on 30-04-2020 11:27
My Hub reboots itself between 00:00 and 01:00 every night.
At the same time as the reboot, the following message appears in network status.
30/04/2020 00:20:46 | Warning! | TCS Partial Service;CM-MAC=**;CMTS-MAC=**;CM-QOS=1.1;CM-VER=3.0; |
followed by.....
30/04/2020 00:21:16 | critical | Received Response to Broadcast Maintenance Request, But no Unicast Maintenance opportunities received - T4 time out;CM-MAC=**;CMTS-MAC=**;CM-QOS=1.1;CM-VER=3.0; |
I have hidden MAC.
Seen some similar posts on here but can't find any with a resolution. Any help greatly appreciated.
This is my first post.
Answered! Go to Answer
on 08-08-2020 22:52
Hi Corey_C, I'm also seeing this issue where the super hub disconnects from the internet around 00:00 - 01:00 everyday (last few months)
I only have 2 upstream channels and I see in the logs that it has a critical issue at these times:
No Ranging Response received - T3 time-out
Many thanks,
Matt
on 10-08-2020 18:34
Hi there @mattvmedia
Welcome to the community and thank you for your first post.
I'm sorry to hear that you've been having issues with your broadband. I have been able to access your account via the forum information given and can see there have been a few minor issues, however it doesn't look like there are any major issues that would be causing these problems you're experiencing. I've sent some signals to your hub that should hopefully help the connection.
Are you able to reboot the hub please and complete a BQM here please?
Hollie - Forum Team
on 03-10-2020 21:54
on 10-10-2020 17:06
on 10-10-2020 17:20
Have you set up the BQM as asked by Hollie in post 22 ?
16-10-2020 23:28 - edited 16-10-2020 23:38
Thanks for the reply, but my issue is more similar to the one in reply 17 - reply 22 was to someone with a different issue.
I posted some more info in the thread https://community.virginmedia.com/t5/QuickStart-set-up-and/Lost-MDD-Timeout-RCS-Partial-Service/m-p/...
on 03-04-2021 02:10
Hi all,
Same thing is happening to me. Every day at around 1:38am, my hub restarts and takes anywhere between 10 and 20 minutes to come back. A technician has replaced the box, but the problem persists.
Has anyone found a solution?
on 05-04-2021 11:09
Hi @cmanduchi,
Welcome to our Community Forum and thank you for your first post!
We're sorry to hear that you're experiencing some issues with your Hub 3 restarting in the middle of the night.
Can you tell us how long this has been going on for?
Usually, we do updates on the system at night for minimal disturbance, but these should only last a few days.
Please keep us updated on this.
on 05-04-2021 17:51
on 06-04-2021 11:20
Thanks for confirming cmanduchi,
I've been able to locate your account using your forum details, although the hub looks to be within the specifications we would expect there are a lot of time out errors.
Can you please reboot the hub and set up a BQM and let that run for 24 hours at least, then post the live link here so we can monitor the connection 🙂
Alex_Rm
