on 14-10-2021 18:26
My son's room often has poor signal at times of the day and I'm unable to connect from there to the two other Tivo boxes in our house.I have a very long Ethernet cable which I thought by connecting into a spare terminal at the rear of the router and the other end into my son's Tivo ethernet would bypass the weak wi fi signal but it makes no difference. Am I supposed to change any settings on his Tivo box in order to strengthen the signal or won't this idea fix the problem?
What advantage is there to connecting an Ethernet cable between the router and a Tivo box?
Many thanks
Answered! Go to Answer
on 16-10-2021 15:08
on 16-10-2021 15:14
Are both the donor & recipient boxes V6? I'm assuming so, but explicit confirmation would be useful.
And both are Ethernet connected?
What are the error codes on the recipient box when you try streaming from the donor box?
on 18-10-2021 15:19
Hello @jenfamily1,
Welcome back! Thanks for posting.
I am sorry to see that you are having issues connecting your TV box, have you tried doing a pinhole reset on your Hub? If not can you try this for me?
Many thanks,
on 21-10-2021 22:14
on 21-10-2021 22:18
on 21-10-2021 22:23
The Ethernet connection on a V6 is for the internet link which comes via your homehub - it's not for connecting directly to another V6.
In some previous posts you seemed to be expecting to see a signal strength readout when using an Ethernet cable, a good analogy would be using a landline phone inplace of a mobile phone and asking if that improves the signal. Wireless signal strength is only relevant over a wireless connection, and one of the reasons for always recommending an Ethernet cable connection for multiroom & internet streaming is to eliminate all the variables and issues that are inherent with wireless.
Check the error code and report back as and when.
on 22-10-2021 09:28
on 06-11-2021 16:55
on 06-11-2021 19:02
I see you've got another thread here relating to broadband issues. That will be having zero impact on your live TV or multiroom streaming, it's different connections involved. OnDemand on each individual box uses the internet and that could be impacted, but multiroom streaming uses the following set of connections:
V6 box 1 <---> Hub <----> V6 box 2. No internet involved. OnDemand uses.... V6 box 1 <---> Hub <---> Internet.
The signal strengths you're checking here, are between the V6 and the hub - anything below 50% (IMO) has potential for problems sooner or later - the strengths you've reported will not be helping the issues one bit, and could well be the underlying cause. You can restart any individual box as many times as you like, but if the WiFi signal is poor - then that's what you need to fix. A bit like rebooting a mobile phone to "reattach" to the network when the signal strength is poor.
on 09-11-2021 11:16
