on 17-04-2023 19:56
Hi there
since the first week of March keep loosing WiFi signal. Engineer come last week still the same thing. This is unacceptable not having WiFi and no one can do something about it. You guys are quick to call for upgrades and sales but when there is a problem there is no support or number to call. Just asking advice if I can terminate the contract due to not being able to use your product that I am paying for.
Answered! Go to Answer
on 17-04-2023 20:04
on 17-04-2023 20:04
on 17-04-2023 20:08
Since we had the issue in the area last month the internet never worked again engineer come in changed a metal connector from the back of the hub I was told to wait 24hours but still the same.
on 17-04-2023 20:09
on 17-04-2023 21:19
Have to send one tab at time
Cable Modem StatusItem Status CommentsChannel Overview Downstream Upstream
Cable Modem Status | Online | DOCSIS 3.1 |
Primary downstream channel | Locked | SC-QAM |
DOCSIS 3.0 channels | 31 | 5 |
DOCSIS 3.1 channels | 1 | 1 |
on 17-04-2023 21:32
1 | 139000000 | 3.299999 | 38.983261 | QAM256 | 1 |
2 | 147000000 | 2.099998 | 38.983261 | QAM256 | 2 |
3 | 155000000 | 2.599998 | 38.983261 | QAM256 | 3 |
4 | 163000000 | 2.700001 | 38.983261 | QAM256 | 4 |
5 | 171000000 | 2.599998 | 38.983261 | QAM256 | 5 |
6 | 179000000 | 2.299999 | 40.366287 | QAM256 | 6 |
7 | 187000000 | 2.400002 | 40.946209 | QAM256 | 7 |
8 | 195000000 | 2.200001 | 40.946209 | QAM256 | 8 |
9 | 203000000 | 2.000000 | 38.983261 | QAM256 | 9 |
10 | 211000000 | 1.799999 | 40.366287 | QAM256 | 10 |
11 | 219000000 | 1.599998 | 38.983261 | QAM256 | 11 |
12 | 227000000 | 1.400002 | 38.983261 | QAM256 | 12 |
13 | 235000000 | 1.000000 | 40.366287 | QAM256 | 13 |
14 | 243000000 | 1.099998 | 38.983261 | QAM256 | 14 |
15 | 251000000 | 1.299999 | 38.983261 | QAM256 | 15 |
16 | 259000000 | 2.000000 | 38.983261 | QAM256 | 16 |
17 | 267000000 | 2.099998 | 40.366287 | QAM256 | 17 |
18 | 275000000 | 2.000000 | 38.983261 | QAM256 | 18 |
19 | 283000000 | 1.900002 | 38.983261 | QAM256 | 19 |
20 | 291000000 | 1.900002 | 40.366287 | QAM256 | 20 |
21 | 299000000 | 2.299999 | 38.983261 | QAM256 | 21 |
22 | 307000000 | 2.000000 | 38.983261 | QAM256 | 22 |
23 | 315000000 | 1.599998 | 38.983261 | QAM256 | 23 |
24 | 323000000 | 1.000000 | 38.983261 | QAM256 | 24 |
25 | 331000000 | 0.799999 | 38.605377 | QAM256 | 25 |
26 | 339000000 | 0.400002 | 38.983261 | QAM256 | 26 |
27 | 347000000 | 0.500000 | 38.983261 | QAM256 | 27 |
28 | 355000000 | -0.099998 | 38.983261 | QAM256 | 28 |
29 | 363000000 | -0.599998 | 38.983261 | QAM256 | 29 |
30 | 371000000 | -1.299999 | 38.605377 | QAM256 | 30 |
31 | 379000000 | -1.400002 | 38.605377 | QAM256 | 31 |
1 | Locked | 38.983261 | 0 | 0 |
2 | Locked | 38.983261 | 0 | 0 |
3 | Locked | 38.983261 | 0 | 0 |
4 | Locked | 38.983261 | 0 | 0 |
5 | Locked | 38.983261 | 0 | 0 |
6 | Locked | 40.366287 | 0 | 0 |
7 | Locked | 40.946209 | 0 | 0 |
8 | Locked | 40.946209 | 0 | 0 |
9 | Locked | 38.983261 | 0 | 0 |
10 | Locked | 40.366287 | 0 | 0 |
11 | Locked | 38.983261 | 0 | 0 |
12 | Locked | 38.983261 | 0 | 0 |
13 | Locked | 40.366287 | 0 | 0 |
14 | Locked | 38.983261 | 0 | 0 |
15 | Locked | 38.983261 | 0 | 0 |
16 | Locked | 38.983261 | 0 | 0 |
17 | Locked | 40.366287 | 0 | 0 |
18 | Locked | 38.983261 | 0 | 0 |
19 | Locked | 38.983261 | 0 | 0 |
