on 25-11-2022 07:42
Been having issues with Wi-Fi signal for a while now. I’ve rebooted the Hub 3 so many times it is getting ridiculous. Today I checked the settings online and ran a test. This is what it said:
“Your home network has a few problems”
nothing else. No advice on how to rectify the “problems”. Can someone from VM please come back to me to advise what I need to do to get a Wi-Fi signal and broadband service worthy of the money I am paying.
thanks.
on 28-11-2022 09:02
Hi Mark1871,
Thanks for your post and it's great having you back in the Community.
I'm sorry to hear that you are having continued issues with your connection. Checking our systems, I can see all is looking well with the Hub in terms of power and signal levels, uptime and time outs. There are no faults open that may be affecting you either. I can see all the devices are connecting through the WiFi.
There are so many things that can influence a WiFi connection some of which include but are not limited to, a fish tank being in the same room, walls being built with concrete instead of brick, it could even be that your next door neighbours router is interfering with yours. Due to this, we are only able to offer limited help. Please have a look here: WiFi Help.
The Hub's location could also be causing the coverage problem so we do need to check the positioning of it. Can you please ensure the following:
Think of the Hub as a radio, and WiFi as the sound - the further away you are from the radio, or the more obstacles that are in the way (walls, electronic devices etc.), the quieter the radio & the poorer the WiFi.
If that doesn't help, you can download our Connect App which will allow you to scan areas of your home and will offer help. You can view more information on that here.
Finally, you can view more about our new WiFi Max service here.
Please keep us posted on how you get on.
on 28-11-2022 12:14
Thanks for the reply. It seems to just be signal from the router to devices like our Ring camera. The router is in the only place it can be sat because of the cables. I’m told it will cost me to have it moved which isn’t an option at the moment. It is next to the TV and the door that leads to the hallway and within 12 feet of the Ring camera and doorbell. No obstacles in the way. All internal walls are stud walls. No brick.
on 28-11-2022 16:00
on 30-11-2022 17:39
Good Evening @Mark1871, thanks for your post on our Community Forums, and I'm sorry to hear of the connection issues you've been experiencing.
Can you please provide us with an update on the services?
Have you been able to put the helpful advice by @jbrennand to the test to see if this helps resolve the issue?
Kindest regards,
David_Bn
on 30-11-2022 19:10
No change. What else can I say?
on 30-11-2022 20:56
on 01-12-2022 18:56
I would like a broadband service worth the money I’m paying. Not looking for anything other than that…
on 04-12-2022 13:24
Hi @Mark1871, can you please confirm if you followed the suggestion of splitting the bands as suggested by @jbrennand?
You may find that specifically placing certain devices on certain bands may be beneficial.
Kindest regards,
David_Bn
on 18-12-2022 21:35
Everything suggested has been done. No change. What next?
on 20-12-2022 07:23
Weak wifi signal still an issue and nobody at Virgin Media seems willing to help put it right. I’m obviously not and expert but if a device cannot detect a Wi-Fi signal from within 10 feet of the router I’m pretty sure that means something isn’t right. I call and I’m told to come here. I come here and try all tips given and nothing changes. Next step is???
