on 19-07-2021 14:50
Does anyone know what the maximum number of devices can be connected by wifi?
We currently have 25ish devices connected but most of them are passive i.e. smart plugs/smart speakers/doorbell etc... but we keep struggling to just get connected on our phones, buffering videos etc.
We're on 100mbs but upon the recommendation of a virgin advisor told that upgrading to 350mbs would likely fix our issues, does anyone have any idea if this will work or am I better getting an external wifi router and using the virgin hub as a modem?
Thanks!
Answered! Go to Answer
on 23-07-2021 17:26
I posted this once already but it seems to have disappeared... are virgin likely to be able to fix whatever the issue is or do I need to look for a non-Cable ISP?
1 | 507000000 | -1.4 | 38 | 256 qam | 13 |
2 | 515000000 | -1.5 | 38 | 256 qam | 14 |
3 | 523000000 | -2 | 38 | 256 qam | 15 |
4 | 531000000 | -2 | 38 | 256 qam | 16 |
5 | 539000000 | -2.2 | 38 | 256 qam | 17 |
6 | 547000000 | -2.7 | 38 | 256 qam | 18 |
7 | 555000000 | -2.2 | 38 | 256 qam | 19 |
8 | 563000000 | -1.7 | 38 | 256 qam | 20 |
9 | 571000000 | -2.7 | 38 | 256 qam | 21 |
10 | 579000000 | -2.7 | 38 | 256 qam | 22 |
11 | 587000000 | -2.5 | 38 | 256 qam | 23 |
12 | 595000000 | -2.4 | 38 | 256 qam | 24 |
13 | 635000000 | -2.7 | 38 | 256 qam | 25 |
14 | 643000000 | -2.2 | 38 | 256 qam | 26 |
15 | 651000000 | -1.9 | 38 | 256 qam | 27 |
16 | 659000000 | -2.2 | 38 | 256 qam | 28 |
17 | 667000000 | -1.7 | 38 | 256 qam | 29 |
18 | 675000000 | -1.5 | 38 | 256 qam | 30 |
19 | 683000000 | -2 | 40 | 256 qam | 31 |
20 | 691000000 | -2 | 38 | 256 qam | 32 |
21 | 699000000 | -1.5 | 38 | 256 qam | 33 |
22 | 707000000 | -1.5 | 38 | 256 qam | 34 |
23 | 715000000 | -2 | 38 | 256 qam | 35 |
24 | 723000000 | -1.5 | 38 | 256 qam | 36 |
1 | Locked | 38.9 | 161 | 0 |
2 | Locked | 38.9 | 131 | 3 |
3 | Locked | 38.6 | 116 | 24 |
4 | Locked | 38.9 | 140 | 19 |
5 | Locked | 38.9 | 130 | 17 |
6 | Locked | 38.9 | 118 | 25 |
7 | Locked | 38.9 | 123 | 12 |
8 | Locked | 38.9 | 137 | 24 |
9 | Locked | 38.9 | 189 | 12 |
10 | Locked | 38.9 | 235 | 7 |
11 | Locked | 38.6 | 250 | 16 |
12 | Locked | 38.9 | 316 | 18 |
13 | Locked | 38.6 | 124 | 27 |
14 | Locked | 38.9 | 122 | 13 |
15 | Locked | 38.6 | 136 | 10 |
16 | Locked | 38.6 | 114 | 2 |
17 | Locked | 38.9 | 101 | 16 |
18 | Locked | 38.9 | 92 | 26 |
19 | Locked | 40.3 | 109 | 19 |
20 | Locked | 38.9 | 155 | 10 |
21 | Locked | 38.9 | 123 | 24 |
22 | Locked | 38.9 | 134 | 16 |
23 | Locked | 38.9 | 126 | 26 |
24 | Locked | 38.6 | 187 | 48 |
1 | 46200044 | 45.3 | 5120 | 64 qam | 1 |
2 | 39400000 | 45.5 | 5120 | 64 qam | 2 |
3 | 25800000 | 46.3 | 5120 | 32 qam | 4 |
4 | 32600000 | 45.8 | 5120 | 64 qam | 3 |
1 | ATDMA | 0 | 0 | 1 | 0 |
2 | ATDMA | 0 | 0 | 2 | 0 |
3 | ATDMA | 0 | 0 | 2 | 0 |
4 | ATDMA | 0 | 0 | 1 | 0 |
on 23-07-2021 17:35
As @Adduxi has said, the network log is poor, and shows a connection that's repeatedly dropping channels. That's supported by the upstream timeouts, and the downstream post-RS error counts. I believe that'll only get fixed by a technician visit. Usually VM get these things sorted without needing to take your business elsewhere, although there are exceptions to every rule.
When all that's sorted, then you can worry about whether the wifi is up to scratch!
23-07-2021 17:43 - edited 23-07-2021 17:44
levels are good a few T3 errors but i dont see that being the problem with the wifi - to me tha question was answered in an earlier post - if the hub3 works for you then great - if not yu need to look at a better wifi router - you will be comparing a [more expensive] much better router with something not much better than a pound shop one
choice of which one is better is up to you a 3rd party router or mesh system - dont think about the pods VM offer - if free they are worth a try - at £5 a month on your package they are a waste of money
its worth asking and mentioning before you think about alternatives - have you split the wifi bands and turned off smart wifi - if not do so
as to a non cable isp - why do you think that will improve things - they are different and the connection in certain ways may be better but the wifi is likely to be the same
on 26-07-2021 08:23
Hello @Killy88,
Welcome back to the community page, thank you for posting on here.
I am sorry to see that you are having issues with your connection.
I was unable to locate your account using your forums details, can you please tell me if you have any devices connected to the wired connection? This would help with the Wi-Fi connections.
Please let me know.
03-08-2021 09:21 - edited 03-08-2021 09:23
So I managed after a few back and forths to get back down to 100mbs package then risked it and bought a new router… absolutely fixed all the problems. VM Hub is now in modem mode and everything is working exactly as it should!
on 03-08-2021 09:35
Thanks for the update @Killy88,
We're pleased to hear that you've been able to find a solution to the issue you were facing.
Feel free to come back to our Community Forums if you have any further issues with the services
Kindest regards,
David_Bn
