on 18-04-2022 10:58
Hello,
we have been suffering intermittent disconnections for several weeks. An engineer did attend and made some adjustments a couple of weeks back but the issue continues.
Hera are the detailed values:
1 | 258750000 | 6.5 | 38 | 256 qam | 16 |
2 | 138750000 | 4.9 | 38 | 256 qam | 1 |
3 | 146750000 | 4.4 | 38 | 256 qam | 2 |
4 | 154750000 | 4.5 | 38 | 256 qam | 3 |
5 | 162750000 | 5 | 38 | 256 qam | 4 |
6 | 170750000 | 5.1 | 38 | 256 qam | 5 |
7 | 178750000 | 5.5 | 38 | 256 qam | 6 |
8 | 186750000 | 5.6 | 38 | 256 qam | 7 |
9 | 194750000 | 5.8 | 38 | 256 qam | 8 |
10 | 202750000 | 6 | 38 | 256 qam | 9 |
11 | 210750000 | 6.1 | 38 | 256 qam | 10 |
12 | 218750000 | 6 | 38 | 256 qam | 11 |
13 | 226750000 | 6.3 | 38 | 256 qam | 12 |
14 | 234750000 | 6 | 38 | 256 qam | 13 |
15 | 242750000 | 6.4 | 38 | 256 qam | 14 |
16 | 250750000 | 6.3 | 38 | 256 qam | 15 |
17 | 266750000 | 6.5 | 38 | 256 qam | 17 |
18 | 274750000 | 6.3 | 38 | 256 qam | 18 |
19 | 282750000 | 6.6 | 38 | 256 qam | 19 |
20 | 290750000 | 6.3 | 38 | 256 qam | 20 |
21 | 298750000 | 7 | 38 | 256 qam | 21 |
22 | 306750000 | 6.5 | 38 | 256 qam | 22 |
23 | 314750000 | 7 | 38 | 256 qam | 23 |
24 | 322750000 | 6.6 | 38 | 256 qam | 24 |
1 | Locked | 38.6 | 5 | 0 |
2 | Locked | 38.6 | 29510 | 4 |
3 | Locked | 38.6 | 11 | 0 |
4 | Locked | 38.6 | 15 | 0 |
5 | Locked | 38.9 | 11 | 0 |
6 | Locked | 38.6 | 10 | 0 |
7 | Locked | 38.6 | 16 | 0 |
8 | Locked | 38.9 | 12 | 0 |
9 | Locked | 38.9 | 23 | 0 |
10 | Locked | 38.6 | 7 | 0 |
11 | Locked | 38.9 | 7 | 0 |
12 | Locked | 38.6 | 5 | 0 |
13 | Locked | 38.9 | 0 | 0 |
14 | Locked | 38.9 | 0 | 0 |
15 | Locked | 38.9 | 6 | 0 |
16 | Locked | 38.9 | 0 | 0 |
17 | Locked | 38.9 | 6 | 0 |
18 | Locked | 38.9 | 0 | 0 |
19 | Locked | 38.9 | 4 | 0 |
20 | Locked | 38.6 | 1 | 0 |
21 | Locked | 38.6 | 0 | 0 |
22 | Locked | 38.9 | 0 | 0 |
23 | Locked | 38.6 | 5 | 0 |
24 | Locked | 38.9 | 0 | 0 |
1 | 32600000 | 46.8 | 5120 | 64 qam | 11 |
2 | 39400000 | 47.3 | 5120 | 64 qam | 10 |
3 | 46200000 | 48 | 5120 | 64 qam | 9 |
4 | 25800000 | 46.3 | 5120 | 64 qam | 12 |
1 | ATDMA | 0 | 0 | 0 | 0 |
2 | ATDMA | 0 | 0 | 0 | 0 |
3 | ATDMA | 0 | 0 | 0 | 0 |
4 | ATDMA | 0 | 0 | 0 | 0 |
on 18-04-2022 11:02
Stats all look fine. Is the Hub actually rebooting, or just dropping the line? Can you post the Network log please.
