on 01-09-2023 00:32
I will be shortly going to VM full fibre and loosing my BT landline and associated number.
I know that a DEC phone can be connected to the VM Hub 5, but what phone number will it use, I am a bit confused.
on 01-09-2023 08:08
Hi davidirv,
Thanks for your post and welcome to the community.
So essentially if you just have one landline number it would still use the same one.
Do you have any extensions at all?
Let us know,
01-09-2023 08:51 - edited 01-09-2023 08:52
Do you mean you are moving away from BT and switching over to VM to provide your phone and broadband services?
Or do you mean your VM telephone service/wall socket is being switched over to a connection from the VM hub?
If it is the former you should be able to port your BT number to VM.
If it is the latter then your VM landline number stays the same, it is just the means of connection that changes (telephone wall socket becomes a connection on the back of the VM hub)
on 01-09-2023 09:00
Hello davidirv.
I think @goslow has hit the nail on the head with the response.
Can you please let us know if you are joining us, or you are an existing customer being switched from the traditional landline to our new fibre landline.
Gareth_L
on 01-09-2023 10:46
Hi Gareth
I am joining VM, a new full fibre installation will be completed in the next two weeks
on 01-09-2023 10:49
Thanks for replying davidirv.
Would you be able to let me know if you have any problems getting set up.
Also have you requested for your current telephone number to be ported over to us?
Gareth_L
on 01-09-2023 10:58
No request as yet, do you know the monthly charge for VM to support the old number
on 01-09-2023 11:12
Hi davidirv.
I can take a look at this for you.
The line charge will be part of a bundle, or do you mean will there be a charge to bring it over.
If the latter than good news. No charge at all to port your number over.
I will need to send a private message to gain account access and pass security.
If you can check your logo at the top right of your screen that would be great.
Gareth_L
