on 15-07-2023 12:36
I'm in Area 26 - status checker says I have no issues in the area, but when I do a line check it says there's an intermittent connection issue in the area and to check back in 24hrs.
It's deffo not my router as nothing has changed (using a Unifi Dream Machine with the SH5 in modem mode).
on 16-07-2023 02:27
What is being reported on the “free & automated” Service Status number - 0800 561 0061 - which usually gives the most up to date info. and tells you of more local issues down to street cab/ postcode level.
The "compensation "timer" can also be started on this number if appropriate.
on 16-07-2023 10:19
3 Mb/s on upstream is going to be a service fault & it likely affects all the folks in your street.
16-07-2023 21:43 - edited 16-07-2023 21:46
@WildWayz wrote:
remember to eat your greens😱
you should test a PC to the hub in modem mode
16-07-2023 22:33 - edited 16-07-2023 22:38
It looks like it has cleared up as of this morning:
