on 26-06-2022 23:42
Started off with disconnecting at the same time every night, between 1am and 2am. Now its constantly dropping out or disconnecting completely throughout the day.
on 29-06-2022 10:07
Hi @Nnicoletaylor,
Thanks for posting and welcome to the community. I am sorry to hear of the WiFi dropping out, can appreciate how frustrating that is. From a system check ran today it shows the below; We need to check that the coax cable (white cable) is connected securely to every piece of Virgin Media kit but also ensure that it is connected securely to any splitters that are in use as well as the wall socket.
Tighten any loose connections to make sure they are finger tight. If the cables have push-fit connectors make sure they are connected securely, especially to the back on the Hub 3.0.
When you've checked this, please reboot and monitor for me. If still happens let me know. If you've already done it recently, let me know.
Best,
on 05-07-2022 19:39
This did not help
on 05-07-2022 20:07
on 08-07-2022 08:59
Good Morning @Nnicoletaylor, I've been able to look in your local area, and see that it's free from any outages.
I've then ran a flow on your hub and have been able to identify that an engineer is required to attend your property.
Check out the purple envelope in the top right hand corner for a private message from me.
Kindest regards,
David_Bn
