06-09-2023 18:00 - edited 06-09-2023 18:08
Hi all,
I have been using Superhub 5 in modem mode for the past 1 year or so, and everything has been working great. However, my internet connection has been going down for the past few days. When the connection goes down, the status light on the hub stays steady green. I have to reboot SH5 to get it working. I have also done a full reset on the hub, but it is still the same. It has come to the point that we have lost internet several times today. I have checked the sub status, and here are the power levels and details:
Item Status Comments
Acquired Downstream Channel(Hz) | 331000000 | Locked |
Ranged Upstream Channel(Hz) | 0 | Failed |
Provisioning State | Online | Operational |
1 | 331000000 | 6.7 | 44 | QAM 256 | 25 |
2 | 139000000 | 9.1 | 44 | QAM 256 | 1 |
3 | 147000000 | 8.9 | 45 | QAM 256 | 2 |
4 | 155000000 | 9 | 44 | QAM 256 | 3 |
5 | 163000000 | 8.8 | 44 | QAM 256 | 4 |
6 | 171000000 | 8.6 | 45 | QAM 256 | 5 |
7 | 179000000 | 8.7 | 45 | QAM 256 | 6 |
8 | 187000000 | 8.8 | 45 | QAM 256 | 7 |
9 | 195000000 | 8.8 | 45 | QAM 256 | 8 |
10 | 203000000 | 8.5 | 45 | QAM 256 | 9 |
11 | 211000000 | 8.8 | 45 | QAM 256 | 10 |
12 | 219000000 | 8.9 | 45 | QAM 256 | 11 |
13 | 227000000 | 8.4 | 44 | QAM 256 | 12 |
14 | 235000000 | 8.2 | 45 | QAM 256 | 13 |
15 | 243000000 | 8.1 | 44 | QAM 256 | 14 |
16 | 251000000 | 7.9 | 44 | QAM 256 | 15 |
17 | 259000000 | 7.8 | 44 | QAM 256 | 16 |
18 | 267000000 | 7.8 | 44 | QAM 256 | 17 |
19 | 275000000 | 8 | 44 | QAM 256 | 18 |
20 | 283000000 | 7.8 | 44 | QAM 256 | 19 |
21 | 291000000 | 7.6 | 44 | QAM 256 | 20 |
22 | 299000000 | 7.5 | 44 | QAM 256 | 21 |
23 | 307000000 | 7.5 | 44 | QAM 256 | 22 |
24 | 315000000 | 7.1 | 44 | QAM 256 | 23 |
25 | 323000000 | 6.8 | 44 | QAM 256 | 24 |
26 | 339000000 | 6.8 | 44 | QAM 256 | 26 |
27 | 347000000 | 6.8 | 44 | QAM 256 | 27 |
28 | 355000000 | 6.8 | 44 | QAM 256 | 28 |
29 | 363000000 | 6.9 | 44 | QAM 256 | 29 |
30 | 371000000 | 6.7 | 44 | QAM 256 | 30 |
31 | 379000000 | 6.5 | 44 | QAM 256 | 31 |
1 | Locked | 44 | 0 | 0 |
2 | Locked | 44 | 0 | 0 |
3 | Locked | 45 | 0 | 0 |
4 | Locked | 44 | 0 | 0 |
5 | Locked | 44 | 0 | 0 |
6 | Locked | 45 | 0 | 0 |
7 | Locked | 45 | 0 | 0 |
8 | Locked | 45 | 0 | 0 |
9 | Locked | 45 | 0 | 0 |
10 | Locked | 45 | 0 | 0 |
11 | Locked | 45 | 0 | 0 |
12 | Locked | 45 | 0 | 0 |
13 | Locked | 44 | 0 | 0 |
14 | Locked | 45 | 0 | 0 |
15 | Locked | 44 | 0 | 0 |
16 | Locked | 44 | 0 | 0 |
17 | Locked | 44 | 0 | 0 |
18 | Locked | 44 | 0 | 0 |
19 | Locked | 44 | 0 | 0 |
20 | Locked | 44 | 0 | 0 |
21 | Locked | 44 | 0 | 0 |
22 | Locked | 44 | 0 | 0 |
23 | Locked | 44 | 0 | 0 |
24 | Locked | 44 | 0 | 0 |
25 | Locked | 44 | 0 | 0 |
26 | Locked | 44 | 0 | 0 |
27 | Locked | 44 | 0 | 0 |
28 | Locked | 44 | 0 | 0 |
29 | Locked | 44 | 0 | 0 |
30 | Locked | 44 | 0 | 0 |
31 | Locked | 44 | 0 | 0 |
Not Available |
Not Available |
General Configuration
Allowed |
1 |
Enabled |
3.1 |
ldJKDHSUBsgvca69834ncxv98 |
126 |
402500089 bps |
42600bytes |
0 bps |
Primary Upstream Service Flow
125 |
38500089 bps |
42600bytes |
0 bps |
42600bytes |
Best Effort |
06-09-2023 18:54:58 | notice | US profile assignment change. US Chan ID: 6; Previous Profile: 13; New Profile: 11 13.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
06-09-2023 18:54:58 | warning | DBC-REQ Mismatch Between Calculated Value for P1.6hi Compared to CCAP Provided Value;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
06-09-2023 18:54:55 | warning | REG-RSP-MP Mismatch Between Calculated Value for P1.6hi Compared to CCAP Provided Value;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
06-09-2023 18:54:55 | notice | REGISTRATION COMPLETE - Waiting for Operational status |
06-09-2023 18:54:49 | notice | DS profile assignment change. DS Chan ID: 32; Previous Profile: ; New Profile: 1 2 3.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
06-09-2023 18:54:46 | notice | TLV-11 - unrecognized OID;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
06-09-2023 18:54:44 | warning | DHCP WARNING - Non-critical field invalid in response ;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
06-09-2023 18:54:42 | notice | Honoring MDD; IP provisioning mode = IPv4 |
06-09-2023 18:54:38 | critical | SYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing;;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
06-09-2023 18:54:22 | critical | Cable Modem Reboot due to power button reset |
06-09-2023 12:17:26 | critical | SYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing;;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
06-09-2023 12:17:09 | critical | Cable Modem Reboot due to power button reset |
06-09-2023 12:14:41 | critical | SYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
04-09-2023 23:54:03 | critical | SYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing;;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
04-09-2023 23:53:46 | critical | Cable Modem Reboot via RG reboot command |
04-09-2023 23:44:06 | critical | SYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing;;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
04-09-2023 23:43:54 | critical | Cable Modem Reboot via RG reboot command |
04-09-2023 23:41:07 | critical | SYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing;;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
04-09-2023 23:40:55 | critical | Cable Modem reset to Factory Default via reset button |
Can i get some advice please? It seems that there is no data for upstream channels. Is this normal?
on 08-09-2023 18:23
Hi, umzyi99.
Thanks for reaching our to our help forums and sorry to see you've been having issues with your hub and connection recently, we'd love to best assist with this.
Could you please tell us how things look since you posted here and have you spoken to our faults team about this to see if we need to send a tech or replace your equipment?
Let us know and we'll be eager to support you.