20 | Locked | 40.366287 | 0 | 0 |
21 | Locked | 38.983261 | 0 | 0 |
22 | Locked | 38.983261 | 0 | 0 |
23 | Locked | 38.983261 | 0 | 0 |
24 | Locked | 38.983261 | 0 | 0 |
25 | Locked | 38.605377 | 0 | 0 |
26 | Locked | 38.983261 | 0 | 0 |
27 | Locked | 38.983261 | 0 | 0 |
28 | Locked | 38.983261 | 0 | 0 |
29 | Locked | 38.983261 | 0 | 0 |
30 | Locked | 38.605377 | 0 | 0 |
31 | Locked | 38.605377 | 0 | 0 |
159 | 96 | 4K | 1840 | QAM4096 | 424 |
159 | Locked | 43 | 1.9 | 248297801 | 51 |
on 17-04-2023 21:34
1 | 30100000 | 50.520599 | 5120 KSym/sec | 64QAM | 12 |
2 | 23600000 | 50.020599 | 5120 KSym/sec | 64QAM | 13 |
3 | 36600000 | 50.520599 | 5120 KSym/sec | 64QAM | 11 |
4 | 43100000 | 50.520599 | 5120 KSym/sec | 64QAM | 10 |
5 | 49600000 | 51.020599 | 5120 KSym/sec | 64QAM | 9 |
1 | US_TYPE_ATDMA | 0 | 0 | 0 | 0 |
2 | US_TYPE_ATDMA | 0 | 0 | 0 | 0 |
3 | US_TYPE_ATDMA | 0 | 0 | 0 | 0 |
4 | US_TYPE_ATDMA | 0 | 0 | 0 | 0 |
5 | US_TYPE_ATDMA | 0 | 0 | 0 | 0 |
14 | 10.0 | 44.0 | 2K | QAM8 |
14 | OFDMA | 200 | 53.9 | 2 | 0 |
on 17-04-2023 21:34
on 17-04-2023 21:35
Network access | true |
Maximum Number of CPEs | 1 |
Baseline Privacy | true |
DOCSIS Mode | 3.1 |
Config file | 87dsfd;kfoA,.iyewrkldJKDHSUBs |
SFID | 80 |
Max Traffic Rate | 287500061 |
Max Traffic Burst | 42600 |
Min Traffic Rate | 0 |
SFID | 79 |
Max Traffic Rate | 27500061 |
Max Concatenated Burst | 42600 |
Scheduling Type | bestEffort |
on 17-04-2023 21:36
Mon Apr 17 | 6 | US profile assignment change. US Chan ID: 14; Previous Profile: 12; New Profile: .;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
Mon Apr 17 | 6 | CM-STATUS message sent. Event Type Code: 24; Chan ID: 159; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: 1.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
Mon Apr 17 | 3 | SYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
Mon Apr 17 | 6 | CM-STATUS message sent. Event Type Code: 16; Chan ID: 159; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: 3.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
Mon Apr 17 | 6 | CM-STATUS message sent. Event Type Code: 24; Chan ID: 159; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: 2.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
Mon Apr 17 | 3 | No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
Mon Apr 17 | 6 | CM-STATUS message sent. Event Type Code: 23; Chan ID: 159; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: N/A.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
Mon Apr 17 | 6 | CM-STATUS message sent. Event Type Code: 5; Chan ID: 24; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: N/A.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
Mon Apr 17 | 6 | US profile assignment change. US Chan ID: 14; Previous Profile: 11; New Profile: 12.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
Mon Apr 17 | 6 | US profile assignment change. US Chan ID: 14; Previous Profile: ; New Profile: 11.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
Mon Apr 17 | 6 | CM-STATUS message sent. Event Type Code: 5; Chan ID: 12; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: N/A.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
Mon Apr 17 | 6 | CM-STATUS message sent. Event Type Code: 5; Chan ID: 12; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: N/A.; |
