on 28-02-2023 21:23
After 2 years of working absolutely fine my BT Whole Home Premium (3 Disks) connected to my VM Hub 4 only provide 5-10 mins of connectivity before dropping. I’ve factory reset the BT Disks multiple times, switched the master disc around and switched the Hub 4 on and off multiple times.
When everything reconnects it works fine for a while then it loses connectivity and I have to try all over again.
Any advice how to trouble shoot the issue
Thanks 👍🏼
on 04-05-2023 17:05
I went through the same thing the only difference is I got an engineer to come out he didn't check anything he just put in hub 5 and said your problem is fixed.
They should credit your account with £15 at the least!
