on 14-05-2024 09:16
Hello,
Recently my VM connection has been dropping out every now and then. It only drops out very shortly but it’s obviously not ideal. This never used to happen.
I’ve reset the router twice which seemed to fix the issue temporarily, but I shouldn’t need to keep doing this.
tried to speak with VM support but it’s impossible to just get an engineer out.
Anyone able to assist on how to just organise an engineer? I pay a lot for my service and don’t need the hassle of speaking with someone for an hour to get one booked.
thanks
on 14-05-2024 09:59
Could you please provide the downstream, upstream and network logs?
To get these - go to 192.168.0.1 (or 192.168.100.1 if in modern mode) and click “Check Router Status’
There’s the forum team here - but they can take a few days to respond (and sometimes ignore clear issues)
on 14-05-2024 11:44
Thanks, I'm on the router page now but can't seem to find an option to export the Downstream, Upstream. The Network Logs don't load. I've attached a snip of the Status.
14-05-2024 12:00 - edited 14-05-2024 12:04
Got a little further after a reboot through web console. I'm seeing these critical messages from the last few days in the network log: This could just be extra noise for all I know. Have blanked out MAC.
14-05-2024 11:56:12 | notice | GUI Login Status - Login Success from LAN interface |
14-05-2024 10:46:10 | notice | REGISTRATION COMPLETE - Waiting for Operational status |
14-05-2024 10:46:06 | notice | US profile assignment change. US Chan ID: 7; Previous Profile: 13; New Profile: 11 13.;CM-MAC=xxxxx;CMTS-MAC=xxxxxCM-QOS=1.1;CM-VER=3.1; |
14-05-2024 10:46:01 | notice | DS profile assignment change. DS Chan ID: 32; Previous Profile: ; New Profile: 1 2 3.;CM-MAC=xxxxxCMTS-MAC=xxxx;CM-QOS=1.1;CM-VER=3.1; |
14-05-2024 10:45:53 | warning | DHCP WARNING - Non-critical field invalid in response ;CM-MAC=xxxxxx35;CMTS-MAC=xxxxx;CM-QOS=1.1;CM-VER=3.1; |
14-05-2024 10:45:51 | notice | Honoring MDD; IP provisioning mode = IPv4 |
14-05-2024 10:45:28 | critical | SYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing;;CM-MAC=xxxx;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
14-05-2024 10:45:27 | critical | Cable Modem Reboot because of - unknown |
13-05-2024 14:08:48 | critical | 16 consecutive T3 timeouts while trying to range on upstream channel 8;CM-MAC=xxxxCMTS-MAC=xxxxx;CM-QOS=1.1;CM-VER=3.1; |
13-05-2024 14:08:48 | critical | Unicast Maintenance Ranging attempted - No response - Retries exhausted;CM-MAC=xxxxx;CMTS-MAC=xxxxx;CM-QOS=1.1;CM-VER=3.1; |
13-05-2024 14:07:40 | critical | Started Unicast Maintenance Ranging - No Response received - T3 time-out;CM-MAC=xxxxxx;CMTS-MAC=xxxxx;CM-QOS=1.1;CM-VER=3.1; |
11-05-2024 01:17:45 | critical | Started Unicast Maintenance Ranging - No Response received - T3 time-out;CM-MAC=xxxxxxCMTS-MAC=xxxxx;CM-QOS=1.1;CM-VER=3.1; |
05-05-2024 08:26:17 | critical | Started Unicast Maintenance Ranging - No Response received - T3 time-out;CM-MAC=xxxxx;CMTS-MAC=xxxxx;CM-QOS=1.1;CM-VER=3.1; |
02-05-2024 17:32:30 | critical | Cable Modem Reboot because of - Reboot Timezone Change |
02-05-2024 17:32:30 | critical | SYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing;;CM-MAC=xxxx;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
02-05-2024 17:29:17 | critical | SYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing;;CM-MAC=xxxxx;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
02-05-2024 17:29:17 | critical | Cable Modem Reboot because of - pin-reset |
