on 15-05-2023 19:25
Hi, I am getting slow speeds, below are my logs, are these not normal readings?
25 | 331000000 | 0.4 | 40.4 | QAM256 | 25 |
1 | 139000000 | 8 | 40.4 | QAM256 | 1 |
2 | 147000000 | 7.9 | 40.4 | QAM256 | 2 |
3 | 155000000 | 7.5 | 40.4 | QAM256 | 3 |
4 | 163000000 | 6.6 | 40.4 | QAM256 | 4 |
5 | 171000000 | 5.8 | 40.9 | QAM256 | 5 |
6 | 179000000 | 5.5 | 40.9 | QAM256 | 6 |
7 | 187000000 | 5.2 | 40.9 | QAM256 | 7 |
8 | 195000000 | 4.8 | 40.9 | QAM256 | 8 |
9 | 203000000 | 4.5 | 40.9 | QAM256 | 9 |
10 | 211000000 | 4.2 | 40.9 | QAM256 | 10 |
11 | 219000000 | 4.1 | 40.9 | QAM256 | 11 |
12 | 227000000 | 3.9 | 40.4 | QAM256 | 12 |
13 | 235000000 | 3.7 | 40.9 | QAM256 | 13 |
14 | 243000000 | 3.4 | 40.9 | QAM256 | 14 |
15 | 251000000 | 2.9 | 40.4 | QAM256 | 15 |
16 | 259000000 | 3 | 40.4 | QAM256 | 16 |
17 | 267000000 | 2.9 | 40.9 | QAM256 | 17 |
18 | 275000000 | 2.8 | 40.4 | QAM256 | 18 |
19 | 283000000 | 3 | 40.4 | QAM256 | 19 |
20 | 291000000 | 2.8 | 40.9 | QAM256 | 20 |
21 | 299000000 | 2.5 | 40.4 | QAM256 | 21 |
22 | 307000000 | 1.9 | 40.4 | QAM256 | 22 |
23 | 315000000 | 1.1 | 40.4 | QAM256 | 23 |
24 | 323000000 | 0.7 | 40.4 | QAM256 | 24 |
26 | 339000000 | 0.3 | 40.4 | QAM256 | 26 |
27 | 347000000 | 0.1 | 40.9 | QAM256 | 27 |
28 | 355000000 | 0.1 | 40.4 | QAM256 | 28 |
29 | 363000000 | 0 | 40.4 | QAM256 | 29 |
30 | 371000000 | -0.2 | 40.9 | QAM256 | 30 |
31 | 379000000 | -0.4 | 40.4 | QAM256 | 31 |
25 | Locked | 40.366287 | 0 | 0 |
1 | Locked | 40.366287 | 0 | 0 |
2 | Locked | 40.366287 | 0 | 0 |
3 | Locked | 40.366287 | 0 | 0 |
4 | Locked | 40.366287 | 0 | 0 |
5 | Locked | 40.946209 | 0 | 0 |
6 | Locked | 40.946209 | 0 | 0 |
7 | Locked | 40.946209 | 0 | 0 |
8 | Locked | 40.946209 | 0 | 0 |
9 | Locked | 40.946209 | 0 | 0 |
10 | Locked | 40.946209 | 0 | 0 |
11 | Locked | 40.946209 | 0 | 0 |
12 | Locked | 40.366287 | 0 | 0 |
13 | Locked | 40.946209 | 0 | 0 |
14 | Locked | 40.946209 | 0 | 0 |
15 | Locked | 40.366287 | 0 | 0 |
16 | Locked | 40.366287 | 0 | 0 |
17 | Locked | 40.946209 | 0 | 0 |
18 | Locked | 40.366287 | 0 | 0 |
19 | Locked | 40.366287 | 0 | 0 |
20 | Locked | 40.946209 | 0 | 0 |
21 | Locked | 40.366287 | 0 | 0 |
22 | Locked | 40.366287 | 0 | 0 |
23 | Locked | 40.366287 | 0 | 0 |
24 | Locked | 40.366287 | 0 | 0 |
26 | Locked | 40.366287 | 0 | 0 |
27 | Locked | 40.946209 | 0 | 0 |
28 | Locked | 40.366287 | 0 | 0 |
29 | Locked | 40.366287 | 0 | 0 |
30 | Locked | 40.946209 | 0 | 0 |
31 | Locked | 40.366287 | 0 | 0 |
33 | 96 | 4K | 1840 | QAM4096 | 424 |
33 | Locked | 41 | -2.6 | 5127344 | 0 |
on 15-05-2023 19:26
1 | 36600000 | 46 | 5120 KSym/sec | QAM64 | 3 |
2 | 43100000 | 46.5 | 5120 KSym/sec | QAM64 | 2 |
3 | 30100000 | 46.8 | 5120 KSym/sec | QAM64 | 4 |
4 | 49600000 | 47.3 | 5120 KSym/sec | QAM64 | 1 |
5 | 23600000 | 46.3 | 5120 KSym/sec | QAM64 | 5 |
1 | ATDMA | 0 | 0 | 0 | 0 |
