on 09-03-2024 21:10
I have been having connection issues for the past few days but today has been extremely bad. Starting at around 8pm.
I had this issue a few weeks back which was posted on the forums in the gaming section which turned out to be my neighbour sharing our cable which resulted in them having to get a repull and their own cable installed which fixed my issues but here we are a few weeks later and the connection is even worse with the connection dropping every few minutes. I have checked the website and called the 0800 fault number and no issues reported in area.
I started a new BQM a few days ago to monitor the connection which has been showing random packet losses but just now its going crazy. Any help would be appreicated. I have already pin hole reset the router yesterday.
09/03/2024 (BQM)
08/03/2024 (BQM)
on 11-03-2024 12:02
Corrected errors on the downstream section seem to be mega high already. Guessing this is ok since they are fixed?
3.0 Downstream channels
1 | 331000000 | 6.4 | 41 | QAM 256 | 25 |
2 | 139000000 | 8.7 | 40 | QAM 256 | 1 |
3 | 147000000 | 8.7 | 40 | QAM 256 | 2 |
4 | 155000000 | 8.6 | 40 | QAM 256 | 3 |
5 | 163000000 | 8.4 | 40 | QAM 256 | 4 |
6 | 171000000 | 8.2 | 40 | QAM 256 | 5 |
7 | 179000000 | 8 | 40 | QAM 256 | 6 |
8 | 187000000 | 7.9 | 41 | QAM 256 | 7 |
9 | 195000000 | 8.2 | 41 | QAM 256 | 8 |
10 | 203000000 | 8.2 | 41 | QAM 256 | 9 |
11 | 227000000 | 8.1 | 41 | QAM 256 | 12 |
12 | 235000000 | 7.9 | 41 | QAM 256 | 13 |
13 | 259000000 | 7.1 | 41 | QAM 256 | 16 |
14 | 267000000 | 7 | 41 | QAM 256 | 17 |
15 | 291000000 | 6.9 | 41 | QAM 256 | 20 |
16 | 299000000 | 6.8 | 41 | QAM 256 | 21 |
17 | 323000000 | 6.5 | 41 | QAM 256 | 24 |
18 | 339000000 | 6.4 | 41 | QAM 256 | 26 |
19 | 347000000 | 6.4 | 41 | QAM 256 | 27 |
20 | 355000000 | 6.2 | 41 | QAM 256 | 28 |
21 | 363000000 | 6.3 | 41 | QAM 256 | 29 |
22 | 371000000 | 5.7 | 41 | QAM 256 | 30 |
23 | 379000000 | 4.8 | 41 | QAM 256 | 31 |
24 | 387000000 | 4.8 | 41 | QAM 256 | 32 |
25 | 395000000 | 4.7 | 41 | QAM 256 | 33 |
26 | 403000000 | 4.7 | 41 | QAM 256 | 34 |
27 | 411000000 | 4.7 | 41 | QAM 256 | 35 |
28 | 419000000 | 4.7 | 41 | QAM 256 | 36 |
29 | 427000000 | 5 | 41 | QAM 256 | 37 |
30 | 435000000 | 4.9 | 41 | QAM 256 | 38 |
31 | 443000000 | 5 | 41 | QAM 256 | 39 |
32 | 451000000 | 5.2 | 41 | QAM 256 | 40 |
1 | Locked | 41 | 0 | 0 |
2 | Locked | 40 | 0 | 0 |
3 | Locked | 40 | 0 | 0 |
4 | Locked | 40 | 0 | 0 |
5 | Locked | 40 | 0 | 0 |
6 | Locked | 40 | 0 | 0 |
7 | Locked | 40 | 0 | 0 |
8 | Locked | 41 | 0 | 0 |
9 | Locked | 41 | 0 | 0 |
10 | Locked | 41 | 0 | 0 |
11 | Locked | 41 | 0 | 0 |
12 | Locked | 41 | 0 | 0 |
13 | Locked | 41 | 0 | 0 |
14 | Locked | 41 | 0 | 0 |
15 | Locked | 41 | 0 | 0 |
16 | Locked | 41 | 0 | 0 |
17 | Locked | 41 | 0 | 0 |
18 | Locked | 41 | 0 | 0 |
19 | Locked | 41 | 0 | 0 |
20 | Locked | 41 | 0 | 0 |
21 | Locked | 41 | 0 | 0 |
22 | Locked | 41 | 0 | 0 |
23 | Locked | 41 | 0 | 0 |
24 | Locked | 41 | 0 | 0 |
25 | Locked | 41 | 0 | 0 |
26 | Locked | 41 | 0 | 0 |
27 | Locked | 41 | 0 | 0 |
28 | Locked | 41 | 0 | 0 |
29 | Locked | 41 | 0 | 0 |
30 | Locked | 41 | 0 | 0 |
31 | Locked | 41 | 0 | 0 |
32 | Locked | 41 | 0 | 0 |
3.1 Downstream channels
159 | 94 | 4K | 1840 | QAM 4096 | 1108 |
159 | Locked | 42 | 3.3 | 4612775 | 0 |
3.0 Upstream channels
0 | 49600000 | 47.8 | 5120 | QAM 64 | 1 |
1 | 43100000 | 47.3 | 5120 | QAM 64 | 2 |
2 | 36600000 | 46 | 5120 | QAM 64 | 3 |
3 | 30100000 | 45.8 | 5120 | QAM 64 | 4 |
4 | 23600000 | 45.5 | 5120 | QAM 64 | 5 |
0 | ATDMA | 0 | 0 | 0 | 0 |
1 | ATDMA | 0 | 0 | 0 | 0 |
2 | ATDMA | 0 | 0 | 0 | 0 |
3 | ATDMA | 0 | 0 | 0 | 0 |
4 | ATDMA | 0 | 0 | 0 | 0 |
3.1 Upstream channels
6 | 10 | 42.5 | 2K | QAM 256 |
6 | OFDMA | 200 | 74000000 | 0 | 0 |
on 11-03-2024 12:04
Service Status page currently when I run a test on the hub.
11-03-2024 12:08 - edited 11-03-2024 12:10
