24-10-2023 12:48 - edited 24-10-2023 12:52
For about a month now, my thinkbroadband graph looks like the first picture. and for the last few days it looks like the second picture.
Hub reboots do not resolve the issue.
on 24-10-2023 15:07
Looks like your being DoS or have a device flooding the upstream
Put hub in modem mode with a best that you know of safe PC and run
CMD
ping -n 200 194.168.4.100
on 25-10-2023 20:58
what makes you say that? and what ip is 194.168.4.100?
on 25-10-2023 22:37
Also, i am i already in modem mode.
on 25-10-2023 23:04
194.168.4.100 is VM DNS
Your in modem mode but with what? a router? its possible your router delays ping which is why you test without it with just a PC and modem mode.
Basic home routers when you ping them may rate limit ping to them so that if a ICMP flood happens you don't flood the upstream so BQM can show bad but really not that bad
on 26-10-2023 07:28
Call 0800 561 0061 this automated number will reports known service issues affecting your street.
Share the Hub Downstream / Upstream stats - these can reveal a connection or noise fault.
( Copy / paste the text from the Hub it make it easier to read that screen shots in these forum pages. )
on 26-10-2023 13:39
In modem mode, connected to a router, an Asus RT-AC86U.
my setup has always looked like this and i've never had issues like this before. Prior to these issues my graph looked like the snapshot from below. with the same setup.
on 26-10-2023 13:41
25 | 331000000 | 3.000000 | 40.366287 | QAM256 | 25 |
1 | 139000000 | 4.000000 | 40.366287 | QAM256 | 1 |
2 | 147000000 | 4.199997 | 40.366287 | QAM256 | 2 |
3 | 155000000 | 4.099998 | 40.366287 | QAM256 | 3 |
4 | 163000000 | 4.000000 | 40.366287 | QAM256 | 4 |
5 | 171000000 | 3.799999 | 38.983261 | QAM256 | 5 |
6 | 179000000 | 3.700001 | 38.983261 | QAM256 | 6 |
7 | 187000000 | 3.599998 | 38.983261 | QAM256 | 7 |
8 | 195000000 | 3.599998 | 38.983261 | QAM256 | 8 |
9 | 203000000 | 3.500000 | 38.605377 | QAM256 | 9 |
10 | 211000000 | 3.400002 | 38.983261 | QAM256 | 10 |
11 | 219000000 | 3.400002 | 38.983261 | QAM256 | 11 |
12 | 227000000 | 3.299999 | 38.983261 | QAM256 | 12 |
13 | 235000000 | 3.000000 | 38.983261 | QAM256 | 13 |
14 | 243000000 | 2.799999 | 38.983261 | QAM256 | 14 |
15 | 251000000 | 2.799999 | 38.983261 | QAM256 | 15 |
16 | 259000000 | 2.799999 | 38.983261 | QAM256 | 16 |
17 | 267000000 | 2.900002 | 38.983261 | QAM256 | 17 |
18 | 275000000 | 3.099998 | 38.983261 | QAM256 | 18 |
19 | 283000000 | 3.000000 | 38.605377 | QAM256 | 19 |
20 | 291000000 | 2.900002 | 38.983261 | QAM256 | 20 |
21 | 299000000 | 3.000000 | 38.605377 | QAM256 | 21 |
22 | 307000000 | 3.000000 | 38.983261 | QAM256 | 22 |
23 | 315000000 | 3.099998 | 40.366287 | QAM256 | 23 |
24 | 323000000 | 2.900002 | 38.983261 | QAM256 | 24 |
26 | 339000000 | 3.200001 | 40.366287 | QAM256 | 26 |
27 | 347000000 | 3.400002 | 40.366287 | QAM256 | 27 |
28 | 355000000 | 3.299999 | 40.366287 | QAM256 | 28 |
29 | 363000000 | 3.299999 | 40.366287 | QAM256 | 29 |
30 | 371000000 | 3.200001 | 40.366287 | QAM256 | 30 |
31 | 379000000 | 3.200001 | 40.366287 | QAM256 | 31 |
25 | Locked | 40.366287 | 0 | 0 |
1 | Locked | 40.366287 | 0 | 0 |
2 | Locked | 40.366287 | 0 | 0 |
3 | Locked | 40.366287 | 0 | 0 |
4 | Locked | 40.366287 | 0 | 0 |
5 | Locked | 38.983261 | 0 | 0 |
6 | Locked | 38.983261 | 0 | 0 |
7 | Locked | 38.983261 | 0 | 0 |
8 | Locked | 38.983261 | 0 | 0 |
9 | Locked | 38.605377 | 0 | 0 |
10 | Locked | 38.983261 | 0 | 0 |
11 | Locked | 38.983261 | 0 | 0 |
12 | Locked | 38.983261 | 0 | 0 |
13 | Locked | 38.983261 | 0 | 0 |
14 | Locked | 38.983261 | 0 | 0 |
15 | Locked | 38.983261 | 0 | 0 |
16 | Locked | 38.983261 | 0 | 0 |
17 | Locked | 38.983261 | 0 | 0 |
18 | Locked | 38.983261 | 0 | 0 |
19 | Locked | 38.605377 | 0 | 0 |
20 | Locked | 38.983261 | 0 | 0 |
21 | Locked | 38.605377 | 0 | 0 |
22 | Locked | 38.983261 | 0 | 0 |
23 | Locked | 40.366287 | 0 | 0 |
24 | Locked | 38.983261 | 0 | 0 |
26 | Locked | 40.366287 | 0 | 0 |
27 | Locked | 40.366287 | 0 | 0 |
28 | Locked | 40.366287 | 0 | 0 |
29 | Locked | 40.366287 | 0 | 0 |
30 | Locked | 40.366287 | 0 | 0 |
31 | Locked | 40.366287 | 0 | 0 |
33 | 96 | 4K | 1840 | QAM4096 | 392 |
33 | Locked | 40 | 3.3 | 1590975269 | 797 |
on 26-10-2023 13:41
1 | 23600000 | 41.270599 | 5120 KSym/sec | 32QAM | 5 |
2 | 49600000 | 41.520599 | 5120 KSym/sec | 64QAM | 1 |
3 | 30100000 | 41.520599 | 5120 KSym/sec | 32QAM | 4 |
4 | 36600000 | 41.520599 | 5120 KSym/sec | 64QAM | 3 |
5 | 43100000 | 41.520599 | 5120 KSym/sec | 64QAM | 2 |
1 | US_TYPE_ATDMA | 0 | 0 | 0 | 0 |
2 | US_TYPE_ATDMA | 0 | 0 | 0 | 0 |
3 | US_TYPE_ATDMA | 0 | 0 | 0 | 0 |
4 | US_TYPE_ATDMA | 0 | 0 | 0 | 0 |
5 | US_TYPE_ATDMA | 0 | 0 | 0 | 0 |
6 | 10.8 | 37.2 | 2K | QAM32 |
6 | OFDMA | 220 | 53.4 | 0 | 0 |
26-10-2023 16:59 - edited 26-10-2023 17:00
run CMD
test hub in modem mode with a PC
