 | 70756 | 10254 |
9 | Locked | 39 | 59185 | 9701 |
10 | Locked | 39 | 54301 | 9261 |
11 | Locked | 39 | 9009 | 8709 |
12 | Locked | 39 | 48683 | 8382 |
13 | Locked | 39 | 11107 | 8942 |
14 | Locked | 39 | 8805 | 7622 |
15 | Locked | 39 | 6074 | 7524 |
16 | Locked | 39 | 6155 | 8287 |
17 | Locked | 39 | 38296 | 6693 |
18 | Locked | 39 | 77330 | 9225 |
19 | Locked | 39 | 5831 | 7825 |
20 | Locked | 39 | 5523 | 5791 |
21 | Locked | 39 | 30478 | 732 |
22 | Locked | 39 | 1942 | 2525 |
23 | Locked | 39 | 30679 | 6838 |
24 | Locked | 39 | 12672 | 7719 |
25 | Locked | 39 | 5005 | 5588 |
26 | Locked | 39 | 5133 | 5608 |
27 | Locked | 39 | 7451 | 5428 |
28 | Locked | 39 | 10450 | 5164 |
29 | Locked | 39 | 5992 | 4945 |
30 | Locked | 39 | 4454 | 4781 |
31 | Locked | 40 | 4531 | 4510 |
3.1 Downstream channels
159 | 94 | 4K | 1840 | QAM 4096 | 1108 |
159 | Locked | 41 | 8.1 | 1170166687 | 2475 |
3.0 Upstream channels
0 | 49600000 | 44 | 5120 | QAM 64 | 1 |
1 | 43100000 | 44 | 5120 | QAM 64 | 2 |
2 | 36600000 | 44 | 5120 | QAM 64 | 3 |
3 | 30100000 | 44 | 5120 | QAM 64 | 4 |
4 | 23600000 | 43.8 | 5120 | QAM 64 | 5 |
0 | ATDMA | 0 | 29 | 25 | 0 |
1 | ATDMA | 0 | 29 | 29 | 0 |
2 | ATDMA | 0 | 29 | 16 | 0 |
3 | ATDMA | 0 | 29 | 18 | 0 |
4 | ATDMA | 0 | 29 | 34 | 0 |
3.1 Upstream channels
6 | 10 | 37.5 | 2K | QAM 256 |
6 | OFDMA | 200 | 74000000 | 6 | 0 |
on 17-02-2024 16:56
power levels with attenuator removed
1 | 331000000 | 8 | 39 | QAM 256 | 25 |
2 | 139000000 | 8.5 | 39 | QAM 256 | 1 |
3 | 147000000 | 8.3 | 39 | QAM 256 | 2 |
4 | 155000000 | 8.2 | 39 | QAM 256 | 3 |
5 | 163000000 | 8.2 | 39 | QAM 256 | 4 |
6 | 171000000 | 7.9 | 39 | QAM 256 | 5 |
7 | 179000000 | 7.7 | 39 | QAM 256 | 6 |
8 | 187000000 | 7.5 | 39 | QAM 256 | 7 |
9 | 195000000 | 7.6 | 39 | QAM 256 | 8 |
10 | 203000000 | 7.6 | 39 | QAM 256 | 9 |
11 | 211000000 | 7.7 | 39 | QAM 256 | 10 |
12 | 219000000 | 7.6 | 39 | QAM 256 | 11 |
13 | 227000000 | 7.6 | 39 | QAM 256 | 12 |
14 | 235000000 | 7.3 | 39 | QAM 256 | 13 |
15 | 243000000 | 7.4 | 39 | QAM 256 | 14 |
16 | 251000000 | 7.1 | 39 | QAM 256 | 15 |
17 | 259000000 | 6.8 | 39 | QAM 256 | 16 |
18 | 267000000 | 6.6 | 39 | QAM 256 | 17 |
19 | 275000000 | 6.4 | 39 | QAM 256 | 18 |
20 | 283000000 | 6.5 | 39 | QAM 256 | 19 |
21 | 291000000 | 6.5 | 39 | QAM 256 | 20 |
22 | 299000000 | 6.6 | 39 | QAM 256 | 21 |
23 | 307000000 | 7.2 | 39 | QAM 256 | 22 |
24 | 315000000 | 7.4 | 39 | QAM 256 | 23 |
25 | 323000000 | 7.9 | 39 | QAM 256 | 24 |
26 | 339000000 | 8.4 | 39 | QAM 256 | 26 |
27 | 347000000 | 8.7 | 40 | QAM 256 | 27 |
28 | 355000000 | 8.7 | 40 | QAM 256 | 28 |
29 | 363000000 | 9 | 40 | QAM 256 | 29 |
30 | 371000000 | 9.1 | 40 | QAM 256 | 30 |
31 | 379000000 | 9.1 | 40 | QAM 256 | 31 |
32 | 387000000 | 9.2 | 40 | QAM 256 | 32 |
on 17-02-2024 16:57
0 | 49600000 | 46.5 | 5120 | QAM 64 | 1 |
1 | 43100000 | 46.5 | 5120 | QAM 64 | 2 |
2 | 36600000 | 46.8 | 5120 | QAM 64 | 3 |
3 | 30100000 | 46.8 | 5120 | QAM 64 | 4 |
4 | 23600000 | 46.3 | 5120 | QAM 64 | 5 |
on 18-02-2024 21:47
and the BQM?
on 18-02-2024 23:14
18feb
band/monitoring/quality/share/3473431eed5c056c591bf637f3b0e92a76518d92"><img alt="My Broadband Ping - 1gb" src="ht
18-02-2024 23:45 - edited 18-02-2024 23:49
Broadband Quality Monitor | thinkbroadband
after fixing your link you have some spikes not all the time but if you game at them time you have problems no real connection drop
what own router are you using?
are problems by wire or by wireless?
on 19-02-2024 22:04
own router asus gaming ax6000
wireless speeds good and wired speeds good
on 22-02-2024 12:25
I am sorry to hear this graham1705, is this only happening when you game?