They look all 0's to me, except for the 3.1 channel that often has odd readings.
on 11-03-2024 12:21
Yeah this number was the one I was referring too. It seems to be increasing massively everytime I refresh?
For instance the number from taking that screenshot which was less than a minute ago to now its showing, 19018821
on 11-03-2024 12:54
I've never been able to make sense of that 3.1 reading, mine looks different every time too. It doesn't seem to correspond with any particular issues so I tend to ignore it. Other opinions welcome.
At least you've got a service. My VM broadband is down today.
on 12-03-2024 16:27
Factory reset the router earlier today as the service status page told me to do it again (3 times this week so far).
Once I reset the router it then advised I did have ongoing network issues and allowed me to book a tech which I haven't done as wanted someone from Virgin to confirm if a tech is 100% required.
Downstream 3.1 channel logging millions of corrected errors in a very short time also
159 | Locked | 42 | 2.9 | 97621396 | 0 |
12-03-2024 16:21:03 | notice | GUI Login Status - Login Success from LAN interface |
12-03-2024 15:53:14 | warning | DBC-REQ Mismatch Between Calculated Value for P1.6hi Compared to CCAP Provided Value;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
12-03-2024 15:53:14 | notice | US profile assignment change. US Chan ID: 6; Previous Profile: 11 13; New Profile: 12 13.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
12-03-2024 15:10:08 | notice | GUI Login Status - Login Success from LAN interface |
12-03-2024 15:10:02 | notice | GUI Login Status - Login Success from LAN interface |
12-03-2024 15:09:34 | notice | GUI Login Status - Login Success from LAN interface |
12-03-2024 14:50:45 | warning | DBC-REQ Mismatch Between Calculated Value for P1.6hi Compared to CCAP Provided Value;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
12-03-2024 14:50:45 | notice | US profile assignment change. US Chan ID: 6; Previous Profile: 13; New Profile: 11 13.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
12-03-2024 14:50:40 | notice | REGISTRATION COMPLETE - Waiting for Operational status |
12-03-2024 14:50:35 | warning | RNG-RSP CCAP Commanded Power Exceeds Value Corresponding to the Top of the DRW;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
12-03-2024 14:50:35 | warning | Dynamic Range Window violation |
12-03-2024 14:50:35 | warning | REG-RSP-MP Mismatch Between Calculated Value for P1.6hi Compared to CCAP Provided Value;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
12-03-2024 14:50:29 | notice | DS profile assignment change. DS Chan ID: 32; Previous Profile: ; New Profile: 1 2 4.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
12-03-2024 14:50:22 | warning | DHCP WARNING - Non-critical field invalid in response ;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
12-03-2024 14:50:20 | notice | Honoring MDD; IP provisioning mode = IPv4 |
12-03-2024 14:50:09 | critical | SYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing;;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
12-03-2024 14:50:08 | critical | Unicast Ranging Received Abort Response - Re-initializing MAC;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
12-03-2024 14:49:57 | critical | Cable Modem Reboot because of - Reboot Timezone Change |
12-03-2024 14:49:57 | critical | SYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing;;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
12-03-2024 14:46:57 | critical | No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
12-03-2024 14:46:51 | critical | SYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing;;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
12-03-2024 14:46:50 | critical | Cable Modem Reboot because of - Reboot Factory reset UI |
on 12-03-2024 22:05
Issues tonight again.
