on 20-08-2021 16:34
Download speeds have seemed slow for several weeks. I tested today between 13:00 and 15:00 and got results varying between 67 and 160 Mbps.
M200: Windows 7 Ultimate: Super Hub 3
Software Version "V1.01.35"
Hardware Version 3.11
Lots of errors - Error Number Error Description
84020200 Lost MDD Timeout
traceroute to bbc.co.uk (151.101.0.81), 30 hops max, 64 byte packets
01 10.53.37.117 <10.000ms <0.000ms <10.000ms
02 86.28.83.57 <10.000ms <10.000ms <10.000ms
03 * * *
04 * * *
05 62.254.84.66 <10.000ms <20.001ms <10.000ms
06 157.52.127.10 <20.000ms <20.001ms <20.000ms
07 151.101.0.81 <10.000ms * <10.000ms
Traceroute complete.
What does this mean?
on 23-08-2021 21:49
I have now.
D/l speeds 45.4 and 45.2 one minute apart.
43.5 and 45.3 with original cable.
on 23-08-2021 22:17
on 24-08-2021 14:38
Well, thanks for trying.
I've just d/loaded the current version of MS Edge and that gives slightly lower results but with a massive latency of around 35ms.
I've also ruled out anti-virus and VPN as sources of problems and all three computers, connected via ethernet, are painfully slow. I don't see how it can be anything but the hub.
All VM b/band users I know have hubs at least two generations later than mine so I'm waiting (but not holding my breath) for the promised replacement hub.
Ciao.
on 24-08-2021 14:55
on 25-08-2021 11:49
Yeah, bottom port only - that's the one I used.
I just used Samknows again and got 45.2 Mbps download speed ; I then tried one of the other pcs and got an identical result.
The first point at which the two have a common connection is in the hub.
I see it as VM's responsibility and I don't see why I should buy other equipment. Bear in mind that this setup has been working well for several years - ever since the SH2 was current, in fact. 🙂
Thank you for trying.
on 27-08-2021 13:46
Hi Jaberwok,
Thanks for your post.
I am sorry you are having intermittent issues, I can see you have been in touch for a hub replacement but nothing has been put through. Would you want a hub to upgrade to the hub 3 ?
Zoie
on 28-08-2021 11:44
Hi Zoie.
Thanks for the reply.
I have been assured that the replacement hub (SH3) has now been ordered and should be delivered on Tuesday next.
on 30-08-2021 13:28
Hi jaberwok
Thanks for coming back to us. I can see this scheduled delivery. This can be tracked here
Let us know how the visit goes
Kind regards,
on 01-09-2021 23:07
Well, it arrived on Wednesday afternoon. Someone needs reminding that dispatch is not the same thing as delivery.
On Wednesday morning I briefly got d/l speeds of 114 and 104 Mbps but then it went back to 45.2 and 45.0.
After installing the replacement hub, I got speeds of 41.0 and 39.0. Testing on another pc gave 36.8.
Now, a few hours after the re-installation and rebooting, the speed is 45.3. Apparently I have downstream connectivity only.
The Virgin Media web-page test, unusually, actually says that there is a problem. It says "This issue is caused by interference on the cabling coming into your home" so, now what? Any advice would be welcome.
on 01-09-2021 23:15
BTW, ironically, Wi-Fi is fine.
Did you know - the beautiful, shiny installation guide for the SH3 mentions ethernet just once - effectively saying "when all else fails, connect via ethernet to go online to look for help in getting Wi-Fi working".