Try a 60 second factory pinhole reset as below;
Remove any ethernet cables from the Hub and hold the pinhole reset switch for 60 seconds. Do NOT reboot the Hub, just let it do it's thing. Note you will need the passwords from the bottom of the Hub afterwards, so make sure they are legible.
on 18-04-2022 11:06
BTW: Those are after going through the restart procedure. We are seeing T3 timeouts in the history.
From other posts, I set up a BQM and get:
Which approximately matches with my observation.
Personally, I think the router is flakey!
Any ideas?
on 18-04-2022 11:12
Here's the log. Please let me know if you still want me to try the factory reset as it is a little bit of a pain - I'll need to reset passwords again! 😄
18/04/2022 09:54:28 | notice | LAN login Success;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
18/04/2022 05:08:50 | Warning! | RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
18/04/2022 05:08:32 | critical | No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
18/04/2022 02:26:24 | Warning! | RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
18/04/2022 02:26:1 | critical | No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
17/04/2022 21:51:27 | Warning! | RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
17/04/2022 21:49:39 | critical | No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
17/04/2022 21:48:38 | critical | Received Response to Broadcast Maintenance Request, But no Unicast Maintenance opportunities received - T4 time out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
17/04/2022 21:44:28 | critical | No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
17/04/2022 21:44:14 | critical | Unicast Maintenance Ranging attempted - No response - Retries exhausted;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
17/04/2022 21:44:14 | critical | Ranging Request Retries exhausted;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
17/04/2022 21:43:30 | critical | No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
17/04/2022 21:42:49 | Warning! | RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
17/04/2022 21:42:49 | critical | SYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
17/04/2022 19:16:44 | Warning! | RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
17/04/2022 14:56:56 | critical | No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
17/04/2022 14:56:6 | critical | Received Response to Broadcast Maintenance Request, But no Unicast Maintenance opportunities received - T4 time out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
17/04/2022 14:51:55 | critical | No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
17/04/2022 14:51:54 | critical | Unicast Maintenance Ranging attempted - No response - Retries exhausted;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
17/04/2022 14:51:54 | critical | Ranging Request Retries exhausted;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
on 19-04-2022 20:17
Still really bad today! Can anyone help here? What can I do?:
1 | 258750000 | 7.1 | 38 | 256 qam | 16 |
2 | 250750000 | 7 | 38 | 256 qam | 15 |
3 | 266750000 | 7.1 | 38 | 256 qam | 17 |
4 | 274750000 | 7 | 38 | 256 qam | 18 |
5 | 282750000 | 7.4 | 38 | 256 qam | 19 |
6 | 290750000 | 7 | 38 | 256 qam | 20 |
7 | 298750000 | 7.8 | 38 | 256 qam | 21 |
8 | 306750000 | 7.1 | 38 | 256 qam | 22 |
9 | 314750000 | 7.6 | 38 | 256 qam | 23 |
10 | 322750000 | 7.5 | 38 | 256 qam | 24 |
11 | 330750000 | 7.8 | 38 | 256 qam | 25 |
12 | 338750000 | 7.8 | 38 | 256 qam | 26 |
13 | 346750000 | 7.6 | 38 | 256 qam | 27 |
14 | 354750000 | 7.6 | 38 | 256 qam | 28 |
15 | 362750000 | 7.5 | 38 | 256 qam | 29 |
16 | 370750000 | 7.8 | 38 | 256 qam | 30 |
17 | 378750000 | 7.5 | 38 | 256 qam | 31 |
18 | 386750000 | 7.6 | 38 | 256 qam | 32 |
19 | 394750000 | 7 | 38 | 256 qam | 33 |
20 | 402750000 | 7.4 | 38 | 256 qam | 34 |
21 | 410750000 | 7 | 38 | 256 qam | 35 |
22 | 418750000 | 7 | 38 | 256 qam | 36 |
23 | 522750000 | 5.6 | 38 | 256 qam | 37 |
24 | 530750000 | 5.8 | 38 | 256 qam | 38 |
1 | Locked | 38.9 | 485 | 98 |
2 | Locked | 38.9 | 785 | 35 |
3 | Locked | 38.9 | 682 | 60 |
4 | Locked | 38.9 | 503 | 39 |
5 | Locked | 38.9 | 465 | 39 |
6 | Locked | 38.6 | 415 | 35 |
7 | Locked | 38.6 | 306 | 34 |