Router status
1 | 331000000 | 6.1 | 41 | QAM 256 | 25 |
2 | 139000000 | 8.5 | 40 | QAM 256 | 1 |
3 | 147000000 | 8.5 | 40 | QAM 256 | 2 |
4 | 163000000 | 8.2 | 40 | QAM 256 | 4 |
5 | 195000000 | 8 | 41 | QAM 256 | 8 |
6 | 203000000 | 8 | 41 | QAM 256 | 9 |
7 | 227000000 | 7.9 | 41 | QAM 256 | 12 |
8 | 235000000 | 7.7 | 41 | QAM 256 | 13 |
9 | 259000000 | 6.9 | 41 | QAM 256 | 16 |
10 | 267000000 | 6.8 | 41 | QAM 256 | 17 |
11 | 275000000 | 6.6 | 41 | QAM 256 | 18 |
12 | 283000000 | 6.8 | 41 | QAM 256 | 19 |
13 | 291000000 | 6.8 | 41 | QAM 256 | 20 |
14 | 299000000 | 6.6 | 41 | QAM 256 | 21 |
15 | 307000000 | 6.6 | 41 | QAM 256 | 22 |
16 | 315000000 | 6.5 | 41 | QAM 256 | 23 |
17 | 323000000 | 6.3 | 41 | QAM 256 | 24 |
18 | 339000000 | 6.2 | 41 | QAM 256 | 26 |
19 | 347000000 | 6.2 | 41 | QAM 256 | 27 |
20 | 355000000 | 6 | 41 | QAM 256 | 28 |
21 | 363000000 | 6.1 | 41 | QAM 256 | 29 |
22 | 371000000 | 5.4 | 41 | QAM 256 | 30 |
23 | 379000000 | 4.6 | 41 | QAM 256 | 31 |
24 | 387000000 | 4.7 | 41 | QAM 256 | 32 |
25 | 395000000 | 4.5 | 41 | QAM 256 | 33 |
26 | 403000000 | 4.5 | 41 | QAM 256 | 34 |
27 | 411000000 | 4.5 | 41 | QAM 256 | 35 |
28 | 419000000 | 4.5 | 41 | QAM 256 | 36 |
29 | 427000000 | 4.8 | 41 | QAM 256 | 37 |
30 | 435000000 | 4.7 | 41 | QAM 256 | 38 |
31 | 443000000 | 4.8 | 41 | QAM 256 | 39 |
32 | 451000000 | 4.9 | 41 | QAM 256 | 40 |
1 | Locked | 41 | 211 | 5744 |
2 | Locked | 40 | 62 | 56727 |
3 | Locked | 40 | 323 | 76136 |
4 | Locked | 40 | 90 | 79346 |
5 | Locked | 41 | 68 | 80427 |
6 | Locked | 41 | 1104 | 84599 |
7 | Locked | 41 | 75 | 88290 |
8 | Locked | 41 | 2915 | 85709 |
9 | Locked | 41 | 98 | 90246 |
10 | Locked | 41 | 138 | 92222 |
11 | Locked | 41 | 13436 | 80387 |
12 | Locked | 41 | 1014 | 94036 |
13 | Locked | 41 | 5538 | 90209 |
14 | Locked | 41 | 44338 | 53319 |
15 | Locked | 41 | 3436 | 94180 |
16 | Locked | 41 | 64686 | 34802 |
17 | Locked | 41 | 9254 | 91392 |
18 | Locked | 41 | 7765 | 94520 |
19 | Locked | 41 | 10208 | 93569 |
20 | Locked | 41 | 300 | 103313 |
21 | Locked | 41 | 11663 | 94219 |
22 | Locked | 41 | 136 | 105353 |
23 | Locked | 41 | 574 | 107134 |
24 | Locked | 41 | 16918 | 92534 |
25 | Locked | 41 | 99 | 109772 |
26 | Locked | 41 | 38064 | 73882 |
27 | Locked | 41 | 64267 | 49364 |
28 | Locked | 41 | 129908 | 3517 |
29 | Locked | 41 | 107585 | 4884 |
30 | Locked | 41 | 117464 | 2985 |
31 | Locked | 41 | 130576 | 3601 |
32 | Locked | 41 | 96116 | 3361 |
159 | Locked | 42 | 3.0 | 553172397 | 24266 |
on 12-03-2024 22:06
12-03-2024 22:02:32 | notice | GUI Login Status - Login Success from LAN interface |
12-03-2024 21:54:20 | warning | DBC-REQ Mismatch Between Calculated Value for P1.6hi Compared to CCAP Provided Value;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
12-03-2024 21:54:20 | notice | US profile assignment change. US Chan ID: 6; Previous Profile: 12 13; New Profile: 11 13.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
12-03-2024 21:32:50 | notice | CM-STATUS message sent. Event Type Code: 5; Chan ID: 1 2 4 8 9 12 13 16 17 18 19 20 21 22 23 24 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: N/A.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS |
12-03-2024 21:32:36 | warning | DBC-REQ Mismatch Between Calculated Value for P1.6hi Compared to CCAP Provided Value;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
