on 21-12-2021 12:01
Anyone on here be able to set my pod up as not connecting. Needs a signing to hub again
thanks
on 21-12-2021 12:39
on 21-12-2021 14:03
@BESSYFRAZZLE wrote:Anyone on here be able to set my pod up as not connecting. Needs a signing to hub again
Call the equipment activation number they may be able to help. It's 0800 953 9500 and you will need the Hub serial number/MAC address from the barcode sticker, and your account number. Just in case the Pod needs to be provisioned again.
You could also move the Pod closer to the Hub as well to see if it pairs?
on 23-12-2021 14:17
Good morning @BESSYFRAZZLE>
Welcome back to the forums and thank you taking the time to post.
I am sorry to hear that you are having some issues with connecting your pods,
As a few days have passed since your post, are you able to let me know how things are currently are, have you managed to get these sorted?
Kind regards,
Zak_M
on 01-01-2022 15:59
Transpired I bought a pod of eBay (as virgin media on their web said about going on mailing list)
so eBay ones won’t connect as you say have to be assigned.
have one from virgin now so connects fine but noticed virgin not great for wifi so may need to get another one ☝️
on 03-01-2022 16:54
Ah! Unfortunately the pods are already assigned and paired to the account and router which they were ordered from.
You can have up to 3 pods at the home if needed depending on your in home set up.
Have you got our connect app and is it tell you there are more blackspots in the home? https://virg.in/connectapp
on 03-01-2022 17:51
@BESSYFRAZZLE wrote:Transpired I bought a pod of eBay (as virgin media on their web said about going on mailing list) so eBay ones won’t connect as you say have to be assigned. <snip>
VM Pods remain the property of VM, as they are rented and shouldn't be sold on eBay.
