on 17-06-2022 21:05
I'm sitting 576mm from my router & cant get a stable Wifi signal - useless.
This post has had to be submitted by my phones G4 because Wifi is so bad.
Can someone tell me how to escape from this c**p contract
on 17-06-2022 21:07
Whoopee - I got a hello badge !
I'd rather have what I'm paying for !
on 18-06-2022 15:26
on 18-06-2022 15:41
on 20-06-2022 18:09
Hi ToberMoray
Thanks for posting and welcome to the community. Sorry to hear you're having issues with the WiFi. I've done a system check today and there's no outages or area issues that could be causing this. Then done a further check on your power levels, both upstream and downstream all fine, plus no congestion nor SNR (signal to noise ratio issues). Can you confirm please if it's just WiFi that's affected or is it broadband as a whole, with Ethernet devices affected too?
If it's just WiFi, then please use the Connect app, virg.in/connect app - on your phone. This when installed, will allow you to do a wireless scan in the property, identifying any coverage blackspots and also will prompt you to order a Pod if needed.
Let us know 🙂
Best,