12-03-2024 21:32:29 | critical | SYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing;;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
12-03-2024 20:54:18 | warning | DBC-REQ Mismatch Between Calculated Value for P1.6hi Compared to CCAP Provided Value;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
12-03-2024 20:54:18 | notice | US profile assignment change. US Chan ID: 6; Previous Profile: 11 13; New Profile: 12 13.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
12-03-2024 20:53:43 | warning | DBC-REQ Mismatch Between Calculated Value for P1.6hi Compared to CCAP Provided Value;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
12-03-2024 20:53:43 | notice | US profile assignment change. US Chan ID: 6; Previous Profile: 12 13; New Profile: 11 13.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
12-03-2024 19:52:50 | warning | DBC-REQ Mismatch Between Calculated Value for P1.6hi Compared to CCAP Provided Value;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
12-03-2024 19:52:50 | notice | US profile assignment change. US Chan ID: 6; Previous Profile: 11 13; New Profile: 12 13.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
12-03-2024 19:22:56 | warning | DBC-REQ Mismatch Between Calculated Value for P1.6hi Compared to CCAP Provided Value;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
12-03-2024 19:22:56 | notice | US profile assignment change. US Chan ID: 6; Previous Profile: 13; New Profile: 11 13.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
12-03-2024 18:24:47 | notice | GUI Login Status - Login Success from LAN interface |
12-03-2024 17:52:59 | warning | DBC-REQ Mismatch Between Calculated Value for P1.6hi Compared to CCAP Provided Value;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
12-03-2024 17:52:59 | notice | US profile assignment change. US Chan ID: 6; Previous Profile: 12 13; New Profile: 13.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
12-03-2024 17:52:35 | notice | US profile assignment change. US Chan ID: 6; Previous Profile: 11 13; New Profile: 12 13.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
12-03-2024 17:52:35 | warning | DBC-REQ Mismatch Between Calculated Value for P1.6hi Compared to CCAP Provided Value;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
12-03-2024 17:24:18 | notice | US profile assignment change. US Chan ID: 6; Previous Profile: 13; New Profile: 11 13.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
12-03-2024 17:24:18 | warning | DBC-REQ Mismatch Between Calculated Value for P1.6hi Compared to CCAP Provided Value;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
12-03-2024 16:53:20 | notice | US profile assignment change. US Chan ID: 6; Previous Profile: 12 13; New Profile: 13.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
12-03-2024 16:53:20 | warning | DBC-REQ Mismatch Between Calculated Value for P1.6hi Compared to CCAP Provided Value;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
on 14-03-2024 09:16
Can someone from the forum team please check this for me as I have just phoned and feel like I have been fobbed off. Agent on phone said they have reconfigured my router and the issue is now fixed and won't happen again?
