on 27-07-2022 23:26
Sam knows is consistently showing that I am getting speeds of around 1140 to my hub4 but I'm only getting max 600mb to a device connected via ethernet.
I've only recently upgraded to 1gig Volt - would you expect the speed to device to increase (I've seen wait 14 days) even though the speed to the hub4 is already at 1140?
on 28-07-2022 14:42
on 31-07-2022 11:47
Hey @Byfoja03,
Welcome back to the community and thanks for taking the time to post.
I'm sorry to hear of the issues that you're having with your connection at the moment. I have looked into this on our system and cannot see anything that would be causing the issues that you're having.
If you could try the help that @jbrennand has advised of and see if that helps to resolve the issues that you're having or this would help diagnose the issues that you're having.
Regards,
Steven_L
on 31-07-2022 12:43
Most likely the devices can't process that speed. Try a test after booting up in 'safe mode'
@Byfoja03 wrote:Sam knows is consistently showing that I am getting speeds of around 1140 to my hub4 but I'm only getting max 600mb to a device connected via ethernet.
