12-12-2023 02:43 - edited 12-12-2023 02:59
Hi there
About a month ago we rejoined Virgin and was working fine. Up until recently I was getting a consistent 384mbps download and 37mbps upload
About a week ago I noticed a drop off in upload speed and some high pings. Speed/ping tests also confirmed this. There appears to be packet loss on upload and maybe some on download (but the amount might be considered normal/negligible for the donwload packet loss as it wasn't much)
Now if I speed test it goes straight to 384mbps almost as fast as previously, but upload seems like it's hunting around between 10-20mbps. Pings seem fine though I do get some timeouts or random high ones (300+ms) which I guess might be related to packet loss/retransmission
I looked at the router status and noticed a lot of pre and post RS errors on the downlink (hundreds, if not thousands). I also noted some T3 errors and the modulation changing in the uplink - sometimes it would drop to 32QAM or 16QAM. There are also T3 time out mesages in the network log
There was apparently a known issue in my area. The status page said TV and was supposed to have been fixed by now (though I can't say we had any issues with TV and the pre and post RS errors on downlink are lower since rebooting the modem)
Now, if I go to the service status check it says no known issues in my area, however if you click on broadband and test my hub, it will eventually return that there is an issue in my postcode with broadband and the technicians are sorting it
I suppose I just wanted to confirm this was the case as one status page says there isn't a problem and the other does, and if so is there an ETA?
I should note that a few years ago when we were with Virgin, we also had a hub 3 at that time and I would get occasional T3 timeout messages in the network log but it seemed to have no impact on performance and there were no RS errors or T3 errors in the uplink page. I don't know if it's negligible/normal to have some amount of T3 errors?
I note that we have recently had a speed boost, so I wonder if others have too and it's a capacity issue?
Some data below for those interested. Would appreciate any feedback as I do like to try to understand these things
1 | 43100000 | 41.2 | 5120 | 64 qam | 10 |
2 | 23600000 | 38.3 | 5120 | 64 qam | 13 |
3 | 30100000 | 39.5 | 5120 | 32 qam | 12 |
4 | 36600000 | 40.3 | 5120 | 32 qam | 11 |
5 | 49600000 | 42.5 | 5120 | 16 qam | 9 |
1 | ATDMA | 0 | 0 | 10 | 0 |
2 | ATDMA | 0 | 0 | 11 | 0 |
3 | ATDMA | 0 | 0 | 7 | 0 |
4 | ATDMA | 0 | 0 | 6 | 0 |
5 | ATDMA | 0 | 0 | 3 | 0 |
1 | 387000000 | 4.4 | 38 | 256 qam | 32 |
2 | 203000000 | 4.4 | 40 | 256 qam | 9 |
3 | 211000000 | 4.5 | 40 | 256 qam | 10 |
4 | 219000000 | 4 | 40 | 256 qam | 11 |
5 | 227000000 | 3.7 | 38 | 256 qam | 12 |
6 | 235000000 | 3.5 | 40 | 256 qam | 13 |
7 | 243000000 | 3.2 | 40 | 256 qam | 14 |
8 | 251000000 | 4.3 | 38 | 256 qam | 15 |
9 | 259000000 | 4.8 | 38 | 256 qam | 16 |
10 | 267000000 | 5 | 40 | 256 qam | 17 |
11 | 275000000 | 4.9 | 40 | 256 qam | 18 |
12 | 283000000 | 5 | 40 | 256 qam | 19 |
13 | 291000000 | 4.8 | 40 | 256 qam | 20 |
14 | 299000000 | 5.1 | 38 | 256 qam | 21 |
15 | 307000000 | 5 | 40 | 256 qam | 22 |
16 | 315000000 | 5.3 | 40 | 256 qam | 23 |
17 | 323000000 | 5.5 | 40 | 256 qam | 24 |
18 | 331000000 | 5.5 | 40 | 256 qam | 25 |
19 | 339000000 | 5.8 | 38 | 256 qam | 26 |
20 | 347000000 | 5.3 | 38 | 256 qam | 27 |
21 | 355000000 | 4.5 | 40 | 256 qam | 28 |
22 | 363000000 | 4.1 | 38 | 256 qam | 29 |
23 | 371000000 | 4.5 | 38 | 256 qam | 30 |
24 | 379000000 | 4.8 | 40 | 256 qam | 31 |
1 | Locked | 38.9 | 461 | 539 |
2 | Locked | 40.3 | 32 | 0 |
3 | Locked | 40.3 | 14 | 0 |
4 | Locked | 40.3 | 23 | 0 |
5 | Locked | 38.6 | 45 | 0 |
6 | Locked | 40.3 | 45 | 0 |
7 | Locked | 40.3 | 67 | 0 |
8 | Locked | 38.9 | 38 | 0 |
9 | Locked | 38.9 | 21 | 0 |
10 | Locked | 40.3 | 20 | 0 |
11 | Locked | 40.3 | 21 | 0 |
12 | Locked | 40.3 | 14 | 0 |
13 | Locked | 40.3 | 18 | 0 |
14 | Locked | 38.9 | 15 | 0 |
15 | Locked | 40.3 | 30 | 0 |
16 | Locked | 40.3 | 28 | 0 |
17 | Locked | 40.3 | 12 | 0 |
18 | Locked | 40.3 | 30 | 0 |
19 | Locked | 38.9 | 26 | 0 |
20 | Locked | 38.9 | 28 | 0 |
21 | Locked | 40.3 | 21 | 0 |
22 | Locked | 38.9 | 54 | 0 |
23 | Locked | 38.9 | 17 | 0 |
24 | Locked | 40.3 | 18 | 0 |
on 12-12-2023 17:02
Looks like problems with your US channels, they should all be at QAM64 and the T3 errors should be minimal.
Usually caused by noise or a SNR fault. All you can do is check the connections are tight, as loose connections can cause noise ingress. A VM tech will need to sort this out, but if it's an area fault, they will not attend until the area fault is cleared.
If you wait here a day or two, a VM Mod will pick this up and discuss.
on 14-12-2023 17:09
Hey @ShiroKen,
Welcome back to the Community Forums and thanks for the post.
Sorry to hear you have been having this issue, I would like to look into this further with you, for me to do so I will need to confirm some information from you in a private message.
Joe
on 19-12-2023 13:42
Hey @ShiroKen,
Glad we could go about looking into this further for you, if there is anything further we can do, please do let us know.
Joe
