on 18-11-2021 14:35
I have 110mb download and only 10mb upload.
Not usually an issue but my PS5 sometimes has slow upload speeds (2mb) and I stream so I need it to be faster. It is wired too not wifi.
on 18-11-2021 14:37
VM will upsell you to a higher tier as they have more upload speed. Other than that, or moving to an Openreach supplier, there is nothing you can do.
on 18-11-2021 14:48
10 Mbps should be easily enough for an HD (1080p/30fps) stream as that is typically around 4-7 Mbps. So if you're finding problems and the occasional slow upload speed suggests that you would, best to get to the root of those. I suggest we start by looking at the hub's status data.
Pull up the log in page for the hub. But don't log in, just click on the link "Check router status" That'll bring up a window with five tabs. Open the Downstream tab. Select all the text (Ctrl-A if using a keyboard), copy it (Ctrl-C), then paste it (Ctrl-V) into a reply here as TEXT not screenshots. Post that, do the same for the Upstream and Network log. You'll get an error message when you post the Network log, just click on "post" a second time. Then we can check for any obvious problems with power, noise or error counts, if all looks good we can move on to other checks.
on 19-11-2021 19:25
Okay thank you 🙂
1 | 411000000 | 23.5 | 38 | 256 qam | 31 |
2 | 195000000 | 23.9 | 40 | 256 qam | 8 |
3 | 203000000 | 23.6 | 40 | 256 qam | 9 |
4 | 211000000 | 23.5 | 40 | 256 qam | 10 |
5 | 219000000 | 23.8 | 40 | 256 qam | 11 |
6 | 227000000 | 24 | 40 | 256 qam | 12 |
7 | 235000000 | 23.9 | 40 | 256 qam | 13 |
8 | 243000000 | 23.6 | 40 | 256 qam | 14 |
9 | 251000000 | 23.3 | 40 | 256 qam | 15 |
10 | 259000000 | 23.5 | 40 | 256 qam | 16 |
11 | 267000000 | 23.5 | 38 | 256 qam | 17 |
12 | 275000000 | 23.8 | 40 | 256 qam | 18 |
13 | 283000000 | 23.5 | 40 | 256 qam | 19 |
14 | 291000000 | 23.8 | 40 | 256 qam | 20 |
15 | 299000000 | 24 | 40 | 256 qam | 21 |
16 | 307000000 | 23.8 | 38 | 256 qam | 22 |
17 | 315000000 | 24 | 40 | 256 qam | 23 |
18 | 323000000 | 23.6 | 40 | 256 qam | 24 |
19 | 363000000 | 24 | 38 | 256 qam | 25 |
20 | 371000000 | 23.9 | 40 | 256 qam | 26 |
21 | 379000000 | 23.8 | 40 | 256 qam | 27 |
22 | 387000000 | 23.9 | 40 | 256 qam | 28 |
23 | 395000000 | 23.5 | 40 | 256 qam | 29 |
24 | 403000000 | 24 | 38 | 256 qam | 30 |
on 19-11-2021 19:26
1 | 53700000 | 35.8 | 5120 | 32 qam | 6 |
2 | 60300000 | 36 | 5120 | 32 qam | 5 |
3 | 46200000 | 35.8 | 5120 | 32 qam | 7 |
4 | 39400000 | 36.3 | 5120 | 32 qam | 8 |
1 | ATDMA | 0 | 0 | 1 | 0 |
2 | ATDMA | 0 | 0 | 1 | 0 |
3 | ATDMA | 0 | 0 | 7 | 0 |
4 | ATDMA | 0 | 0 | 32 | 0 |
on 19-11-2021 19:27
19/11/2021 19:14:30 | notice | LAN login Success;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
19/11/2021 19:09:19 | Warning! | LAN login FAILED : Incorrect Username / Password / ConnectionType;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
19/11/2021 18:23:0 | Error | DHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
17/11/2021 21:06:51 | critical | No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
16/11/2021 08:31:10 | Error | DHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
12/11/2021 19:02:25 | critical | No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
12/11/2021 15:14:44 | Error | DHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
09/11/2021 16:43:5 | critical | No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
09/11/2021 03:14:44 | Error | DHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
06/11/2021 20:31:40 | critical | No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
05/11/2021 15:14:44 | Error | DHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
02/11/2021 10:13:10 | critical | No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
02/11/2021 03:14:44 | Error | DHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
30/10/2021 10:17:29 | critical | No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
29/10/2021 15:14:44 | Error | DHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
27/10/2021 14:16:29 | critical | No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
26/10/2021 17:34:17 | Error | DHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
01/01/1970 00:01:42 | critical | No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
21/10/2021 23:54:52 | Error | DHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
19/10/2021 08:32:57 | critical | No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
19-11-2021 20:02 - edited 19-11-2021 20:02
You need an engineer visit to look that those. Downstream power levels are very high, upstream should be at 64QAM, but is showing 32, so honestly not surprised you're having issues right now. Would be worth a revisit once you've had these issues sorted to see if you need the upgrade or not.
on 20-11-2021 00:02
Yes I don't know what I'm looking at but critical, error and warning didn't look good. Thank you. I'll call them next week.
20-11-2021 11:51 - edited 20-11-2021 11:52
The downstream levels are so grossly excessive that your connection will certainly be disrupted. You definitely need attention to this. Was there ever an attenuator fitted in the feed to the Hub?
on 22-11-2021 12:52
Hi @stoffle thanks for getting back to our community.
I am sorry your upload speeds are still not what you'd expect. I would love to take a closer look at this for you. I am going to send you a private message.
Lee_R