The service checker page is advising I need a tech booked but phone support never mentioned a tech visit.
1 | 331000000 | 6.3 | 41 | QAM 256 | 25 |
5 | 163000000 | 8.3 | 40 | QAM 256 | 4 |
11 | 211000000 | 8.3 | 41 | QAM 256 | 10 |
12 | 219000000 | 8.2 | 41 | QAM 256 | 11 |
13 | 227000000 | 8.1 | 41 | QAM 256 | 12 |
14 | 235000000 | 7.9 | 41 | QAM 256 | 13 |
15 | 243000000 | 7.2 | 41 | QAM 256 | 14 |
16 | 251000000 | 6.6 | 41 | QAM 256 | 15 |
17 | 259000000 | 7 | 41 | QAM 256 | 16 |
2 | Locked | 40 | 234 | 763 |
3 | Locked | 40 | 441 | 4080 |
4 | Locked | 40 | 686 | 4030 |
5 | Locked | 40 | 497 | 5246 |
6 | Locked | 40 | 309 | 3761 |
7 | Locked | 40 | 315 | 5099 |
8 | Locked | 41 | 314 | 4486 |
9 | Locked | 41 | 466 | 3391 |
10 | Locked | 41 | 747 | 7072 |
11 | Locked | 41 | 345 | 4646 |
12 | Locked | 41 | 637 | 7153 |
13 | Locked | 41 | 755 | 6667 |
14 | Locked | 41 | 1091 | 7071 |
15 | Locked | 41 | 446 | 5591 |
16 | Locked | 41 | 2020 | 7215 |
17 | Locked | 41 | 596 | 7385 |
18 | Locked | 41 | 869 | 7107 |
19 | Locked | 41 | 1027 | 8227 |
20 | Locked | 41 | 674 | 7487 |
21 | Locked | 41 | 2620 | 6959 |
22 | Locked | 41 | 814 | 7823 |
23 | Locked | 41 | 2401 | 7085 |
24 | Locked | 41 | 2025 | 7618 |
25 | Locked | 41 | 2186 | 7148 |
26 | Locked | 41 | 3547 | 6526 |
27 | Locked | 41 | 3543 | 5996 |
28 | Locked | 41 | 3260 | 6145 |
29 | Locked | 41 | 3145 | 6306 |
30 | Locked | 41 | 3390 | 5989 |
31 | Locked | 41 | 2979 | 7565 |
32 | Locked | 41 | 3700 | 5630 |
159 | Locked | 42 | 3.2 | 1362692245 | 92 |
0 | 49600000 | 48 | 5120 | QAM 64 | 1 |
1 | 43100000 | 47 | 5120 | QAM 64 | 2 |
4 | 23600000 | 45.8 | 5120 | QAM 64 | 5 |
on 14-03-2024 09:17
What ever the agent on the phone is advising they have done, its not recorded anything on the network log on router?
