on 13-07-2022 12:08
Hi everyone,
We recently changed to gig1 on our Ultimate Oomph bundle and received a hub 4 that I installed myself (literally just followed the instructions in the booklet that came in the box and applied the our custom stuff of the old router), however nearly 2 weeks into the upgrade the speed has not changed at all. I've attached the results from SamKnows and the network information from the router.
Thank you in advance.
Daniel
25 | 330750000 | -1.5 | 40.4 | QAM256 | 25 |
6 | 178750000 | -0.7 | 40.9 | QAM256 | 6 |
7 | 186750000 | -0.7 | 40.9 | QAM256 | 7 |
8 | 194750000 | -0.7 | 40.9 | QAM256 | 8 |
9 | 202750000 | -0.6 | 40.9 | QAM256 | 9 |
10 | 210750000 | -0.6 | 40.9 | QAM256 | 10 |
11 | 218750000 | -0.6 | 40.9 | QAM256 | 11 |
12 | 226750000 | -0.4 | 40.4 | QAM256 | 12 |
13 | 234750000 | -0.5 | 40.4 | QAM256 | 13 |
14 | 242750000 | -0.4 | 40.4 | QAM256 | 14 |
15 | 250750000 | -0.5 | 40.9 | QAM256 | 15 |
16 | 258750000 | -0.6 | 40.4 | QAM256 | 16 |
17 | 266750000 | -0.5 | 40.4 | QAM256 | 17 |
18 | 274750000 | -0.1 | 40.4 | QAM256 | 18 |
19 | 282750000 | -0.1 | 40.9 | QAM256 | 19 |
20 | 290750000 | -0.2 | 40.4 | QAM256 | 20 |
21 | 298750000 | -0.8 | 40.4 | QAM256 | 21 |
22 | 306750000 | -1.1 | 40.9 | QAM256 | 22 |
23 | 314750000 | -1.5 | 40.9 | QAM256 | 23 |
24 | 322750000 | -1.6 | 40.4 | QAM256 | 24 |
26 | 338750000 | -1.5 | 40.9 | QAM256 | 26 |
27 | 346750000 | -1.4 | 40.9 | QAM256 | 27 |
28 | 354750000 | -1.3 | 40.9 | QAM256 | 28 |
29 | 362750000 | -1.2 | 40.9 | QAM256 | 29 |
30 | 370750000 | -1.1 | 40.9 | QAM256 | 30 |
31 | 378750000 | -1.3 | 40.4 | QAM256 | 31 |
32 | 386750000 | -1.2 | 40.4 | QAM256 | 32 |
33 | 394750000 | -1.1 | 40.4 | QAM256 | 33 |
34 | 402750000 | -1.2 | 40.9 | QAM256 | 34 |
35 | 410750000 | -1.1 | 40.4 | QAM256 | 35 |
36 | 514750000 | -0.2 | 40.9 | QAM256 | 36 |
25 | Locked | 40.366287 | 0 | 0 |
6 | Locked | 40.946209 | 0 | 0 |
7 | Locked | 40.946209 | 0 | 0 |
8 | Locked | 40.946209 | 10 | 0 |
9 | Locked | 40.946209 | 0 | 0 |
10 | Locked | 40.946209 | 0 | 0 |
11 | Locked | 40.946209 | 0 | 0 |
12 | Locked | 40.366287 | 0 | 0 |
13 | Locked | 40.366287 | 0 | 0 |
14 | Locked | 40.366287 | 0 | 0 |
15 | Locked | 40.946209 | 0 | 0 |
16 | Locked | 40.366287 | 0 | 0 |
17 | Locked | 40.366287 | 0 | 0 |
18 | Locked | 40.366287 | 0 | 0 |
19 | Locked | 40.946209 | 0 | 0 |
20 | Locked | 40.366287 | 0 | 0 |
21 | Locked | 40.366287 | 0 | 0 |
22 | Locked | 40.946209 | 0 | 0 |
23 | Locked | 40.946209 | 0 | 0 |
24 | Locked | 40.366287 | 0 | 0 |
26 | Locked | 40.946209 | 0 | 0 |
27 | Locked | 40.946209 | 0 | 0 |
28 | Locked | 40.946209 | 0 | 0 |
29 | Locked | 40.946209 | 0 | 0 |
30 | Locked | 40.946209 | 0 | 0 |
31 | Locked | 40.366287 | 0 | 0 |
32 | Locked | 40.366287 | 0 | 0 |
33 | Locked | 40.366287 | 0 | 0 |
34 | Locked | 40.946209 | 0 | 0 |
35 | Locked | 40.366287 | 0 | 0 |
36 | Locked | 40.946209 | 0 | 0 |
37 | 94 | 4K | 1840 | QAM4096 | 416 |
37 | Locked | 43 | -1.4 | 423198775 | 31 |
Answered! Go to Answer
on 13-07-2022 12:39
Hi @Bluer
The Primary Downstream from your network logs shows you are on the Gig1 tier, and the realspeed screenshot shows that the hub is receiving the full speed.
How are you measuring the speed? Wired or wireless? Which device are you using?
The following link (thanks @jbrennand ) details how to test your speed /Speed/Slow-Speed-on-1G-connection
You should also check that your network is enabled for Gig1 - also try a new/different ethernet cable and ethernet port.
on 13-07-2022 12:39
Hi @Bluer
13-07-2022 14:34 - edited 13-07-2022 14:34
Hi Dave,
I've investigated a little bit more and it turns out it was my settings on my desktop. I tested the same cable on my laptop and it was expected speeds, so then I performed a network reset in Windows and then ran TCPOptimiser, and after another restart following applying the optimised settings, I am now getting expected speeds.
Thank you for your help which prompted me to try more tests 🙂
Daniel
on 13-07-2022 15:27
Hi again Daniel,
Thanks for the update. That's great news 😄
