on 25-09-2022 19:31
Hi.
I am trying to change my websafe settings but I get an error message that says my settings cannot be saved at this time.
on 25-09-2022 22:20
Are you seeing the old UI (left) or the new UI (right). If the latter then when signed in to My Virgin Media go to Web Safe Settings (old UI) and try making the changes there
Have I helped? Click Mark as Helpful Answer and solved, or use Kudos to say thanks
on 27-09-2022 14:48
Thanks for the reply. I am seeing the new UI. How do I get to the old UI to change the Settings?
on 29-09-2022 15:52
Hey Shaun0963, thanks for your posts and replies on our help forum.
Sorry to see you had an issue with changing the child safe settings online due to this error message, has the advice above helped and have you managed to do this since you last posted on Tuesday?
Let us know if you still need our assistance with this. happy to offer it.
on 29-09-2022 16:00
Hi. I’m afraid to say the above information hasn’t helped me. I am still getting the same error message when trying to change the websafe settings.
on 02-10-2022 09:00
Thanks for the update Shaun0963,
To investigate this further I've dropped you a PM.
You'll find the message within the purple envelope icon.
Regards,
on 02-10-2022 13:40
Thanks for your cooperation over PM Shaun0963,
That should now be ready to switch for you within the next 24 hours.
Be sure to pop back up if any issues occur.
Regards,