2 | ATDMA | 0 | 0 | 0 | 0 |
3 | ATDMA | 0 | 0 | 0 | 0 |
4 | ATDMA | 0 | 0 | 0 | 0 |
5 | ATDMA | 0 | 0 | 0 | 0 |
12 | 10.4 | 42.5 | 2K | QAM128 |
12 | OFDMA | 208 | 53.4 | 0 | 0 |
on 15-05-2023 19:26
Network access | true |
Maximum Number of CPEs | 1 |
Baseline Privacy | true |
DOCSIS Mode | 3.1 |
Config file | cmreg-vmdg640-bbt076-b.cm |
SFID | 151026 |
Max Traffic Rate | 1230000450 |
Max Traffic Burst | 42600 |
Min Traffic Rate | 0 |
SFID | 151025 |
Max Traffic Rate | 55000270 |
Max Concatenated Burst | 42600 |
Scheduling Type | bestEffort |
on 15-05-2023 19:26
Mon 15/05/2023 18:12:22 | 5 | MIMO Event MIMO: Stored MIMO=-1 post cfg file MIMO=-1;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
Thu 01/01/1970 00:01:22 | 3 | No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
Thu 01/01/1970 00:01:21 | 3 | Unicast Ranging Received Abort Response - initializing MAC;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
Sun 14/05/2023 20:34:50 | 6 | CM-STATUS message sent. Event Type Code: 16; Chan ID: 33; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: 3.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
Sun 14/05/2023 20:25:18 | 3 | No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
Sun 14/05/2023 18:52:40 | 6 | CM-STATUS message sent. Event Type Code: 16; Chan ID: 33; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: 3.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
Sun 14/05/2023 18:00:33 | 6 | US profile assignment change. US Chan ID: 12; Previous Profile: 12; New Profile: 11.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
Sun 14/05/2023 11:38:58 | 6 | CM-STATUS message sent. Event Type Code: 24; Chan ID: 33; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: 2.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
Sun 14/05/2023 07:13:39 | 4 | DHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
Sat 13/05/2023 11:20:23 | 3 | No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
on 15-05-2023 19:36
The power level range across your downstream channels is quite large (-0.4 to +8).
What does this site show?
https://samknows.com/realspeed/
on 16-05-2023 13:08
on 18-05-2023 13:36
Hi @captaincomedy,
Welcome back to our Community Forums! Thank you for your post and I'm sorry to see that you're having some slow speeds!
Have you taken a look at our Speed Up page to see if this can help improve your speeds at all?
Can you please confirm if your Hub is in Router Mode or Modem Mode? If your Hub is in Modem Mode, we wouldn't be able to see any issues as the Hub would be connected to a third party equipment that we do not support. If your Hub is in Modem Mode, please switch back to Router Mode for at least 24 hours so that we can view any issues with your speeds and connection and see if there's anything we can do to help going forward.
Keep us updated on how you get on.
Thank you. 😊
