29-06-2022 08:27 - edited 29-06-2022 08:29
Signed up to Virgin on the 19th of June after being away from Virgin for 2 years
been checking the router log. Seems to be some critical errors apparently.
Can anyone tell me what it means?
29/06/2022 06:39:30 | critical | No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
27/06/2022 07:26:29 | Error | DHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
24/06/2022 23:20:7 | critical | No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
24/06/2022 07:16:5 | Error | DHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
21/06/2022 20:38:23 | critical | No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
20/06/2022 09:45:46 | Warning! | Lost MDD Timeout;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
20/06/2022 09:45:41 | critical | SYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
20/06/2022 09:45:41 | Warning! | RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
20/06/2022 09:07:40 | critical | No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
19/06/2022 18:36:49 | Error | DHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
19/06/2022 17:49:21 | notice | LAN login Success;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
19/06/2022 17:48:21 | Warning! | LAN login FAILED : Incorrect Username / Password / ConnectionType;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
19/06/2022 17:41:26 | Error | DHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
19/06/2022 17:21:49 | critical | No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
19/06/2022 17:08:21 | critical | Received Response to Broadcast Maintenance Request, But no Unicast Maintenance opportunities received - T4 time out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
19/06/2022 17:08:12 | Warning! | Lost MDD Timeout;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
19/06/2022 17:08:8 | Warning! | RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
19/06/2022 17:08:7 | critical | SYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
Answered! Go to Answer
on 11-07-2022 12:50
A few T3 timeouts are not unusual on a cable internet connection - if you've got speed, reliability or connection quality problems then focus on those rather than the network log. If you're seeing T3 errors multiple times in a day then that's usually a sign of a problem, but if you're only aware of the T3s because you went looking, and there's only one every two or three days then I'd ignore it.
on 29-06-2022 08:30
1 | 267000000 | 4 | 38 | 256 qam | 17 |
2 | 275000000 | 4.5 | 38 | 256 qam | 18 |
3 | 283000000 | 5.3 | 38 | 256 qam | 19 |
4 | 291000000 | 5.1 | 38 | 256 qam | 20 |
5 | 299000000 | 5 | 38 | 256 qam | 21 |
6 | 307000000 | 4.8 | 38 | 256 qam | 22 |
7 | 315000000 | 5.9 | 38 | 256 qam | 23 |
8 | 323000000 | 5.9 | 38 | 256 qam | 24 |
9 | 331000000 | 5.4 | 38 | 256 qam | 25 |
10 | 339000000 | 5.1 | 38 | 256 qam | 26 |
11 | 347000000 | 5.9 | 38 | 256 qam | 27 |
12 | 355000000 | 5.8 | 38 | 256 qam | 28 |
13 | 363000000 | 5.9 | 40 | 256 qam | 29 |
14 | 371000000 | 5.4 | 38 | 256 qam | 30 |
15 | 379000000 | 5.6 | 38 | 256 qam | 31 |
16 | 387000000 | 5.4 | 38 | 256 qam | 32 |
17 | 395000000 | 5 | 38 | 256 qam | 33 |
18 | 403000000 | 4.6 | 38 | 256 qam | 34 |
19 | 411000000 | 4.6 | 38 | 256 qam | 35 |
20 | 419000000 | 4.8 | 38 | 256 qam | 36 |
21 | 427000000 | 4.5 | 38 | 256 qam | 37 |
22 | 435000000 | 4.8 | 38 | 256 qam | 38 |
23 | 443000000 | 4.5 | 38 | 256 qam | 39 |
24 | 451000000 | 4.6 | 38 | 256 qam | 40 |
1 | Locked | 38.9 | 4250 | 41 | |
2 | Locked | 38.6 | 5089 | 35 | |
3 | Locked | 38.9 | 4304 | 28 | |
4 | Locked | 38.9 | 6539 | 23 | |
5 | Locked | 38.6 | 8446 | 23 | |
6 | Locked | 38.6 | 9586 | 18 | |
7 | Locked | 38.9 | 8424 | 4 | |
8 | Locked | 38.9 | 9858 | 0 | |
9 | Locked | 38.9 | 13862 | 0 | |
10 | Locked | 38.9 | 15308 | 0 | |
11 | Locked | 38.6 | 16768 | 13 | |
12 | Locked | 38.9 | 17926 | 2 | |
13 | Locked | 40.3 | 16796 | 4 | |
14 | Locked | 38.9 | 21912 | 42 | |
15 | Locked | 38.9 | 25015 | 26 | |
16 | Locked | 38.6 | 22745 | 1 | |
17 | Locked | 38.9 | 28568 | 2 | |
18 | Locked | 38.9 | 28594 | 0 | |
19 | Locked | 38.9 | 29826 | 14 | |
20 | Locked | 38.9 | 32140 | 17 | |
21 | Locked | 38.9 | 33015 | 19 | |
22 | Locked | 38.9 | 32421 | 42 | |
23 | Locked | 38.6 | 32589 | 0 | |
24 | Locked | 38.9 | 31796 | 0 |
on 29-06-2022 08:31
1 46200000 40.8 5120 64 qam 3
2 60300000 42 5120 64 qam 1
3 39400000 40.5 5120 64 qam 4
4 53700000 41.3 5120 64 qam 2
1 ATDMA 0 0 4 0
2 ATDMA 0 0 1 0
3 ATDMA 0 0 2 0
4 ATDMA 0 0 2 0
on 29-06-2022 14:57
on 29-06-2022 22:01
Shall I post It in there?
on 30-06-2022 01:35
on 02-07-2022 10:17
Hi there. Thank for posting. Sorry to hear of the broadband issues. I've done a system check today and can see you're affected by a SNR (signal to noise ratio) issue. F009929024 - this is your fault reference. The estimated fix date is the 7th July, just after 1pm. Please monitor the connection for me after this date and let me know if having issues still, will be happy to help.
Best,
on 11-07-2022 10:24
Hi I'm still getting "critical" error after the 8th
11/07/2022 06:43:27 | critical | No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0; |
on 11-07-2022 12:50
on 11-07-2022 16:02
Thanks! I haven't really had no problems so I should stop looking at the logs 🙈🤣