14-03-2024 09:12:51 | notice | GUI Login Status - Login Success from LAN interface |
14-03-2024 09:03:43 | notice | US profile assignment change. US Chan ID: 6; Previous Profile: 11 13; New Profile: 12 13.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
14-03-2024 09:03:43 | warning | DBC-REQ Mismatch Between Calculated Value for P1.6hi Compared to CCAP Provided Value;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
14-03-2024 09:01:21 | notice | CM-STATUS message sent. Event Type Code: 24; Chan ID: 159; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: 1.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
14-03-2024 08:58:00 | notice | CM-STATUS message sent. Event Type Code: 16; Chan ID: 159; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: 1.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
14-03-2024 08:55:25 | notice | GUI Login Status - Login Success from LAN interface |
14-03-2024 08:54:54 | notice | CM-STATUS message sent. Event Type Code: 5; Chan ID: 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: N/A.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1 |
14-03-2024 08:54:21 | warning | Dynamic Range Window violation |
14-03-2024 08:54:21 | warning | RNG-RSP CCAP Commanded Power Exceeds Value Corresponding to the Top of the DRW;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
14-03-2024 08:23:15 | notice | US profile assignment change. US Chan ID: 6; Previous Profile: 12 13; New Profile: 11 13.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
14-03-2024 08:23:15 | warning | DBC-REQ Mismatch Between Calculated Value for P1.6hi Compared to CCAP Provided Value;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
14-03-2024 08:13:11 | notice | US profile assignment change. US Chan ID: 6; Previous Profile: 11 13; New Profile: 12 13.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
14-03-2024 08:13:11 | warning | DBC-REQ Mismatch Between Calculated Value for P1.6hi Compared to CCAP Provided Value;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
14-03-2024 06:42:30 | notice | US profile assignment change. US Chan ID: 6; Previous Profile: 12 13; New Profile: 11 13.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
14-03-2024 06:42:30 | warning | DBC-REQ Mismatch Between Calculated Value for P1.6hi Compared to CCAP Provided Value;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
14-03-2024 06:32:28 | warning | DBC-REQ Mismatch Between Calculated Value for P1.6hi Compared to CCAP Provided Value;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
14-03-2024 06:32:28 | notice | US profile assignment change. US Chan ID: 6; Previous Profile: 11 13; New Profile: 12 13.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
14-03-2024 05:52:11 | warning | DBC-REQ Mismatch Between Calculated Value for P1.6hi Compared to CCAP Provided Value;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
14-03-2024 05:52:11 | notice | US profile assignment change. US Chan ID: 6; Previous Profile: 12 13; New Profile: 11 13.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
14-03-2024 05:42:04 | warning | DBC-REQ Mismatch Between Calculated Value for P1.6hi Compared to CCAP Provided Value;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
14-03-2024 05:42:04 | notice | US profile assignment change. US Chan ID: 6; Previous Profile: 11 13; New Profile: 12 13.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
14-03-2024 05:32:00 | warning | DBC-REQ Mismatch Between Calculated Value for P1.6hi Compared to CCAP Provided Value;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
14-03-2024 05:32:00 | notice | US profile assignment change. US Chan ID: 6; Previous Profile: 12 13; New Profile: 11 13.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
14-03-2024 05:21:55 | warning | DBC-REQ Mismatch Between Calculated Value for P1.6hi Compared to CCAP Provided Value;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
14-03-2024 05:21:55 | notice | US profile assignment change. US Chan ID: 6; Previous Profile: 11 13; New Profile: 12 13.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
14-03-2024 04:51:36 | notice | US profile assignment change. US Chan ID: 6; Previous Profile: 12 13; New Profile: 11 13.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
14-03-2024 04:51:36 | warning | DBC-REQ Mismatch Between Calculated Value for P1.6hi Compared to CCAP Provided Value;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
14-03-2024 04:41:32 | warning | DBC-REQ Mismatch Between Calculated Value for P1.6hi Compared to CCAP Provided Value;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
14-03-2024 04:41:32 | notice | US profile assignment change. US Chan ID: 6; Previous Profile: 11 13; New Profile: 12 13.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
14-03-2024 03:41:05 | warning | DBC-REQ Mismatch Between Calculated Value for P1.6hi Compared to CCAP Provided Value;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
14-03-2024 03:41:05 | notice | US profile assignment change. US Chan ID: 6; Previous Profile: 12 13; New Profile: 11 13.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
14-03-2024 03:20:55 | notice | US profile assignment change. US Chan ID: 6; Previous Profile: 11 13; New Profile: 12 13.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
14-03-2024 03:20:55 | warning | DBC-REQ Mismatch Between Calculated Value for P1.6hi Compared to CCAP Provided Value;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
14-03-2024 03:10:51 | warning | DBC-REQ Mismatch Between Calculated Value for P1.6hi Compared to CCAP Provided Value;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
Also Service checker page is now not working for me. Been like that since yesterday lunchtime. Also does the same via the app.
