on 04-09-2021 20:27
Ok so I have just logged into my router as I am having difficulty detecting my V6 box when casting from my phone (using YouTube app) and the status problem checker under diagnostic inform me I have WiFi issues on the network, what does this mean, would it relate to the issue i am experiencing
is anyone else’s having issues casting YouTube app from phone to V6.
Answered! Go to Answer
on 15-09-2021 21:55
hi Beth.
Thank you for your reply but mine is WiFi to WiFi, only main box is able to Ethernet.
i did get a email today saying my hub setting are being remotely tweeked but so far no difference, also had a text saying that the 17th essential work is being carried out in our area.
on 18-09-2021 11:08
Thank you for letting us know @Les2013.
Has the issue improved since the service works and the email? Please get back to us when you can.
22-09-2021 21:55 - edited 22-09-2021 21:59
@Akua_A
Unfortunately not, in front of the V6 as we speak and from multiple devices i cannot. I can pick up other TV and V6 but not the one Upstairs.
on 26-09-2021 15:44
Hi Les2013,
That second v6 that's on a wireless connection, are you able to go into that settings menu under networking
Then can you check the network status and advise what you see? If there are errors are you able to run the test option?
Cheers,
Corey C
01-10-2021 21:11 - edited 01-10-2021 21:12
Signal 90% connected to 2.4ghz and service status is connected.
on 04-10-2021 09:34
Hmm, are you able to try connecting to the 5Ghz channel instead to see if that makes a difference? This will help us get a feeling of where the problem lies.
Beth
on 12-10-2021 19:18
I have tried this previously and the signal strength drops as expected but doesn’t not solve the issue.
if I reconnect the V6 to wifi it will find it as master bedroom but then wont the next day for example.
on 14-10-2021 19:48
