Weird power level distribution and RS errors
i_saw_drones
Hi All,
I recently noticed a bit of lag now and again with my Hub 3, and I decided to check the stats on it and found that there's a bit of a discrepancy regarding the power levels of downstream - is it normal for some channels have very negative power and others positive power ?
There's also quite a lot of post-RS errors on those channels which have a more extreme power values.
Please could you let me know if this is an issue with my line, or I can do something else to improve this, or does this need an engineer visit? Thank you!
Below stats have been taken after the router has been on for around 6 hours.
1259000000-9.928256 qam16
21470000007.540256 qam2
3155000000840256 qam3
41630000008.340256 qam4
51710000008.340256 qam5
61790000007.940256 qam6
71870000007.540256 qam7
8195000000740256 qam8
92030000006.140256 qam9
102110000005.440256 qam10
112190000004.138256 qam11
122270000002.738256 qam12
132350000000.737256 qam13
14243000000-1.935256 qam14
15251000000-5.432256 qam15
16267000000-1027256 qam17
17275000000-5.431256 qam18
18283000000-1.735256 qam19
192910000000.537256 qam20
202990000002.537256 qam21
213070000003.738256 qam22
223150000005.140256 qam23
23323000000640256 qam24
243310000006.540256 qam25
1Locked28.239152592038675
2Locked40.3230
3Locked40.3130
4Locked40.370
5Locked40.960
6Locked40.3140
7Locked40.3110
8Locked40.3340
9Locked40.9100
10Locked40.960
11Locked38.9100
12Locked38.6140
13Locked37.3190
14Locked354760
15Locked32.2239428714
16Locked27.8411019167652719
17Locked31.950392810
18Locked356410
19Locked37.3210
20Locked37.6330
21Locked38.9100
22Locked40.390
23Locked40.3180
24Locked40.930
21 REPLIES 21
jpeg1
There is still a serious problem with your connection. That is very obvious from the data you have posted. It still needs to be sorted by a technician on site.
- jpeg1
My name is NOT Alessandro. That's just a tag Virginmedia sticks on some contributors. Please ignore it.
Joseph_B
Hey @i_saw_drones,
Sorry to hear you are still having this issue.
I can see from our systems that you are still experiencing an outage, this is set to be fixed on the 13th December at 12:20PM, we would ask that you bear with us whilst we work through this.
Joe
Hi there Joe,
Thank you for the update, I'm sorry to hear that there is still an issue with the area before even someone will look at my connection, as I noted that it's also affecting my download speeds, so I am not receiving what I'm paying for :(. I also noticed from my BQM reports that I have a lot of packet loss as well, which is not great to say the least.
I will check as soon as it is resolved on Wednesday 13th and report back so that hopefully we can move this forward.
jpeg1
Something interesting happened at 03.00 today. The gross packet loss stopped, so there has been a network change. You might like to check your Hub data for any changes.
- jpeg1
Thank you for the heads-up, as it prompted me to check. I normally restart the hub daily at 3am with a power plug, however, I was curious as to why the packet drops stopped and it turns out that the router decided to sync to a single download channel:
1 235000000 -2.2 31 256 qam 13
1 Locked 31.6 19233838 0
Refresh data
1 49600034 43.3 5120 64 qam 1
1 ATDMA 0 0 0 0
Since then, I've had multiple drops/resyncs and all the download channels came back, albeit with the same power distribution as my earlier posts, and it seems the packet drops have returned too.
At it stands, it's unusable at the moment for remote work, so I am currently piggybacking off my mobile hotspot.
Fingers crossed it improves or VM find a fix by Wednesday.
Hi @i_saw_drones
Thanks for coming back to us.
The outage has been closed as resolved.
I do hope therefore everything has been resolved for you but if not, please let us know and we can assist further.
Best wishes
John_GS
Hi John_GS,
Thank you for coming back. Things have improved since the fix yesterday (13th Dec), as there is no longer any red on my BQM chart!
I checked my levels today and they seem to be better than before and there are now no Post RS errors! 🙂 However, I still have a strange distribution of power values (some positive and some negative), but I am not sure if this can be considered to be "normal"? It doesn't seem to impact the errors, but should it be like this?
I've posted them as they are now, after the router has been on for around 14 hours or so. Thank you for any input!
1235000000038256 qam13
21390000002.938256 qam1
31470000002.738256 qam2
41550000002.538256 qam3
51630000002.438256 qam4
61710000002.238256 qam5
71790000001.738256 qam6
81870000001.538256 qam7
91950000001.438256 qam8
10203000000138256 qam9
112110000000.938256 qam10
122190000000.538256 qam11
132270000000.238256 qam12
14243000000-0.238256 qam14
15251000000-0.438256 qam15
16259000000-0.438256 qam16
172670000000.938256 qam17
182750000001.538256 qam18
192830000001.238256 qam19
202910000000.738256 qam20
212990000000.738256 qam21
223070000000.738256 qam22
233150000000.738256 qam23
243230000000.738256 qam24
1Locked38.6240
2Locked38.9270
3Locked38.9280
4Locked38.9420
5Locked38.6340
6Locked38.9240
7Locked38.6290
8Locked38.6130
9Locked38.9320
10Locked38.6110
11Locked38.6160
12Locked38.6240
13Locked38.9180
14Locked38.6400
15Locked38.6320
16Locked38.6210
17Locked38.6150
18Locked38.9100
19Locked38.9150
20Locked38.6120
21Locked38.6260
22Locked38.6210
23Locked38.6210
24Locked38.9150
14960000046.8512064 qam6
22360008346512064 qam10
33009995246.3512064 qam9
43660006846.5512064 qam8
54310009746.5512064 qam7
1ATDMA0010
3ATDMA0000
4ATDMA0000
5ATDMA0000
jpeg1
Those levels are OK now. Nothing to worry about.
- jpeg1
Ah thank you very much for your input on this jpeg1! Appreciate your help throughout this thread.
In this case, I think no further actions needed thank goodness 🙂
Thanks for the updates @i_saw_drones.
Do feel free to come back to our Community Forums, if this error returns, or if there's an alternative issues that arise.
David_Bn
