on 02-05-2022 12:47
Has anyone had these issues? And how are they resolved? At least 5 of the devices with poor signal strength are in the same room as the hub 🤷♂️
Answered! Go to Answer
on 02-05-2022 14:38
With 31 devices, you should really consider moving to your own "proper" networking kit. The VM Hubs are a typical ISP device, built to a price.
on 02-05-2022 13:25
on 02-05-2022 14:09
It’s a hub 3 and every device, (31) is struggling on Wi-Fi. Nothing on Ethernet cable
on 02-05-2022 14:19
Is your SH behind a TV ???
What happens if you go closer to the SH ???
Wifi 2.4GHz or 5GHz range ???
WOW 31 devices...
on 02-05-2022 14:31
on 02-05-2022 14:38
on 05-05-2022 13:52
Hi Warbo_swfc,
Thanks for your post and a big welcome to the Community. It's great having you on board with us.
I'm sorry to hear about the issues you have been having with your broadband and WiFi connection. I'm happy to take a look in to things but I've been unable to locate you on our systems using your forum credentials. I will need to confirm some information with you in order for me to proceed with checks.
I have sent you a private message regarding this and will investigate further once I receive your reply. Just click on the little plum envelope at the top right-hand side of the page to access your inbox.
on 13-05-2022 12:30
Hi @Warbo_swfc
Thank you for communicating with me via Private Message
Glad to hear the issue was all sorted with the technician visit, please do be sure to contact us in the future if you require any assistance 🙂
