24-10-2023 12:48 - edited 24-10-2023 12:52
For about a month now, my thinkbroadband graph looks like the first picture. and for the last few days it looks like the second picture.
Hub reboots do not resolve the issue.
27-10-2023 16:23 - edited 27-10-2023 16:24
i've plugged my macbook into the hub 4, via ethernet.
here are the results of the ping:
--- 194.168.4.100 ping statistics ---
215 packets transmitted, 215 packets received, 0.0% packet loss
and here are the results of the latest 24 hours of my thinkbroadband BQM.
on 28-10-2023 02:07
i don't understand why this is happening.
on 28-10-2023 15:41
on 28-10-2023 16:08
setup you router QoS to limit download 115Mb and upload 19Mb
on 28-10-2023 17:30
Hi, can you advise why i should do this? Thanks!
For what it's worth i have the gigabit package.
28-10-2023 18:48 - edited 28-10-2023 18:50
Going by Demo UI log in to your ASUS click adaptive QoS > QoS tab enable QoS with QoS type Traditional QoS then put in 19Mb for upload and 115Mb for download for now then run this test
https://www.waveform.com/tools/bufferbloat
give 24hr before increasing the limits when checking with BQM if BQM still spikes either your still be flooded or causing a flood or the area your in is bad and nothing you can do.
Its also possible your still flooding but the limits and QoS show your BQM to be fine
on 28-10-2023 19:22
sorry, i asked why, not how? i'm curious as to what we are trying to determine from the above tests and why we are using those values for QOS?
on 28-10-2023 20:17
testing
on 29-10-2023 11:10
although that doesn't make sense to me, i've done what you asked, but i'm still experiencing lag.
Can i get a response from VM please?
Cable Modem Status | Online | DOCSIS 3.1 |
Primary downstream channel | Locked | SC-QAM |
DOCSIS 3.0 channels | 31 | 5 |
DOCSIS 3.1 channels | 1 | 1 |
on 29-10-2023 11:10
25 | 331000000 | 2.599998 | 38.983261 | QAM256 | 25 |
1 | 139000000 | 3.500000 | 40.366287 | QAM256 | 1 |
2 | 147000000 | 3.599998 | 38.983261 | QAM256 | 2 |
3 | 155000000 | 3.599998 | 40.946209 | QAM256 | 3 |
4 | 163000000 | 3.500000 | 38.983261 | QAM256 | 4 |
5 | 171000000 | 3.299999 | 38.983261 | QAM256 | 5 |
6 | 179000000 | 3.200001 | 38.983261 | QAM256 | 6 |
7 | 187000000 | 3.200001 | 38.983261 | QAM256 | 7 |
8 | 195000000 | 3.099998 | 38.983261 | QAM256 | 8 |
9 | 203000000 | 3.000000 | 38.605377 | QAM256 | 9 |
10 | 211000000 | 3.000000 | 38.605377 | QAM256 | 10 |
11 | 219000000 | 3.000000 | 38.983261 | QAM256 | 11 |
12 | 227000000 | 2.799999 | 38.983261 | QAM256 | 12 |
13 | 235000000 | 2.599998 | 38.983261 | QAM256 | 13 |
14 | 243000000 | 2.400002 | 38.605377 | QAM256 | 14 |
15 | 251000000 | 2.400002 | 38.983261 | QAM256 | 15 |
16 | 259000000 | 2.400002 | 38.983261 | QAM256 | 16 |
17 | 267000000 | 2.599998 | 38.983261 | QAM256 | 17 |
18 | 275000000 | 2.700001 | 38.605377 | QAM256 | 18 |
19 | 283000000 | 2.500000 | 38.983261 | QAM256 | 19 |
20 | 291000000 | 2.500000 | 38.983261 | QAM256 | 20 |
21 | 299000000 | 2.599998 | 38.605377 | QAM256 | 21 |
22 | 307000000 | 2.599998 | 38.983261 | QAM256 | 22 |
23 | 315000000 | 2.700001 | 38.983261 | QAM256 | 23 |
24 | 323000000 | 2.599998 | 38.983261 | QAM256 | 24 |
26 | 339000000 | 2.799999 | 40.366287 | QAM256 | 26 |
27 | 347000000 | 3.099998 | 40.366287 | QAM256 | 27 |
28 | 355000000 | 3.000000 | 38.983261 | QAM256 | 28 |
29 | 363000000 | 3.000000 | 40.366287 | QAM256 | 29 |
30 | 371000000 | 2.900002 | 40.366287 | QAM256 | 30 |
31 | 379000000 | 2.900002 | 40.366287 | QAM256 | 31 |
25 | Locked | 38.983261 | 0 | 0 |
1 | Locked | 40.366287 | 0 | 0 |
2 | Locked | 38.983261 | 0 | 0 |
3 | Locked | 40.946209 | 0 | 0 |
4 | Locked | 38.983261 | 0 | 0 |
6 | Locked | 38.983261 | 0 | 0 |
7 | Locked | 38.983261 | 0 | 0 |
8 | Locked | 38.983261 | 0 | 0 |
9 | Locked | 38.605377 | 0 | 0 |
10 | Locked | 38.605377 | 0 | 0 |
11 | Locked | 38.983261 | 0 | 0 |
12 | Locked | 38.983261 | 0 | 0 |
13 | Locked | 38.983261 | 0 | 0 |
14 | Locked | 38.605377 | 0 | 0 |
15 | Locked | 38.983261 | 0 | 0 |
16 | Locked | 38.983261 | 0 | 0 |
17 | Locked | 38.983261 | 0 | 0 |
18 | Locked | 38.605377 | 0 | 0 |
19 | Locked | 38.983261 | 0 | 0 |
20 | Locked | 38.983261 | 0 | 0 |
21 | Locked | 38.605377 | 0 | 0 |
22 | Locked | 38.983261 | 0 | 0 |
23 | Locked | 38.983261 | 0 | 0 |
24 | Locked | 38.983261 | 0 | 0 |
26 | Locked | 40.366287 | 0 | 0 |
27 | Locked | 40.366287 | 0 | 0 |
28 | Locked | 38.983261 | 0 | 0 |
29 | Locked | 40.366287 | 0 | 0 |
30 | Locked | 40.366287 | 0 | 0 |
31 | Locked | 40.366287 | 0 | 0 |
33 | 96 | 4K | 1840 | QAM4096 | 392 |
33 | Locked | 41 | 3.0 | 1550966896 | 0 |
