on 24-11-2021 17:49
Virgin media have offered me an upgrade to Hub 3 after I clicked on the www.link,, well my S Hub 2ac is well past its sell by date but works everything ... I do not know if I should swop i or not ,...... if its not broke dont fix it syndrome ,,, VM have upped the anti a bit around here...done some recent line works and the service has not crashed and the lines seen good better than ever . I have good wifi signals / phone / telly on V6 box ,, missus happy with it..
I have not ordered the Hub 3 .. just wondering if I should ? just saying ,, any advice.
Alb in Blackbrook , St Helens
on 24-11-2021 18:51
on 26-11-2021 12:43
" Status Quo "... will remain here remain here until I need to do something.
Thx John
on 26-11-2021 12:50
Don't know why you're being sent a link to uprade to a Hub 3 for as VM as slowly sending out invites to upgrade to the Hub 5.
on 26-11-2021 13:44
@annorax wrote:Don't know why you're being sent a link to uprade to a Hub 3 for as VM as slowly sending out invites to upgrade to the Hub 5.
Classic 'left hand; right hand'
on 28-11-2021 17:23
Hi @Alby41
Thanks for posting. Have you opted in or applied for Volt benefits, if also a O2 customer? This could explain being sent an email to apply for the hub 3. As you get a speed boost which you'll need a hub 3 for. The hub you currently have is an older piece of equipment so does let us know if you wish to replace it.
Kind regards,
on 06-12-2021 21:20
on 09-12-2021 11:21
Hello @Alby41,
No problem 🙂 I am sorry for what has happened in the past with your equipment.
I hope you have no issues with your Hub-2, if you ever decide to go for a Hub-3 please do call us on 0345 454 1111 🙂
Many thanks,
