Orbi Mesh Network with VM
RG5
Hi I have an Orbi Mesh network with VM which I installed a couple of years ago. I followed online instructions, so I have no idea what I did - I remember taking an http address from the bottom of the router and changing some setting from the VM Hub3 - more on this in a bit.
I had the VM Hub3 wired directly to the Orbi router, from which I run two satellites. Everything was working until yesterday when I had to reset the Orbi router, in doing so the network in my home is now ORBI xyz123 rather than VM xyz123.
Everything seems to be work, although it took a fair deal of time for all the devices to long on to the new network. I just wanted to check that this was a normal thing and won't affect my account with Virgin - I've checked service status online several times and everything seems to be okay with Virgin.
As to the http address on the bottom of the VM hub, when I put the address into the search bar it just times out - ??
Any advice gratefully received, ta.
2 REPLIES 2
Cardiffman282
Problem sorter
Modem mode hub settings are at 192.168.100.1
Cancel VM here
Complain to VM
here
Demand compensation from VM here
Demand your call recordings here
Monitor the state of your VM connection here
Online Manuals for Orbi and Orbi Pro...
https://www.netgear.com/support/product/orbi
