on 19-07-2023 16:03
I recently changed settings on my hub 5 router, since this the wifi pods have stopped working and are continuously flashing white, this has been for several days, I have turned the router and pods on and off with no effect. Any ideas of how I can resolve this? Thanks
on 19-07-2023 16:40
Hub Settings required for VM Pods to work
1. The Hub is in 'Router Mode'
2. Wireless Channel Optimisation is Enabled
3. The 2.4 & 5 GHz bands have the same SSID ( Hub 5 might need the original SSID )
4. SSID broadcast is Enabled on both bands
5. Both SSID are protected with the same password.