What happens if you remove the asus gaming ax6000 do you see any difference or does it go worst?
What gaming are you doing, is it PC / console?
Matt - Forum Team
New around here?
on 27-02-2024 11:32
hi got a new problem geting a lot of of t3 timeout and t2 errors and loads off downstream erros
on 27-02-2024 11:35
1 | 331000000 | 7.8 | 39 | QAM 256 | 25 |
2 | 139000000 | 8 | 39 | QAM 256 | 1 |
3 | 147000000 | 7.8 | 39 | QAM 256 | 2 |
4 | 155000000 | 7.7 | 39 | QAM 256 | 3 |
5 | 163000000 | 7.7 | 39 | QAM 256 | 4 |
6 | 171000000 | 7.4 | 39 | QAM 256 | 5 |
7 | 179000000 | 7.2 | 39 | QAM 256 | 6 |
8 | 187000000 | 7 | 39 | QAM 256 | 7 |
9 | 195000000 | 7.2 | 39 | QAM 256 | 8 |
10 | 203000000 | 7.2 | 39 | QAM 256 | 9 |
11 | 211000000 | 7.3 | 39 | QAM 256 | 10 |
12 | 219000000 | 7.3 | 39 | QAM 256 | 11 |
13 | 227000000 | 7.2 | 39 | QAM 256 | 12 |
14 | 235000000 | 6.9 | 39 | QAM 256 | 13 |
15 | 243000000 | 6.9 | 39 | QAM 256 | 14 |
16 | 251000000 | 6.6 | 39 | QAM 256 | 15 |
17 | 259000000 | 6.4 | 39 | QAM 256 | 16 |
18 | 267000000 | 6.3 | 39 | QAM 256 | 17 |
19 | 275000000 | 6 | 39 | QAM 256 | 18 |
20 | 283000000 | 6.1 | 39 | QAM 256 | 19 |
21 | 291000000 | 5.9 | 39 | QAM 256 | 20 |
22 | 299000000 | 6 | 39 | QAM 256 | 21 |
23 | 307000000 | 6.7 | 39 | QAM 256 | 22 |
24 | 315000000 | 7 | 39 | QAM 256 | 23 |
25 | 323000000 | 7.6 | 39 | QAM 256 | 24 |
26 | 339000000 | 8.1 | 39 | QAM 256 | 26 |
27 | 347000000 | 8.4 | 39 | QAM 256 | 27 |
28 | 355000000 | 8.4 | 39 | QAM 256 | 28 |
29 | 363000000 | 8.8 | 39 | QAM 256 | 29 |
30 | 371000000 | 8.9 | 39 | QAM 256 | 30 |
31 | 379000000 | 8.9 | 39 | QAM 256 | 31 |
32 | 387000000 | 9.1 | 40 | QAM 256 | 32 |
1 | Locked | 39 | 95419 | 1934 |
2 | Locked | 39 | 24774 | 5476 |
3 | Locked | 39 | 142726 | 43113 |
4 | Locked | 39 | 692479 | 48264 |
5 | Locked | 39 | 324276 | 6609 |
6 | Locked | 39 | 344952 | 32481 |
7 | Locked | 39 | 304952 | 10585 |
8 | Locked | 39 | 183555 | 8382 |
9 | Locked | 39 | 239171 | 6982 |
10 | Locked | 39 | 36084 | 9592 |
11 | Locked | 39 | 30912 | 2877 |
12 | Locked | 39 | 89241 | 7066 |
13 | Locked | 39 | 33157 | 6076 |
14 | Locked | 39 | 29252 | 3186 |
15 | Locked | 39 | 25858 | 3042 |
16 | Locked | 39 | 23758 | 3205 |
17 | Locked | 39 | 47921 | 7074 |
18 | Locked | 39 | 20386 | 5397 |
19 | Locked | 39 | 17657 | 4755 |
20 | Locked | 39 | 8480 | 4688 |
21 | Locked | 39 | 6621 | 2722 |
22 | Locked | 39 | 18160 | 6410 |
23 | Locked | 39 | 26643 | 2978 |
24 | Locked | 39 | 9576 | 6468 |
25 | Locked | 39 | 26918 | 5577 |
26 | Locked | 39 | 26964 | 3208 |
27 | Locked | 39 | 5239 | 2704 |
28 | Locked | 39 | 25556 | 5011 |
29 | Locked | 39 | 7833 | 5875 |
30 | Locked | 39 | 20846 | 3928 |
31 | Locked | 39 | 13608 | 3432 |
32 | Locked | 40 | 11986 | 5692 |
159 | Locked | 41 | 6.7 | 1940985528 | 7838 |
on 27-02-2024 11:35
0 | 49600000 | 46 | 5120 | QAM 64 | 1 |
1 | 43100000 | 46 | 5120 | QAM 64 | 2 |
2 | 36600000 | 46 | 5120 | QAM 64 | 3 |
3 | 30100000 | 46 | 5120 | QAM 64 | 4 |
4 | 23600000 | 45.5 | 5120 | QAM 64 | 5 |
0 | ATDMA | 0 | 8 | 18 | 0 |
1 | ATDMA | 0 | 8 | 16 | 1 |
2 | ATDMA | 0 | 8 | 14 | 1 |
3 | ATDMA | 0 | 8 | 16 | 1 |
4 | ATDMA | 0 | 8 | 14 | 1 |
6 | 10 | 39.7 | 2K | QAM 256 |
6 | OFDMA | 200 | 74000000 | 0 | 0 |
