on 13-04-2023 21:19
My hub 4 fan is constantly running and is noisy. It is NOT in a hot place and has plenty of ventilation. As the hub is in my living room and cannot be relocated to another room it is incredibly annoying. Any help would be appreciated.
on 13-04-2023 22:42
Could be full of dust? Hub 4 is the only one with a fan. Power it off and blow it through with a can of compressed air.
on 14-04-2023 06:08
I’ve only had it 2 weeks. It’s been doing it since I installed it.
on 14-04-2023 11:25
@cnick wrote:I’ve only had it 2 weeks. It’s been doing it since I installed it.
VM recycle Hubs back into a pool to be re-used by customers. So, it could still need a clean out from the previous renters.
on 16-04-2023 11:56
Hi cnick,
Thank you for your post and welcome to the community.
Have you been able to try the suggestions from Adduxi?
^Martin
on 16-04-2023 21:42
I did try vacuuming it out, but it made no difference.
on 19-04-2023 09:51
Hi cnick
Thank you for your post and welcome back to our community.
I will send you a private message now so we can look into this further.
Please look out for the purple envelope in the top right of the page and pop me a reply when you can.
Vikki - Forum Team