8 | Locked | 38.9 | 294 | 42 |
9 | Locked | 38.9 | 196 | 42 |
10 | Locked | 38.6 | 310 | 41 |
11 | Locked | 38.9 | 160 | 147 |
12 | Locked | 38.6 | 213 | 27 |
13 | Locked | 38.9 | 138 | 33 |
14 | Locked | 38.6 | 171 | 35 |
15 | Locked | 38.6 | 121 | 33 |
16 | Locked | 38.9 | 138 | 30 |
17 | Locked | 38.9 | 130 | 38 |
18 | Locked | 38.9 | 112 | 25 |
19 | Locked | 38.9 | 94 | 26 |
20 | Locked | 38.9 | 101 | 20 |
21 | Locked | 38.6 | 93 | 19 |
22 | Locked | 38.9 | 67 | 16 |
23 | Locked | 38.9 | 63 | 3 |
24 | Locked | 38.6 | 40 | 13 |
1 | 32600000 | 46.3 | 5120 | 64 qam | 11 |
2 | 39400000 | 47 | 5120 | 64 qam | 10 |
3 | 46200000 | 47.5 | 5120 | 64 qam | 9 |
4 | 25800005 | 45.8 | 5120 | 64 qam | 12 |
1 | ATDMA | 0 | 0 | 3 | 0 |
on 19-04-2022 20:19
19/04/2022 13:44:51 | Warning! | RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
19/04/2022 13:12:32 | critical | No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
19/04/2022 13:11:32 | critical | Received Response to Broadcast Maintenance Request, But no Unicast Maintenance opportunities received - T4 time out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
19/04/2022 13:07:43 | critical | No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
19/04/2022 13:07:42 | critical | Unicast Maintenance Ranging attempted - No response - Retries exhausted;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
19/04/2022 13:07:42 | critical | Ranging Request Retries exhausted;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
19/04/2022 13:07:32 | critical | No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
19/04/2022 13:07:19 | critical | Unicast Maintenance Ranging attempted - No response - Retries exhausted;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
19/04/2022 13:07:19 | critical | Ranging Request Retries exhausted;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
19/04/2022 13:06:35 | critical | No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
19/04/2022 13:02:9 | Warning! | RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
19/04/2022 10:35:27 | critical | No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
19/04/2022 10:34:27 | critical | Received Response to Broadcast Maintenance Request, But no Unicast Maintenance opportunities received - T4 time out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
19/04/2022 10:30:17 | critical | No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
19/04/2022 10:30:17 | critical | Unicast Maintenance Ranging attempted - No response - Retries exhausted;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
19/04/2022 10:30:17 | critical | Ranging Request Retries exhausted;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
19/04/2022 10:07:59 | critical | No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
19/04/2022 10:07:35 | critical | Unicast Maintenance Ranging attempted - No response - Retries exhausted;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
19/04/2022 10:07:35 | critical | Ranging Request Retries exhausted;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
19/04/2022 10:06:51 | critical | No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
on 19-04-2022 23:21
Looks like you have a circuit problem, rather than a hub problem.
Check with Area faults on 0800 561 0061 If you have a VM landline 150 this goes down to post code level. You could also try the web page http://www.virginmedia.com/servicechecker
VM will not dispatch any technicians when an area fault exists.
If no faults found:
Call Customer Services on 0345 454 1111/150 if you have a VM landline or wait a day or two for a VM staff member to get to your post.
on 20-04-2022 08:51
Hi @JonKemp12
Thanks for posting on our community forum
Please keep an eye on your inbox and I'll drop you a private message to have a detailed look into this.
on 22-04-2022 08:55
Please do let us know how your service is today JonKemp12.
^Martin
on 22-04-2022 15:59
Hi Martin,
no, still no improvement.
Looks like it dropped out around 12:10, 12:50 and 14:20 this afternoon.
Here is the link to the BQM:
https://www.thinkbroadband.com/broadband/monitoring/quality/share/17a88e14e8c7df5c40c15b495a765c5fc965f976
I hope someone can fix this!
Thank you,
- jon