on 14-05-2024 12:05
Downstream info:
3.0 Downstream channels
1 | 306000000 | 3.4 | 41 | QAM 256 | 22 |
2 | 146000000 | 6.1 | 40 | QAM 256 | 2 |
3 | 154000000 | 5.9 | 40 | QAM 256 | 3 |
4 | 162000000 | 5.5 | 40 | QAM 256 | 4 |
5 | 170000000 | 5.1 | 40 | QAM 256 | 5 |
6 | 178000000 | 4.8 | 40 | QAM 256 | 6 |
7 | 186000000 | 4.6 | 40 | QAM 256 | 7 |
8 | 194000000 | 4.6 | 40 | QAM 256 | 8 |
9 | 202000000 | 4.7 | 40 | QAM 256 | 9 |
10 | 210000000 | 4.8 | 40 | QAM 256 | 10 |
11 | 218000000 | 4.7 | 41 | QAM 256 | 11 |
12 | 226000000 | 4.4 | 41 | QAM 256 | 12 |
13 | 234000000 | 4.1 | 41 | QAM 256 | 13 |
14 | 242000000 | 4 | 41 | QAM 256 | 14 |
15 | 250000000 | 3.9 | 41 | QAM 256 | 15 |
16 | 258000000 | 4.1 | 41 | QAM 256 | 16 |
17 | 266000000 | 4.1 | 41 | QAM 256 | 17 |
18 | 274000000 | 4 | 41 | QAM 256 | 18 |
19 | 282000000 | 4 | 41 | QAM 256 | 19 |
20 | 290000000 | 4.2 | 41 | QAM 256 | 20 |
21 | 298000000 | 3.9 | 41 | QAM 256 | 21 |
22 | 314000000 | 3.3 | 41 | QAM 256 | 23 |
23 | 322000000 | 3.2 | 41 | QAM 256 | 24 |
24 | 330000000 | 3 | 41 | QAM 256 | 25 |
25 | 370000000 | 2.4 | 41 | QAM 256 | 26 |
26 | 378000000 | 2.1 | 41 | QAM 256 | 27 |
27 | 386000000 | 1.7 | 41 | QAM 256 | 28 |
28 | 394000000 | 1.5 | 41 | QAM 256 | 29 |
29 | 402000000 | 1.3 | 41 | QAM 256 | 30 |
30 | 410000000 | 1.6 | 41 | QAM 256 | 31 |
31 | 418000000 | 1.8 | 41 | QAM 256 | 32 |
1 | Locked | 41 | 0 | 0 |
2 | Locked | 40 | 0 | 0 |
3 | Locked | 40 | 0 | 0 |
4 | Locked | 40 | 0 | 0 |
5 | Locked | 40 | 0 | 0 |
6 | Locked | 40 | 0 | 0 |
7 | Locked | 40 | 0 | 0 |
8 | Locked | 40 | 0 | 0 |
9 | Locked | 40 | 0 | 0 |
10 | Locked | 40 | 0 | 0 |
11 | Locked | 41 | 0 | 0 |
12 | Locked | 41 | 0 | 0 |
13 | Locked | 41 | 0 | 0 |
14 | Locked | 41 | 0 | 0 |
15 | Locked | 41 | 0 | 0 |
16 | Locked | 41 | 0 | 0 |
17 | Locked | 41 | 0 | 0 |
18 | Locked | 41 | 0 | 0 |
19 | Locked | 41 | 0 | 0 |
20 | Locked | 41 | 0 | 0 |
21 | Locked | 41 | 0 | 0 |
22 | Locked | 41 | 0 | 0 |
23 | Locked | 41 | 0 | 0 |
24 | Locked | 41 | 0 | 0 |
25 | Locked | 41 | 0 | 0 |
26 | Locked | 41 | 1 | 0 |
27 | Locked | 41 | 0 | 0 |
28 | Locked | 41 | 0 | 0 |
29 | Locked | 41 | 0 | 0 |
30 | Locked | 41 | 1 | 0 |
31 | Locked | 41 | 0 | 0 |
3.1 Downstream channels
33 | 94 | 4K | 1840 | QAM 4096 | 1108 |
33 | Locked | 39 | -5.9 | 17385079 | 0 |
Upstream:
3.0 Upstream channels
0 | 49600000 | 39.5 | 5120 | QAM 64 | 1 |
1 | 43100000 | 39.5 | 5120 | QAM 64 | 2 |
2 | 36600000 | 39.3 | 5120 | QAM 64 | 3 |
3 | 30100000 | 38.8 | 5120 | QAM 64 | 4 |
4 | 23600000 | 38.5 | 5120 | QAM 64 | 5 |
0 | ATDMA | 0 | 0 | 0 | 0 |
1 | ATDMA | 0 | 0 | 0 | 0 |
2 | ATDMA | 0 | 0 | 0 | 0 |
3 | ATDMA | 0 | 0 | 0 | 0 |
4 | ATDMA | 0 | 0 | 0 | 0 |
3.1 Upstream channels
7 | 10.4 | 34.7 | 2K | QAM 256 |
7 | OFDMA | 208 | 74000000 | 0 | 0 |
on 14-05-2024 17:06
Looks like the router may have been forced to restart due to errors earlier, there was also 16 consecutive T3 errors yesterday (making it a T4 time out) - the Sync errors are also indicative of a problem.
This all needs investigation by a Virgin Engineer (if you wait a few days, the forum team will reach out). Could also contact the social media team on X/Facebook - this may be quicker.
on 15-05-2024 12:32
Thanks, I’ll wait for a forum admin!
on 17-05-2024 14:14
Hey mattcodling, thank you for reaching out and I am so sorry to see you've been having some connection issues.
Thank you posting all this information its been very helpful.
I am going to send you a DM to look into this.
Matt - Forum Team
New around here?
