2 weeks ago
Replaced a week ago on April 9th. Since then the WiFi signal keeps dropping I get weak signal messages on our ring doorbell, cannot access the VM connect app it tells me that I am out. I have tried resetting the hub, reinstalled apps to no avail. I have to say that i never had any issues with broadband until the past few months.
2 weeks ago
Was your previous Hub also a Hub3? Are ethernet connected devices having the same issues ?
If they are, can you post the data as per this...
__________________________
In your browser’s URL box type in http://192.168.0.1 (or http://192.168.100.1 - if in modem mode) (DONT click these links) - and hit return. No need to log in - just click on the “Router Status” icon/text at bottom-middle (Hub3/4/5) or top/right (SH’s) - of the Login page.
Then… Navigate to these “data pages” and just copy/paste the normal “Formatted Text” (not images) 3 FULL sets of data onto here – 2 tables from the Downstream, 2 from the Upstream, & the Network Logs pages. Don't worry too much about the formatting it can be easily read & DON’T include personal data or MAC addresses - blank them out - if you copy/paste the data, the board software will do this for you (you may need to click the "submit" button again). If character limits are “exceeded” - just do two posts
2 weeks ago
If hub was replaced with Hub 5, then the wifi is the problem.
I had the same problem, 3 engineer visits, all connections changed inside and out, a hub change and was still getting disconnects. I cured the problem by putting the router into modem only mode. Not had a disconnect since.
a week ago
Hi @bazzauns51,
Thank you for your post and welcome back to our community forums. We're here to help.
I'm sorry to hear you're having some problems with the Wi-Fi service and signal recently. I've checked over things on our systems and I'm unable to detect any faults currently. Is this issue ongoing today? If so, have you noticed any problems with the wired connection too?
