on 29-07-2022 06:31
Hi I’ve been experiencing a permanent red light issue on my hub. I do have WiFi but it’s not great. I’ve checked all connections they appear to be fine. it’s up on unit so not overheating. I’ve rebooted it etc…..
I spoke on webchat at least a week ago and they ran tests and said everything was fine so probably in the middle of updates. However the red light has permanently been on now for about 2 weeks now.
Answered! Go to Answer
on 31-07-2022 16:06
Hi @Kimborooney
Thanks for coming back to us, I will send you a PM now to book a tech visit in.
Kind regards,
on 29-07-2022 10:10
Turn off hub, leave for half an hour, turn on and of the LED is still red it will need replacing. a VM staff member will get to your post shortly.
on 29-07-2022 11:14
Hi there Kimborooney, welcome to our forum page and thanks for posting here with your issue.
We're sorry to hear you have a red light on your hub, could you please let us know whether that has an impact to the services?
Is your landline connecting via the hub too? If so, does this work at the minute?
Also, you may follow the below steps as Tudor suggested:
• Then use the power switch to turn the unit back on. The Hub should now operate normally.
Please, try the above and let us know if the red light comes back on and if the internet or any other service has been affected by this.
Happy to help based on your feedback.
on 29-07-2022 12:04
Hi tried everything and it’s still come back on red.
I don’t have a landline.
Yes the internet has been affected a bit sort of intermittent when im doing something say online and I have to re-fresh/try again same with iPlayer when im signing in.
on 31-07-2022 16:06
Hi @Kimborooney
Kind regards,
on 02-08-2022 11:12
Hi @Kimborooney
Thanks for joining me on PM and confirming your address for the technician visit due to the red light on your router, after all the checks have been done.
There will be no charge for this visit unless:
• The technician diagnoses the faults as not being caused by our network/equipment
• The technician discovers that the fault or problem relates to your equipment
• The technician discovers that the fault or problem relates to any system that we are not responsible for
The technician will confirm during their visit if any of these instances apply, and if so, a £25 charge will be applied to your account.
Please ensure there is someone over the age of 18 present at the time of the visit. If you need to change or cancel your appointment you can do this online or via the MyVM app by 4pm the day before the appointment.
If you do miss an agreed appointment for any reason, a £25 missed appointment charge will be applied to your account on the day of the appointment
